I plan to use Orin NX’s 3-way USBSS to directly connect to 3-way Realsense d455 without connecting USB2.0 port. Is this feasible?
No, not possible.
I tested and found that usbss can work normally when directly connected to d455 without connecting USB2.0 port.
What is the function of the bound USB2.0?
What problems will occur if USB2.0 port is not connected?
Your usb port will not work properly one day in some cases when there is no usb2.0 bounded.
Didn’t hit error now does not mean it will always work fine. You are not the first one doing such thing and those users all come back and report error. Thus, please try not to do that.
USB3 must have a usb2 to work along with. This is the spec.
Can you describe what problems other users have encountered?
Detection issue.
