On R28.2 I can run “sensors” (and this works as expected), but 'sensors-detect" resulted in kernel error and eventual reboot from watchdog. The sensors-detect error changes for me and is not consistent. This is just conjecture, but I suspect there sensors-detect uses an i2c probe at an address which is better off not probed.
Example:
[ 103.661908] CPU3: SError detected, daif=1c0, spsr=0x800000c5, mpidr=80000101, esr=bf40c000
[ 103.661914] CPU4: SError detected, daif=1c0, spsr=0x800000c5, mpidr=80000102, esr=bf40c000
[ 103.661919] CPU0: SError detected, daif=1c0, spsr=0x800000c5, mpidr=80000100, esr=bf40c000
[ 103.661925] CPU5: SError detected, daif=1c0, spsr=0x800000c5, mpidr=80000103, esr=bf40c000
[ 103.661937] CPU1: SError detected, daif=140, spsr=0x20000000, mpidr=80000000, esr=be000000
[ 103.661944] CPU2: SError detected, daif=1c0, spsr=0x800000c5, mpidr=80000001, esr=be000000
** 98 printk messages dropped ** [ 103.664591] **************************************
** 414 printk messages dropped ** [ 103.672636] CPU1: SError detected, daif=140, spsr=0x20000000, mpidr=80000000, esr=be000000
** 595 printk messages dropped ** [ 103.684182] Address Type = Secure DRAM
** 364 printk messages dropped ** [ 103.691127] Address Type = Secure DRAM
** 363 printk messages dropped ** [ 103.697985] Address Type = Secure DRAM
** 353 printk messages dropped ** [ 103.704701] Machine check error in DCC:1:
** 374 printk messages dropped ** [ 103.711699] Address Type = Secure DRAM
** 364 printk messages dropped ** [ 103.718533] Address Type = Secure DRAM
** 363 printk messages dropped ** [ 103.725308] Address Type = Secure DRAM
** 353 printk messages dropped ** [ 103.731935] Machine check error in DCC:1:
** 374 printk messages dropped ** [ 103.738876] Address Type = Secure DRAM
** 364 printk messages dropped ** [ 103.745729] Address Type = Secure DRAM
** 363 printk messages dropped ** [ 103.752529] Address Type = Secure DRAM
** 364 printk messages dropped ** [ 103.759399] Address Type = Secure DRAM
** 363 printk messages dropped ** [ 103.766230] Address Type = Secure DRAM
** 364 printk messages dropped ** [ 103.773070] Address Type = Secure DRAM
** 361 printk messages dropped ** [ 103.779672] CPU1: SError detected, daif=140, spsr=0x20000000, mpidr=80000000, esr=be000000
** 595 printk messages dropped ** [ 103.790891] Address Type = Secure DRAM
** 364 printk messages dropped ** [ 103.797759] Address Type = Secure DRAM
** 363 printk messages dropped ** [ 103.804481] Address Type = Secure DRAM
...snip...
[ 110.698724] **************************************
[ 110.698724] Machine check error in DCC:1:
[ 110.698724] Status = 0xf400000100000405
[ 110.698725] Bank does not have any known errors
[ 110.698725] Overflow (there may be more errors)
[ 110.698725] Uncorrected (this is fatal)
[ 110.698726] Error reporting enabled when error arrived
[ 110.698726] ADDR = 0xb0
[ 110.698758] **************************************
[ 110.698758] CPU1: SError detected, daif=140, spsr=0x20000000, mpidr=80000000, esr=be000000
[ 110.698760] CPU2: SError detected, daif=1c0, spsr=0x800000c5, mpidr=80000001, esr=be000000
[ 110.698900] ROC:IOB Machine Check Error:
[ 110.698901] Address Type = Secure DRAM
[ 110.698903] Address = 0x0 (Unknown Device)
[ 110.698926] **************************************
In one case where there was a kernel register dump (I missed the log of this).
Scanning some devices can cause “unexpected” behavior. It seems though that if you just run the command:
sensors
…you will get correct behavior (though annoying this is not necessarily a bug to have random address probing do something unexpected). There is a GUI package “xsensors” if you prefer this. If you are looking specifically at measuring these values in a program I’m not sure what to suggest there.
sudo apt-get install sensors
sudo apt-get install xsensors
Unless you have a reason I’d avoid running sensors-detect.
Example output:
# sensors
BCPU-therm-virtual-0
Adapter: Virtual device
temp1: +33.5°C (crit = +101.0°C)
MCPU-therm-virtual-0
GPU-therm-virtual-0
temp1: +32.5°C (crit = -40.0°C)
Tboard_tegra-virtual-0
temp1: +30.0°C (crit = +107.0°C)
Tdiode_tegra-virtual-0
temp1: +30.8°C (crit = +107.0°C)
thermal-fan-est-virtual-0
temp1: +32.9°C
