USB2 eye diagram JP6.2
I am using the JETSON AGX ORIN INDUSTRIAL module on a custom carrier board, and using the USB2-0, USB2-1 ports as HOST only,
In JP5.1.4, I had to define the value nvidia,hs_curr_level=<6> in the DT for the USB ports to work correctly.
Is it possible to define this value in the DT in JP6.2 as well?
Yehonatan
This is not supported. Please follow design guide and make sure the hardware design is correct.
