USB2 Hub with Direct USB3 Interfaces
I am fairly certain this will work but I would like confirmation that this is a valid architecture. Where I have a USB2 hub that goes to USB A ports that also use the direct USB3 interfaces of the Orin NX/Nano.
No, currently it is not supported. USB2 and USBSS in same combine should go thru same hub or directly to connector together.
