USB3.1 storage performance issue
Software Version
[] DRIVE OS 6.0.8.1
] DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] DRIVE AGX Orin Developer Kit (940-63710-0010-200)
other
SDK Manager Version
1.9.3.10904
[*] other
Host Machine Version
[*] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
I have tested the write speed with dd and found that the performance on orin (type-c) was very poor, about 16-45MB/s (I have tried three orins, DriveOS 6.0.3/8/9), and the same USB-SSD on PC was about 450MB/s~2.4GB/s
Orin:
PC:
What needs to be configured to achieve USB 3.1 performance?
Dear @xiaolei.qin,
Could you check if DriveWorks SDK Reference: High Throughput Recording helps?
Hello @SivaRamaKrishnaNV,
I have made some adjustments to USB IO parameters based on the documentation, and now there has been a significant improvement of USB throughput. Therefore, I will mark your reply as a solution.
Thank you for your reply!
Dear @xiaolei.qin,
May I know the which SSD is used in this test?
I used the USB-nvme SSD:
