Can two USBSS ports on the Orin NX be used on a single Type-C connector to achieve double transfer speeds?
I am currently using USBSS0 and DisplayPort on one Type-C connector, and I have USBSS1 on the other Type-C connector. I’d like to connect USBSS1 and USBSS2 to the second Type-C connector.
Can the Orin NX use two USBSS ports as a single USB 3.2 Gen 2×2 port?
For reference: https://tripplite.eaton.com/products/usb-connectivity-types-standards
