We have a custom carrier board. We tried to adapt JetPack 4.2.2 for the Jetson TX2i as we have done for the Jetson TX2. With the TX2, everything is working so far. With the TX2i, we are not able to make our two USB3 Ports run (USB3-1 and USB3-2). Can you please check our device tree file and see if there is an error?
Thank you.
and then disabling port and lane for usb3-0, USB3-1 and USB3-2 Ports are working now. But still we face an issue. When the USB3.0 Device is already connected at power on, it only gets recognized as USB2.0 device. When replugged, it gets correctly recognized as USB3.0 device. This happens only with one USB3.0 port (usb3-2), where the USB2.0 Signals are going over a USB2.0 Hub. We added a ramp delay for the Enable of the Hub, but without success so far:
Do you have any idea what could be the problem? Increasing the delay?
Measuring the enable signal, we see that it stays low at the power on and then goes high during booting, as expected.
Thank you.
