Hi, I am a newcomer working on Jetson Nano 2G since a week right now. JetPack 4.6.
I want to attach a Samsung 750 Evo 250 GB SSD to the Nano. My problem is that it will only connect as a high speed device, not as a supersede device. Spuerspeed is working theoretical, as it does connect with supersede with a SanDisk USB dongle.
I started using an ICY case: IB-245-C31-B, which uses JMicron controller, which I found out is known to cause problems. Therefore I tried a UGREEN based on ASM1153E which theoretically should work. It supports UAS as well.
Also, I tried to connect the drive via a USB 3.0 Hub. Hub will connect @superspeed, drives in the same way as when connected directly.
Unfortunately, it does not work. Find here “dmesg | grep usb” and “lsusb -t”. Any ideas?
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 core_edp_mv=1125 core_edp_ma=4000 gpt earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.418019] iommu: Adding device 70090000.xusb to group 2
[ 0.486502] vdd-usb-vbus: 5000 mV
[ 0.486705] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.487032] vdd-usb-vbus2: 5000 mV
[ 0.534521] usbcore: registered new interface driver usbfs
[ 0.534564] usbcore: registered new interface driver hub
[ 0.534607] usbcore: registered new device driver usb
[ 0.601017] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.603092] vdd-usb-hub-en: 5000 mV
[ 0.603430] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 1.010526] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x8207c10
[ 1.010535] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 1.012118] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 1.012233] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 1.012328] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 1.012516] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 1.012601] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 1.012691] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 1.012782] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 1.012877] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 1.012970] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 1.013058] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 1.013658] tegra-xusb-padctl 7009f000.xusb_padctl: failed to setup XUSB ports: -517
[ 1.105515] usbcore: registered new interface driver r8152
[ 1.105561] usbcore: registered new interface driver asix
[ 1.105617] usbcore: registered new interface driver ax88179_178a
[ 1.105658] usbcore: registered new interface driver cdc_ether
[ 1.105697] usbcore: registered new interface driver net1080
[ 1.105739] usbcore: registered new interface driver cdc_subset
[ 1.105774] usbcore: registered new interface driver zaurus
[ 1.105835] usbcore: registered new interface driver cdc_ncm
[ 1.109429] usbcore: registered new interface driver uas
[ 1.109487] usbcore: registered new interface driver usb-storage
[ 1.109589] usbcore: registered new interface driver usbserial
[ 1.113713] usbcore: registered new interface driver xpad
[ 1.314180] usbcore: registered new interface driver usbhid
[ 1.314182] usbhid: USB HID core driver
[ 1.318353] usbcore: registered new interface driver snd-usb-audio
[ 1.399204] vdd-usb-vbus-en: 5000 mV
[ 1.399544] vdd-usb-vbus-en: supplied by vdd-5v0-sys
[ 1.402966] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x8207c10
[ 1.402970] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 1.403652] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 1.403716] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 1.403775] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 1.403884] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 1.403940] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 1.403996] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 1.404050] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 1.404104] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 1.404159] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 1.404211] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 1.407532] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.408214] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.409266] tegra-xusb 70090000.xusb: extcon 0: ffffffc0786bd800 id
[ 1.412850] tegra-xusb 70090000.xusb: Firmware timestamp: 2020-07-31 09:33:12 UTC, Version: 50.26 release
[ 1.412875] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.412888] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.413616] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.413640] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.413941] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.413945] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.413949] usb usb1: Product: xHCI Host Controller
[ 1.413952] usb usb1: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 1.413955] usb usb1: SerialNumber: 70090000.xusb
[ 1.414919] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.414926] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.414991] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.415067] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.415071] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.415074] usb usb2: Product: xHCI Host Controller
[ 1.415078] usb usb2: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 1.415081] usb usb2: SerialNumber: 70090000.xusb
[ 1.415871] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 1.415876] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 1.518705] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.518855] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 2
[ 1.518971] usb usb2: usb_suspend_both: status 0
[ 1.742571] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.764686] usb 1-2: New USB device found, idVendor=174c, idProduct=235c
[ 1.764692] usb 1-2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 1.764695] usb 1-2: Product: Ugreen Storage Device
[ 1.764698] usb 1-2: Manufacturer: Ugreen
[ 1.764702] usb 1-2: SerialNumber: 20D11E80FE04
[ 1.886580] usb 1-3: new high-speed USB device number 3 using tegra-xusb
[ 1.907346] usb 1-3: New USB device found, idVendor=1a40, idProduct=0801
[ 1.907350] usb 1-3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.907354] usb 1-3: Product: USB 2.0 Hub
[ 2.030646] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 2
[ 2.050619] usb 1-3: usb_suspend_both: status 0
[ 4.043432] usb0: HOST MAC 1e:1b:6f:00:c8:86
[ 4.043461] usb0: MAC 1e:1b:6f:00:c8:87
[ 4.070955] l4tbr0: port 2(usb0) entered blocking state
[ 4.070960] l4tbr0: port 2(usb0) entered disabled state
[ 4.071236] device usb0 entered promiscuous mode
[ 4.075954] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 31.858746] vdd-usb-vbus: disabling
[ 31.858750] vdd-usb-vbus2: disabling
[ 31.858834] vdd-usb-hub-en: disabling
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/5p, 480M
|__ Port 2: Dev 2, If 0, Class=Mass Storage, Driver=uas, 480M
|__ Port 3: Dev 3, If 0, Class=Hub, Driver=hub/4p, 480M
