Use ESS Stereo DNN with Nvblox - Depth image conversion
Hi there,
I am trying to use isaac_ros_nvblox with a custom stereo camera and the Isaac ROS DNN Stereo Disparity package.
I am using the StereoDNN disparity node of the isaas_ros_ess package to generate a disparity map from a calibrated stereo camera, and am looking to feed this into the isaac_ros_nvblox package.
However, the isaas_ros_ess package outputs a disparity image of type stereo_msgs/DisparityImage, but the isaac_ros_nvblox package requires a depth image of type sensor_msgs/Image
How can I convert the StereoDNN Disparity output to the required Depth image format? Are there any Isaac ROS nodes to do this?
Thanks,
Hi @HiddenNetwork ,
You can take such an example as the code in this repository:
Raffaello
Hi @HiddenNetwork ,
second hint:
You can follow this example
And run a Composable node like the code below:
disparity_to_depth_node = ComposableNode(
    name='disparity_to_depth',
    package='isaac_ros_stereo_image_proc',
    plugin='nvidia::isaac_ros::stereo_image_proc::DisparityToDepthNode')
Best,
Raffaello
