USB dev mode transfer speed
I’m running Orin AGX with the USB dev mode (also known as Ethernet over USB) as suggested in L4T-README README-usb-dev-mode.txt.
Running the commands
$ lsusb
Bus 002 Device 003: ID 0955:7020 NVidia Corp.
$ lsusb -t
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/10p, 10000M
    |__ Port 8: Dev 3, If 0, Class=Communications, Driver=rndis_host, 5000M
    |__ Port 8: Dev 3, If 1, Class=CDC Data, Driver=rndis_host, 5000M
    |__ Port 8: Dev 3, If 2, Class=Communications, Driver=cdc_acm, 5000M
    |__ Port 8: Dev 3, If 3, Class=CDC Data, Driver=cdc_acm, 5000M
    |__ Port 8: Dev 3, If 4, Class=Mass Storage, Driver=usb-storage, 5000M
    |__ Port 8: Dev 3, If 5, Class=Communications, Driver=cdc_ncm, 5000M
    |__ Port 8: Dev 3, If 6, Class=CDC Data, Driver=cdc_ncm, 5000M
Show that the Orin AGX link is capable of USB3 speeds. But when I run tests with iperf3 I can only get transfer speeds around 982 Mbits/s
$ iperf3 -c 192.168.55.1
Connecting to host 192.168.55.1, port 5201
[  4] local 192.168.55.100 port 56000 connected to 192.168.55.1 port 5201
[ ID] Interval           Transfer     Bandwidth
[  4]   0.00-1.00   sec   114 MBytes   954 Mbits/sec
[  4]   1.00-2.00   sec   116 MBytes   973 Mbits/sec
[  4]   2.00-3.00   sec   117 MBytes   982 Mbits/sec
[  4]   3.00-4.00   sec   118 MBytes   987 Mbits/sec
[  4]   4.00-5.00   sec   117 MBytes   985 Mbits/sec
[  4]   5.00-6.00   sec   118 MBytes   987 Mbits/sec
[  4]   6.00-7.00   sec   118 MBytes   988 Mbits/sec
[  4]   7.00-8.00   sec   118 MBytes   987 Mbits/sec
[  4]   8.00-9.00   sec   118 MBytes   987 Mbits/sec
[  4]   9.00-10.00  sec   118 MBytes   988 Mbits/sec
[  4]   0.00-10.00  sec  1.14 GBytes   982 Mbits/sec                  sender
[  4]   0.00-10.00  sec  1.14 GBytes   982 Mbits/sec                  receiver
iperf Done.
I tested this with both Windows and Linux host and the results are the same. I would expect speeds close to 5000 Mbits/sec. I also tested the bandwidth with nuttcp and it gave similar results.
Any advice how could I reach USB3 speeds around 5000 Mbits/sec?
About the setup
  • I’m using jetson-agx-orin-devkit-as-nx-16gb
  • I had to reflash the device according to these instructions in order to get the USB dev mode work
Would like to confirm the set up, so Orin is connected to a host PC through type-C port and run in device mode. And the host PC accesses internet through Ethernet port on Orin developer kit. Do we understand the set up correctly?
Hi DaneLLL,
Yes. Only a single USB cable is used, USB-A to USB-C.
No. The host is connected to internet directly through ethernet port. Orin AGX is not connected to internet at all and the ethernet port is not used.
On Linux host I was able to fix this by running
ifconfig l4tbr0 mtu 9000
on Orin AGX and then I got 2.5 Gbps with iPerf.
On Windows host, I still get less than 1 Gbps.
Generally we set up with Linux host PC. Would suggest use this setup. It is possible to hit certain issues with Windows host PC.
