Use pldm fetching the temp sensor of ConnectX6-Dx card (2x100G)
I can’t find the detailed information about this.
I can find a sensor through PLDM protocol:
PDR type : Numeric Sensor
record handle : 0x00000004
PDR data length : 71
PLDM terminus handle : 0x0000
sensor ID : 0x0001
entity type : 0x0050
entity instance number : 0x0000
container ID : 0x8119
sensor init : No Init
sensor auxiliary name PDR : 0x0
base unit : 0x2
unit modifier : 0x0
rate unit : 0x0
base OEM unit handle : 0x0
aux unit : 0x0
aux unit modifier : 0x0
aux rate modifier : 0x0
rel : 0x0
aux OEM unit handle : 0x0
is linear : 0x1
sensor data size : sint16
resolution : 0x0 0x0 0x80 0x3f
offset : 0x0 0x0 0x0 0x0
accuracy : 0x0000
plus tolerance : 0x0
minus tolerance : 0x0
hysteresis : 0x0005
supported thresholds : 0x7
threshold and hysteresis is volatility : 0x0
state transition interval : 0x0 0x0 0x0 0x0
update interval : 0x1 0x0 0x0 0x0
max readable : 0x0078
min readable : 0xffffffff
range field format : sint16
range field support : 0x2e
nominal value : 0x0000
normal max : 0x0069
normal min : 0xffffffd8
warning high : 0x0064
warning low : 0x0000
critical high : 0x0069
critical low : 0x0000
fatal high : 0x0073
fatal low : 0x0000
What sensor is this?
You can use mget_temp -d get temp sensor.
thanks.
