i am use tx1 and use jetpack3.2 to flash the device.
the boot up log is
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38-tegra (buildbrain@mobile-u64-638) (gcc version 4.8.5 (GCC) ) #1 SMP PREEMPT Thu Mar 1 20:44:58 PST 2018
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] Reserved memory: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 16 MiB at 0x00000000fdc00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc0ffe10000 s31616 r8192 d29824 u69632
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1027072
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 androidboot.modem=none androidboot.serialno=03216170245780c085fe androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1125 core_edp_ma=4000 gpt root=/dev/mmcblk0p1 rw rootwait
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 4061772K/4173824K available (10945K kernel code, 2068K rwdata, 6364K rodata, 1208K init, 665K bss, 95668K reserved, 16384K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[ 0.000000] 0xffffffbdc2000000 - 0xffffffbdc6000000 ( 64 MB actual)
[ 0.000000] fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc100000000 ( 4096 MB)
[ 0.000000] .init : 0xffffffc001168000 - 0xffffffc001296000 ( 1208 KB)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc001167d74 ( 17312 KB)
[ 0.000000] .data : 0xffffffc0012b1000 - 0xffffffc0014b61b8 ( 2069 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] enable_t210_agic_clks:106 ape clocked & reset cleared
[ 0.000000] t210 clock_and_reset probe
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] kmemleak: Kernel memory leak detector disabled
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001801] Console: colour dummy device 80x25
[ 0.002761] console [tty0] enabled
[ 0.002793] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.002828] pid_max: default: 32768 minimum: 301
[ 0.002916] Security Framework initialized
[ 0.002939] SELinux: Initializing.
[ 0.003043] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003068] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003742] Initializing cgroup subsys io
[ 0.003774] Initializing cgroup subsys memory
[ 0.003814] Initializing cgroup subsys devices
[ 0.003840] Initializing cgroup subsys freezer
[ 0.003863] Initializing cgroup subsys net_cls
[ 0.003888] Initializing cgroup subsys perf_event
[ 0.003913] Initializing cgroup subsys net_prio
[ 0.003942] Initializing cgroup subsys pids
[ 0.003965] Initializing cgroup subsys debug
[ 0.004266] CPU0 ipc=1024
[ 0.004304] CPU1 ipc=1024
[ 0.004337] CPU2 ipc=1024
[ 0.004370] CPU3 ipc=1024
[ 0.004430] ASID allocator initialised with 65536 entries
[ 0.030360] tegra-id: chipid=22117.
[ 0.030392] tegra-id: opt_subrevision=0.
[ 0.030426] Tegra Speedo/IDDQ fuse revision 4
[ 0.030449] Tegra: CPU Speedo ID 7, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.030472] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ 0.030495] Tegra: CPU Speedo Value 1996, SoC Speedo Value 1866, GPU Speedo Value 1994
[ 0.030525] Tegra: CPU IDDQ Value 1512, SoC IDDQ Value 1620, GPU IDDQ Value 2055
[ 0.030569] Tegra Revision: A02 SKU: 0x17 CPU Process: 0 SoC Process: 0
[ 0.032122] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
[ 0.032173] DTB Build time: Mar 1 2018 20:46:06
[ 0.048776] CPU1: Booted secondary processor [411fd071]
[ 0.060739] CPU2: Booted secondary processor [411fd071]
[ 0.072736] CPU3: Booted secondary processor [411fd071]
[ 0.072822] Brought up 4 CPUs
[ 0.072897] SMP: Total of 4 processors activated.
[ 0.072921] CPU: All CPU(s) started at EL2
[ 0.072963] alternatives: patching kernel code
[ 0.075481] devtmpfs: initialized
[ 0.144376] Initilizing CustomIPI irq domain
[ 0.144713] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.145303] pinctrl core: initialized pinctrl subsystem
[ 0.145485] OS set in device tree is not L4T.
[ 0.145846] regulator-dummy: no parameters
[ 0.146059] Initializing plugin-manager
[ 0.146126] Plugin module not found
[ 0.147108] node /plugin-manager/fragement@0 match with board >=2180-1000-300
[ 0.148499] Adding domain ape-pd to PM domain mc-clk-pd
[ 0.148546] Adding domain adsp-pd to PM domain ape-pd
[ 0.153599] NET: Registered protocol family 16
[ 0.155365] console [pstore-1] enabled
[ 0.155389] pstore: Registered ramoops as persistent store backend
[ 0.155415] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.164227] cpuidle: using governor ladder
[ 0.176219] cpuidle: using governor menu
[ 0.176539] bpmp: mail init ok
[ 0.177316] vdso: 2 pages (1 code @ ffffffc0012b9000, 1 data @ ffffffc0012b8000)
[ 0.177372] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.178798] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.179740] tegra_powergate_init: DONE
[ 0.179784] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
[ 0.179836] DTB Build time: Mar 1 2018 20:46:06
[ 0.182769] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.182809] Error: Driver 'tegra-mc' is already registered, aborting...
[ 0.184307] platform tegra-carveouts: SMMU isn't ready yet
[ 0.185018] platform tegra-carveouts: domain=ffffffc0fa163618 allocates as[0]=ffffffc0fa17c0a8
[ 0.185088] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.185322] platform smmu_test: domain=ffffffc0fa163918 allocates as[0]=ffffffc0fa17c110
[ 0.185640] platform 70016000.bpmp: domain=ffffffc0fa163c18 allocates as[0]=ffffffc0fa17c178
[ 0.186343] bpmp: ping status is 0
[ 0.186452] bpmp 70016000.bpmp: firmware tag is 1e4b302fc0f866f97885165cf8b395ac
[ 0.186707] bpmp 70016000.bpmp: probe ok
[ 0.187349] mc: mapped MMIO address: 0xffffff800007e000 -> 0x70019000
[ 0.187451] mc: mapped MMIO address: 0xffffff80000b6000 -> 0x7001c000
[ 0.187554] mc: mapped MMIO address: 0xffffff80000dc000 -> 0x7001d000
[ 0.187643] mc-err: Set intmask: 0x23d40
[ 0.198515] GPIO line 58 (wlan-default-input-h2) hogged as input
[ 0.198565] GPIO line 65 (wlan-default-input-i1) hogged as input
[ 0.198612] GPIO line 56 (wlan-default-output-high-h0) hogged as output/high
[ 0.198657] GPIO line 64 (wlan-default-output-high-i0) hogged as output/high
[ 0.198701] GPIO line 66 (wlan-default-output-high) hogged as output/high
[ 0.198746] GPIO line 148 (cam0-rst) hogged as output/low
[ 0.198787] GPIO line 151 (cam0-pwdn) hogged as output/low
[ 0.198827] GPIO line 149 (cam1-rst) hogged as output/low
[ 0.198867] GPIO line 152 (cam1-pwdn) hogged as output/low
[ 0.198972] gpiochip_add_data: registered GPIOs 0 to 255 on device: tegra-gpio
[ 0.201474] platform 70006000.serial: domain=ffffffc0fa256118 allocates as[0]=ffffffc0fa17c1e0
[ 0.202565] platform sound: domain=ffffffc0fa256a18 allocates as[0]=ffffffc0fa17c248
[ 0.204957] platform tegradc.1: domain=ffffffc0fa260c18 allocates as[0]=ffffffc0fa17c2b0
[ 0.207501] platform 57000000.gpu: domain=ffffffc0fa266f18 allocates as[0]=ffffffc0fa17c318
[ 0.207581] platform 57000000.gpu: domain=ffffffc0fa266f18 allocates as[1]=ffffffc0fa17c380
[ 0.207657] platform 57000000.gpu: domain=ffffffc0fa266f18 allocates as[2]=ffffffc0fa17c3e8
[ 0.207728] platform 57000000.gpu: domain=ffffffc0fa266f18 allocates as[3]=ffffffc0fa17c450
[ 0.208535] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.208582] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.208609] tegra-pmc: ### PMC reset source: Software reset
[ 0.208632] tegra-pmc: ### PMC reset status reg: 0x3
[ 0.252344] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.252382] tegra-pmc: Clear bootloader IO dpd settings
[ 0.252413] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.252483] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.255643] platform 1003000.pcie-controller: domain=ffffffc0fa276018 allocates as[0]=ffffffc0fa17c4b8
[ 0.257918] platform sdhci-tegra.3: domain=ffffffc0fa2eb118 allocates as[0]=ffffffc0fa17c520
[ 0.258516] platform sdhci-tegra.0: domain=ffffffc0fa2eb518 allocates as[0]=ffffffc0fa17c588
[ 0.265419] vdd-ac-bat: 5000 mV
[ 0.266618] vdd-cpu-fixed: 1000 mV
[ 0.270523] irq: no irq domain found for /soctherm@0x700E2000 !
[ 0.270859] irq: no irq domain found for /soctherm@0x700E2000 !
[ 0.293445] ACPI: Interpreter disabled.
[ 0.294246] SCSI subsystem initialized
[ 0.294537] usbcore: registered new interface driver usbfs
[ 0.294610] usbcore: registered new interface driver hub
[ 0.294712] usbcore: registered new device driver usb
[ 0.297771] gpiochip_add_data: registered GPIOs 496 to 511 on device: tca9539
[ 0.299219] gpiochip_add_data: registered GPIOs 480 to 495 on device: tca9539
[ 0.302363] max77620 4-003c: PMIC Version OTP:0x3C and ES:0x8
[ 0.304309] GPIO line 474 (spmic-default-output-high) hogged as output/high
[ 0.304427] gpiochip_add_data: registered GPIOs 472 to 479 on device: max77620-gpio
[ 0.308349] vdd-core: 600 <--> 1400 mV at 1125 mV
[ 0.312343] vddio-ddr: at 1125 mV
[ 0.313195] vdd-pre-reg: 1350 mV
[ 0.316213] vdd-1v8: 1800 mV
[ 0.320215] avdd-sys: 1200 mV
[ 0.324213] vdd-pex: 1050 mV
[ 0.324838] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 0.325710] vdd-cam-hv: 2800 mV
[ 0.328213] vdd-rtc: 850 mV
[ 0.329066] avdd-ts-hv: 3300 mV
[ 0.329944] vdd-ts: 1800 mV
[ 0.332214] vdd-gen-pll-edp: 1050 mV
[ 0.336213] vdd-hdmi-dp: 1050 mV
[ 0.336860] max77620 4-003c: max77620 probe successful
[ 0.338731] media: Linux media interface: v0.10
[ 0.338803] Linux video capture interface: v2.00
[ 0.346211] tegra210-emc 7001b000.memory-controller: validated EMC DFS table
[ 0.346557] Advanced Linux Sound Architecture Driver Initialized.
[ 0.349320] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.349370] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.349454] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.349494] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.352426] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.356220] vdd-3v3: 3300 mV
[ 0.360215] max77620-gpio7: 1050 mV
[ 0.360525] lcd-bl-en: 1800 mV
[ 0.360822] en-vdd-sd: 3300 mV
[ 0.361497] en-vdd-cam: 1800 mV
[ 0.364215] vdd-sys-boost: 5000 mV
[ 0.364865] vdd-hdmi: 5000 mV
[ 0.365111] aux-3v3: 3300 mV
[ 0.365346] snsr_pm: 3300 mV
[ 0.368217] vdd-disp-3v0: 3000 mV
[ 0.368904] vdd-fan: 5000 mV
[ 0.369207] usb-vbus1: 5000 mV
[ 0.369845] en-vdd-ts-1v8: 1800 mV
[ 0.370491] en-vdd-ts-hv-3v3: 3300 mV
[ 0.371316] en-vdd-disp-3v3: 3300 mV
[ 0.371973] en-mdm-pwr-3v7: 3700 mV
[ 0.372819] en-vdd-disp-1v8: 1800 mV
[ 0.373462] en-vdd-cam-hv-2v8: 2800 mV
[ 0.373740] rtl-5v0: 5000 mV
[ 0.374027] en-usb-vbus2: 5000 mV
[ 0.374681] en-vdd-cam-1v2: 1200 mV
[ 0.374975] en-vdd-vcm-2v8: 2800 mV
[ 0.375634] en-vdd-cam-1v2-alt: 1200 mV
[ 0.378413] extcon-gpio-states extcon:extcon@1: Cable state 1
[ 0.379446] clocksource: Switched to clocksource arch_sys_counter
[ 0.423753] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.424120] nvmap_page_pool_init: Total RAM pages: 1019539
[ 0.424152] nvmap_page_pool_init: nvmap page pool size: 127442 pages (497 MB)
[ 0.424263] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.424439] misc nvmap: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.424574] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.425242] pnp: PnP ACPI: disabled
[ 0.437002] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.438818] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.439225] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.439423] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.441058] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
[ 0.441306] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
[ 0.441530] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 0.442798] isomgr_init(): iso emc max clk=1600000KHz
[ 0.442824] isomgr_init(): max_iso_bw=11520000KB
[ 0.442960] NET: Registered protocol family 2
[ 0.443567] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.443771] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.444033] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.444146] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.444213] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.444450] NET: Registered protocol family 1
[ 0.444765] RPC: Registered named UNIX socket transport module.
[ 0.444795] RPC: Registered udp transport module.
[ 0.444818] RPC: Registered tcp transport module.
[ 0.444840] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.445113] Trying to unpack rootfs image as initramfs...
[ 0.456085] host1x 50000000.host1x: initialized
[ 0.457444] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.460518] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.460643] audit: initializing netlink subsys (disabled)
[ 0.460702] audit: type=2000 audit(0.455:1): initialized
[ 0.472596] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.473078] fuse init (API version 7.23)
[ 0.475934] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.476074] io scheduler noop registered
[ 0.476106] io scheduler deadline registered
[ 0.476297] io scheduler cfq registered (default)
[ 0.481904] tegra21x-padctl-uphy 7009f000.pinctrl: padctl mmio start 0x000000007009f000 end 0x000000007009ffff
[ 0.481953] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_SKU_CALIB_0 0x9a49415
[ 0.481990] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_USB_CALIB_EXT_0 0x4
[ 0.483428] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-0 is used by XUSB
[ 0.483491] tegra21x-padctl-uphy 7009f000.pinctrl: using UTMI port 0 for otg
[ 0.483523] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-2 is used by XUSB
[ 0.483560] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 5, set usb3_lanes = 0x20
[ 0.483605] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 1 maps to USB2 port 2
[ 0.483640] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-1 is used by XUSB
[ 0.483675] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 6, set usb3_lanes = 0x60
[ 0.483717] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 0 maps to USB2 port 1
[ 0.483762] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 1, set pcie_lanes = 0x2
[ 0.483810] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 2, set pcie_lanes = 0x6
[ 0.483856] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 3, set pcie_lanes = 0xe
[ 0.483902] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 4, set pcie_lanes = 0x1e
[ 0.483948] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 0, set pcie_lanes = 0x1f
[ 0.483997] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 7, set sata_lanes = 0x80
[ 0.484424] tegra21x-padctl-uphy 7009f000.pinctrl: mailbox is not ready yet
[ 0.485443] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.486549] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.487276] Adding domain pcie-pd to PM domain mc-clk-pd
[ 0.492080] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 0.492150] tegra-pcie 1003000.pcie-controller: failed to get PHY: -517
[ 0.492178] tegra-pcie 1003000.pcie-controller: failed to get PHYs: -517
[ 0.495748] tsec 54500000.tsec: initialized
[ 0.496897] tsec 54100000.tsecb: initialized
[ 0.499521] nvdec 54480000.nvdec: initialized
[ 0.504470] falcon 54340000.vic: initialized
[ 0.505819] falcon 544c0000.nvenc: initialized
[ 0.506768] falcon 54380000.nvjpg: initialized
[ 0.508735] DC OR NODE connected to /host1x/sor1
[ 0.508831] display board info: id 0xffff, fab 0x0
[ 0.508887] panel_select fail by _node_status
[ 0.508947] display board info: id 0xffff, fab 0x0
[ 0.508995] panel_select fail by _node_status
[ 0.509022] generic_infoframe_type: 0x87
[ 0.509197] tegradc tegradc.1: DT parsed successfully
[ 0.509255] tegradc tegradc.1: Display dc.ffffff8000980000 registered with id=0
[ 0.510105] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.510293] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1020000, vi_iso_bw=750000, max_bw=1020000
[ 0.510985] display board info: id 0xffff, fab 0x0
[ 0.511037] panel_select fail by _node_status
[ 0.515130] tegra-i2c 7000c700.i2c: no acknowledge from address 0x50
[ 0.516380] tegradc tegradc.1: probed
[ 0.519616] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 0.521670] tegra-adma 702e2000.adma: Tegra ADMA driver register 10 channels
[ 0.523211] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 0.523567] kfuse 7000fc00.kfuse: initialized
[ 0.525555] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.526452] clk_cbus_round_rate: no gbus parent
[ 0.526482] tegra_gpu_edp gpu_edp: unable to get max GPU freq
[ 0.527001] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 0.527037] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 0.527105] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 0.528393] vdd-gpu: applied init 1000000uV constraint
[ 0.528426] vdd-gpu: 710 <--> 1320 mV at 1000 mV
[ 0.528489] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 0.528928] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.529057] No Device Node present for smmu client: serial8250 !!
[ 0.529086] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.529129] No Device Node present for smmu client: serial8250 !!
[ 0.529155] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.530251] No Device Node present for smmu client: serial8250 !!
[ 0.530285] serial8250 serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.530334] No Device Node present for smmu client: serial8250 !!
[ 0.530362] serial8250 serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.531029] console [ttyS0] disabled
[ 0.531102] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 320, base_baud = 25500000) is a Tegra
[ 2.474342] console [ttyS0] enabled
[ 2.475695] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 321, base_baud = 0) is a TEGRA_UART
[ 2.476145] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 322, base_baud = 0) is a TEGRA_UART
[ 2.476471] serial-tegra 70006300.serial: RX in PIO mode
[ 2.476572] 70006300.serial: ttyTHS3 at MMIO 0x70006300 (irq = 323, base_baud = 0) is a TEGRA_UART
[ 2.478085] Console: switching to colour frame buffer device 80x30
[ 2.478844] gk20a 57000000.gpu: platform probe failed
[ 2.489159] brd: module loaded
[ 2.494773] loop: module loaded
[ 2.495458] zram: Added device: zram0
[ 2.495469] Silicon Labs C2 port support v. 0.51.0 - (C) 2007 Rodolfo Giometti
[ 2.495678] nct1008_nct72 0-004c: find device tree node, parsing dt
[ 2.495682] nct1008_nct72 0-004c: starting parse dt
[ 2.495754] nct1008_nct72 0-004c: success parsing dt
[ 2.496002] nct1008_nct72 0-004c: success in enabling tmp451 VDD rail
[ 2.612665] tegradc tegradc.1: fb registered
[ 2.623254] tmp451: Enabled overheat logging at 102.00C
[ 2.630709] nct1008_nct72 0-004c: nct1008_probe: initialized
[ 2.641055] THERMAL EST: found 2 subdevs
[ 2.647067] THERMAL EST num_resources: 0
[ 2.652985] [THERMAL EST subdev 0]
[ 2.658366] [THERMAL EST subdev 1]
[ 2.663997] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 2.676697] THERMAL EST: thz register success.
[ 2.683112] THERMAL EST: end of probe, return err: 0
[ 2.689964] tegra_profiler: Branch: Dev
[ 2.695565] tegra_profiler: Version: 1.117
[ 2.701343] tegra_profiler: Samples version: 41
[ 2.707502] tegra_profiler: IO version: 22
[ 2.713180] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.719111] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.730554] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.736565] armv8_pmu: [1] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.747984] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.754002] armv8_pmu: [2] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.765629] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.771737] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.783643] tegra_profiler: auth: init
[ 2.789681] tegra-ahci 70027000.sata: Missing devslp-active state
[ 2.798579] Rounding down aligned max_sectors from 4294967295 to 4294967288
[ 2.807991] spi-tegra114 7000d400.spi: Static pin configuration used
[ 2.817146] spi-tegra114 7000da00.spi: Static pin configuration used
[ 2.826837] tun: Universal TUN/TAP device driver, 1.6
[ 2.833780] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.842277] PPP generic driver version 2.4.2
[ 2.848609] PPP BSD Compression module registered
[ 2.855218] PPP Deflate Compression module registered
[ 2.862223] PPP MPPE Compression module registered
[ 2.868979] NET: Registered protocol family 24
[ 2.875480] usbcore: registered new interface driver r8152
[ 2.883027] usbcore: registered new interface driver asix
[ 2.890434] usbcore: registered new interface driver ax88179_178a
[ 2.898450] usbcore: registered new interface driver cdc_ether
[ 2.906168] usbcore: registered new interface driver smsc95xx
[ 2.913730] usbcore: registered new interface driver net1080
[ 2.921114] usbcore: registered new interface driver cdc_subset
[ 2.928717] usbcore: registered new interface driver zaurus
[ 2.935939] usbcore: registered new interface driver cdc_ncm
[ 2.943212] usbcore: registered new interface driver cdc_acm
[ 2.950321] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.961235] usbcore: registered new interface driver usb-storage
[ 2.968829] usbcore: registered new interface driver usbserial
[ 2.976135] usbcore: registered new interface driver ftdi_sio
[ 2.983267] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.993321] usbcore: registered new interface driver option
[ 3.000361] usbserial: USB Serial support registered for GSM modem (1-port)
[ 3.008839] usbcore: registered new interface driver pl2303
[ 3.015901] usbserial: USB Serial support registered for pl2303
[ 3.024342] tegra-xudc-new 700d0000.xudc: usb2 phy is not available yet
[ 3.168185] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc1
[ 3.180955] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc0
[ 3.189792] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 3.198126] i2c /dev entries driver
[ 3.205488] IR NEC protocol handler initialized
[ 3.211794] IR Sharp protocol handler initialized
[ 3.218297] IR XMP protocol handler initialized
[ 3.224719] usbcore: registered new interface driver uvcvideo
[ 3.232358] USB Video Class driver (1.1.1)
[ 3.238656] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.249480] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 3.258675] tegra_soctherm 700e2000.soctherm: pllx_offset tz:1 max:8, min:4
[ 3.268210] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 3.281088] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 3.294365] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.308013] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 3.321371] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 3.334973] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.348859] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature 2147483647 forced to 127000
[ 3.362578] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 3.376241] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 3.389356] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 3.400478] tegra_aotag tegra-aotag: Registering sensor 0
[ 3.408533] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 3.416296] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 3.425174] FAN dev name: pwm-fan
[ 3.430964] FAN:gpio request success.
[ 3.437144] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.445606] pwm_fan_driver pwm-fan: got pwm for fan
[ 3.453056] pwm_fan_driver pwm-fan: fan tach request irq success
[ 3.461457] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.468888] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.480890] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.493062] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.505322] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.517579] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.530050] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.542335] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.554616] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.566914] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.579539] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.593437] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 3.607259] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 3.621040] device-mapper: uevent: version 1.0.3
[ 3.628743] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 3.649032] sdhci: Secure Digital Host Controller Interface driver
[ 3.657971] sdhci: Copyright(c) Pierre Ossman
[ 3.665004] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.673954] sdhci-tegra sdhci-tegra.3: Parent select= pll_p rate=408000000
[ 3.676860] tegra-se 70012000.se: tegra_se_probe: complete
[ 3.677489] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.680299] usbcore: registered new interface driver usbhid
[ 3.680302] usbhid: USB HID core driver
[ 3.714101] sdhci-tegra sdhci-tegra.3: Parent select= pll_c4_out2 rate=199680000
[ 3.726417] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[ 3.740257] parse_throttle_dt_data: Num cap clks = 6
[ 3.747695] parse_throttle_dt_data: clk=cclk_g type=2
[ 3.755113] parse_throttle_dt_data: clk=gpu type=4
[ 3.762216] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 3.770566] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 3.771479] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[ 3.771827] sdhci-tegra sdhci-tegra.1: Parent select= pll_p rate=408000000
[ 3.771848] sdhci-tegra sdhci-tegra.1: Client registration for eMC Successful
[ 3.810513] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 3.814087] mmc0: MAN_BKOPS_EN bit is not set
[ 3.815479] mmc1: SDHCI controller on sdhci-tegra.1 [sdhci-tegra.1] using ADMA 64-bit with 64 bit addr
[ 3.816191] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 3.816242] sdhci-tegra sdhci-tegra.0: Got WP GPIO
[ 3.816324] sdhci-tegra sdhci-tegra.0: Parent select= pll_p rate=408000000
[ 3.816372] sdhci-tegra sdhci-tegra.0: wakeup init done, cd_irq: 262
[ 3.816393] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 3.818420] en-vdd-sd: supplied by vdd-3v3
[ 3.821714] mmc0: Skipping tuning since strobe enabled
[ 3.827704] mmc0: new HS400 MMC card at address 0001
[ 3.827967] mmcblk mmc0:0001: Card claimed for testing.
[ 3.828582] mmcblk0: mmc0:0001 016G32 14.7 GiB
[ 3.829093] mmcblk0rpmb: mmc0:0001 016G32 partition 3 4.00 MiB
[ 3.830701] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19
[ 3.855639] mmc2: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 3.868658] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 3.951621] parse_throttle_dt_data: clk=emc type=3
[ 3.959291] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.967288] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 3.976687] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 3.990678] tegra124-dfll 70110000.clock: config PMU interface as PWM
[ 4.001496] coresight-tmc 72030000.etf: TMC initialized
[ 4.010036] coresight-tmc 72050000.etr: TMC initialized
[ 4.017427] coresight-tpiu 72060000.tpiu: TPIU initialized
[ 4.025290] coresight-funnel 73010000.funnel_bccplex: FUNNEL initialized
[ 4.034339] coresight-funnel 72010000.funnel_major: FUNNEL initialized
[ 4.043523] coresight-replicator 72040000.replicator: REPLICATOR initialized
[ 4.053395] coresight-etm4x 73440000.ptm: ETM 4.0 initialized
[ 4.062657] coresight-etm4x 73540000.ptm: ETM 4.0 initialized
[ 4.071025] coresight-etm4x 73640000.ptm: ETM 4.0 initialized
[ 4.072676] mmc1 tuning done saved tap delay=72
[ 4.072679] mmc1: hw tuning done ...
[ 4.072686] mmc1: tuning_window[0]: 0xfe7fffff
[ 4.072691] mmc1: tuning_window[1]: 0xfe7fffff
[ 4.072697] mmc1: tuning_window[2]: 0xfcffffff
[ 4.072702] mmc1: tuning_window[3]: 0x7cffffff
[ 4.072708] mmc1: tuning_window[4]: 0x0
[ 4.072713] mmc1: tuning_window[5]: 0x0
[ 4.072719] mmc1: tuning_window[6]: 0x0
[ 4.072724] mmc1: tuning_window[7]: 0x0
[ 4.072727] sdhci: Tap value: 72 | Trim value: 8
[ 4.072731] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 4.078198] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 4.078243] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 4.168233] coresight-etm4x 73740000.ptm: ETM 4.0 initialized
[ 4.176722] usbcore: registered new interface driver snd-usb-audio
[ 4.184273] No Device Node present for smmu client: snd-soc-dummy !!
[ 4.191958] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 4.207246] No Device Node present for smmu client: snd-soc-dummy !!
[ 4.207380] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 4.225773] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 4.238796] No Device Node present for smmu client: snd-soc-dummy !!
[ 4.246843] snd-soc-dummy snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 4.260362] No Device Node present for smmu client: snd-soc-dummy !!
[ 4.268633] snd-soc-dummy snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 4.305266] tegra210-i2s tegra210-i2s.0: Missing prop fsync-width for I2S0
[ 4.316202] tegra210-i2s tegra210-i2s.2: Missing prop fsync-width for I2S2
[ 4.325945] tegra210-i2s tegra210-i2s.3: Missing prop fsync-width for I2S3
[ 4.335842] tegra210-i2s tegra210-i2s.4: Missing prop fsync-width for I2S4
[ 4.358120] OPE platform probe
[ 4.363598] OPE platform probe successful
[ 4.370187] OPE platform probe
[ 4.375601] OPE platform probe successful
[ 4.416401] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 4.428252] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 4.440197] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 4.452171] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 4.464171] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 4.476203] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 4.488265] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 4.500324] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 4.512413] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 4.524649] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 4.561911] input: tegra-snd-t210ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input1
[ 4.576963] tegra-snd-t210ref-mobile-rt565x sound: codec-dai "dit-hifi" registered
[ 4.590014] tegra-snd-t210ref-mobile-rt565x sound: This is a dummy codec
[ 4.600400] GACT probability NOT on
[ 4.606690] Mirror/redirect action on
[ 4.613082] u32 classifier
[ 4.618440] Actions configured
[ 4.624429] Netfilter messages via NETLINK v0.30.
[ 4.631728] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 4.640793] ctnetlink v0.93: registering with nfnetlink.
[ 4.649404] xt_time: kernel timezone is -0000
[ 4.656245] IPVS: Registered protocols ()
[ 4.662640] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 4.674708] IPVS: Creating netns size=1424 id=0
[ 4.681575] IPVS: ipvs loaded.
[ 4.686872] IPVS: [rr] scheduler registered.
[ 4.693491] ipip: IPv4 over IPv4 tunneling driver
[ 4.700967] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.708549] arp_tables: (C) 2002 David S. Miller
[ 4.715291] Initializing XFRM netlink socket
[ 4.722253] NET: Registered protocol family 10
[ 4.729695] mip6: Mobile IPv6
[ 4.734575] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 4.742060] sit: IPv6 over IPv4 tunneling driver
[ 4.749556] NET: Registered protocol family 17
[ 4.755782] NET: Registered protocol family 15
[ 4.761916] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 4.777994] Key type dns_resolver registered
[ 4.784767] Registered cp15_barrier emulation handler
[ 4.800080] isp 54600000.isp: initialized
[ 4.807186] isp 54680000.isp: initialized
[ 4.817006] clk_cbus_recalc_rate: no gbus parent
[ 4.823400] clk_cbus_round_rate: no gbus parent
[ 4.829622] clk_cbus_round_rate: no gbus parent
[ 4.835798] clk_cbus_recalc_rate: no gbus parent
[ 4.842530] clk_cbus_recalc_rate: no gbus parent
[ 4.848659] clk_cbus_round_rate: no gbus parent
[ 4.854661] clk_cbus_round_rate: no gbus parent
[ 4.860650] clk_cbus_recalc_rate: no gbus parent
[ 4.866737] tegra_dvfs: GPU-cap: registered
[ 4.872439] tegra dvfs: vdd-cpu: nominal 1226mV, offset 708000uV, step 19200uV, scaling enabled
[ 4.884038] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[ 4.895961] tegra dvfs: vdd-gpu: nominal 1130mV, offset 710000uV, step 10000uV, scaling enabled
[ 4.910410] tegra_dvfs: vdd-gpu-vts: registered
[ 4.918530] xhci-tegra 70090000.xusb: can't get usb3-0 phy (-517)
[ 4.927071] tegra21x-padctl-uphy 7009f000.pinctrl: padctl mmio start 0x000000007009f000 end 0x000000007009ffff
[ 4.940701] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_SKU_CALIB_0 0x9a49415
[ 4.951953] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_USB_CALIB_EXT_0 0x4
[ 4.964561] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-0 is used by XUSB
[ 4.973466] tegra21x-padctl-uphy 7009f000.pinctrl: using UTMI port 0 for otg
[ 4.982597] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-2 is used by XUSB
[ 4.991454] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 5, set usb3_lanes = 0x20
[ 5.003579] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 1 maps to USB2 port 2
[ 5.015608] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-1 is used by XUSB
[ 5.024811] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 6, set usb3_lanes = 0x60
[ 5.037561] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 0 maps to USB2 port 1
[ 5.049991] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 1, set pcie_lanes = 0x2
[ 5.062803] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 2, set pcie_lanes = 0x6
[ 5.075594] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 3, set pcie_lanes = 0xe
[ 5.088494] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 4, set pcie_lanes = 0x1e
[ 5.101578] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 0, set pcie_lanes = 0x1f
[ 5.114621] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 7, set sata_lanes = 0x80
[ 5.128331] usb-vbus1: supplied by vdd-3v3
[ 5.137324] tegra21x-padctl-uphy 7009f000.pinctrl: Done tegra21x_padctl_uphy_probe
[ 5.152782] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 5.162237] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 5.172043] clk_cbus_round_rate: no gbus parent
[ 5.179389] tegra_gpu_edp gpu_edp: unable to get max GPU freq
[ 5.188330] tegra-ahci 70027000.sata: Missing devslp-active state
[ 5.190054] gk20a 57000000.gpu: GPCPLL initial settings: NA mode, M=1, N=34, P=3
[ 5.192339] gk20a 57000000.gpu: failed to allocate secure buffer -12
[ 5.218531] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes
[ 5.219508] tegra-ahci 70027000.sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 5.219519] tegra-ahci 70027000.sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 5.224907] scsi host0: tegra_ahci
[ 5.229532] scsi host1: tegra_ahci
[ 5.229765] ata1: SATA max UDMA/133 mmio [mem 0x70027000-0x70028fff] port 0x100 irq 370
[ 5.229768] ata2: DUMMY
[ 5.232899] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 5.232980] tegra-xudc-new 700d0000.xudc: device mode on
[ 5.285488] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 5.302490] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 5.302896] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 5.328873] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 5.330740] tegra124-dfll 70110000.clock: entered closed loop mode
[ 5.333116] xhci-tegra 70090000.xusb: UTMI port 0 has OTG_CAP
[ 5.333118] xhci-tegra 70090000.xusb: No USB3 port has OTG_CAP
[ 5.335259] xhci-tegra 70090000.xusb: Direct firmware load for tegra21x_xusb_firmware failed with error -2
[ 5.335262] xhci-tegra 70090000.xusb: Falling back to user helper
[ 5.390519] input: gpio-keys as /devices/gpio-keys/input/input2
[ 5.391526] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes
[ 5.439185] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:05:35 UTC (946688735)
[ 5.450532] vi 54080000.vi: vi_probe: ++
[ 5.464061] vi 54080000.vi: initialized
[ 5.473535] vi 54080000.vi: ep of_device is not enabled /host1x/vi/ports/port@0/endpoint.
[ 5.483490] vi 54080000.vi: ep of_device is not enabled /host1x/vi/ports/port@1/endpoint.
[ 5.493506] vi 54080000.vi: ep of_device is not enabled /host1x/vi/ports/port@2/endpoint.
[ 5.503561] vi 54080000.vi: ep of_device is not enabled /host1x/vi/ports/port@3/endpoint.
[ 5.513611] vi 54080000.vi: all channel register failed
[ 5.520684] Disable partitions left on by BL
[ 5.525876] disb
[ 5.540537] DRAM derating cdev registered.
[ 5.546264] vdd-cpu-fixed: disabling
[ 5.547525] ata1: SATA link down (SStatus 0 SControl 300)
[ 5.556963] vdd-cam-hv: disabling
[ 5.561210] avdd-ts-hv: disabling
[ 5.565432] vdd-ts: disabling
[ 5.569275] max77620-gpio7: disabling
[ 5.574010] lcd-bl-en: disabling
[ 5.577955] en-vdd-sd: disabling
[ 5.581923] en-vdd-cam: disabling
[ 5.585955] aux-3v3: disabling
[ 5.589694] snsr_pm: disabling
[ 5.593415] vdd-disp-3v0: disabling
[ 5.597580] vdd-fan: disabling
[ 5.601290] usb-vbus1: disabling
[ 5.605147] en-vdd-ts-1v8: disabling
[ 5.609326] en-vdd-ts-hv-3v3: disabling
[ 5.613735] en-vdd-disp-3v3: disabling
[ 5.618285] en-mdm-pwr-3v7: disabling
[ 5.622426] en-vdd-disp-1v8: disabling
[ 5.626919] en-vdd-cam-hv-2v8: disabling
[ 5.631268] rtl-5v0: disabling
[ 5.634764] en-usb-vbus2: disabling
[ 5.638683] en-vdd-cam-1v2: disabling
[ 5.642773] en-vdd-vcm-2v8: disabling
[ 5.646849] en-vdd-cam-1v2-alt: disabling
[ 5.652513] ALSA device list:
[ 5.655867] #0: tegra-hda at 0x70038000 irq 348
[ 5.660971] #1: tegra-snd-t210ref-mobile-rt565x
[ 5.667469] EXT4-fs (mmcblk0p1): couldn't mount as ext3 due to feature incompatibilities
[ 5.677452] EXT4-fs (mmcblk0p1): couldn't mount as ext2 due to feature incompatibilities
[ 5.691780] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.701024] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 5.710009] devtmpfs: mounted
[ 5.713923] Freeing unused kernel memory: 1208K (ffffffc001168000 - ffffffc001296000)
[ 5.723105] Freeing alternatives memory: 76K (ffffffc001296000 - ffffffc0012a9000)
[ 5.740407] btb inv war enabled
[ 5.791392] systemd[1]: System time before build time, advancing clock.
[ 5.815475] random: systemd: uninitialized urandom read (16 bytes read, 57 bits of entropy available)
[ 5.828657] random: systemd: uninitialized urandom read (16 bytes read, 57 bits of entropy available)
[ 5.839625] random: systemd: uninitialized urandom read (16 bytes read, 57 bits of entropy available)
[ 5.851925] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 5.873272] systemd[1]: Detected architecture arm64.
[ 5.879276] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 5.894670] systemd[1]: Set hostname to <tegra-ubuntu>.
[ 5.910536] random: systemd: uninitialized urandom read (16 bytes read, 59 bits of entropy available)
[ 5.914100] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 59 bits of entropy available)
[ 5.915498] random: systemd-cryptse: uninitialized urandom read (16 bytes read, 60 bits of entropy available)
[ 5.917552] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 60 bits of entropy available)
[ 5.917646] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 60 bits of entropy available)
[ 5.917667] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 60 bits of entropy available)
[ 5.917801] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 60 bits of entropy available)
[ 6.109780] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 6.118660] systemd[1]: Reached target Encrypted Volumes.
[ 6.126385] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.134445] systemd[1]: Reached target Remote File Systems (Pre).
[ 6.142759] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.153733] systemd[1]: Listening on Journal Audit Socket.
[ 6.161490] systemd[1]: Listening on udev Control Socket.
[ 6.169060] systemd[1]: Reached target Swap.
[ 6.175489] systemd[1]: Listening on LVM2 poll daemon socket.
[ 6.183422] systemd[1]: Listening on Syslog Socket.
[ 6.190327] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 6.198410] systemd[1]: Reached target Remote File Systems.
[ 6.206098] systemd[1]: Created slice User and Session Slice.
[ 6.213929] systemd[1]: Created slice System Slice.
[ 6.220740] systemd[1]: Reached target Slices.
[ 6.227197] systemd[1]: Created slice system-getty.slice.
[ 6.234577] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 6.242816] systemd[1]: Listening on udev Kernel Socket.
[ 6.250025] systemd[1]: Listening on Journal Socket.
[ 6.257708] systemd[1]: Starting Journal Service...
[ 6.268968] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 6.278724] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 6.293201] systemd[1]: Mounting POSIX Message Queue File System...
[ 6.302784] systemd[1]: Started Braille Device Support.
[ 6.311495] systemd[1]: Mounting Debug File System...
[ 6.334117] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 6.335052] systemd[1]: Starting Load Kernel Modules...
[ 6.349119] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 6.361594] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 6.372423] systemd[1]: Reached target User and Group Name Lookups.
[ 6.383769] systemd[1]: Mounted POSIX Message Queue File System.
[ 6.391999] systemd[1]: Mounted Debug File System.
[ 6.399103] systemd[1]: Started Journal Service.
[ 6.479459] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 6.535508] systemd-journald[205]: Received request to flush runtime journal from PID 1
[ 6.736421] xhci-tegra 70090000.xusb: cannot find firmware....retry after 1 second
[ 6.871860] cfg80211: World regulatory domain updated:
[ 6.882840] cfg80211: DFS Master region: unset
[ 6.891455] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 6.895512] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 6.895516] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.895518] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.895520] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.895523] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 6.895526] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 6.895528] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 6.895530] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.895532] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 6.995458] tegra-pcie 1003000.pcie-controller: link 0 down, ignoring
[ 7.087503] dhd_module_init in
[ 7.087718] found wifi platform device bcmdhd_wlan
[ 7.099343] Power-up adapter 'DHD generic adapter'
[ 7.099364] wifi_platform_set_power = 1
[ 7.296679] random: nonblocking pool is initialized
[ 7.303492] wifi_platform_bus_enumerate device present 1
[ 7.327597] wifi_platform_bus_enumerate device present 0
[ 7.334374] F1 signature read @0x18000000=0x17214354
[ 7.347019] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 7.347661] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 7.347729] wifi_platform_prealloc: failed to alloc static mem section 7
[ 7.347735] wifi_platform_get_mac_addr
[ 7.362355] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 7.363162] wl_create_event_handler(): thread:wl_event_handler:1d4 started
[ 7.363170] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc079b61a70
[ 7.363261] dhd_attach(): thread:dhd_watchdog_thread:1d5 started
[ 7.363291] dhd_attach(): thread:dhd_dpc:1d6 started
[ 7.363317] dhd_attach(): thread:dhd_rxf:1d7 started
[ 7.363321] dhd_deferred_work_init: work queue initialized
[ 7.363577] Dongle Host Driver, version 1.201.82 (r)
[ 7.363577] Compiled in drivers/net/wireless/bcmdhd on Mar 1 2018 at 20:43:08
[ 7.363875] tegra_sysfs_register
[ 7.363905] Register interface [wlan0] MAC: 00:04:4b:8e:a7:f9
[ 7.363905]
[ 7.363908] dhd_prot_ioctl : bus is down. we have nothing to do
[ 7.364018] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 72
[ 7.365061] wifi_platform_set_power = 0
[ 7.431449] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 7.556539] using random self ethernet address
[ 7.561986] using random host ethernet address
[ 7.593162] Mass Storage Function, version: 2009/09/11
[ 7.602954] LUN: removable file: (no medium)
[ 7.614469] using random self ethernet address
[ 7.619870] using random host ethernet address
[ 7.630785] usb0: HOST MAC 2a:84:ec:e7:46:dc
[ 7.635904] usb0: MAC ba:d8:0c:88:68:39
[ 7.641428] usb1: HOST MAC 6e:15:e5:71:f3:0d
[ 7.646537] usb1: MAC f6:0b:5b:4d:2d:5a
[ 7.651187] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 7.675681] device usb0 entered promiscuous mode
[ 7.692003] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 7.703220] device usb1 entered promiscuous mode
[ 7.713410] IPv6: ADDRCONF(NETDEV_UP): usb1: link is not ready
[ 7.713415] l4tbr0: port 2(usb1) entered forwarding state
[ 7.713429] l4tbr0: port 2(usb1) entered forwarding state
[ 7.751138] xhci-tegra 70090000.xusb: Firmware timestamp: 2017-10-20 11:40:00 UTC, Version: 50.19 release
[ 7.767807] xhci-tegra 70090000.xusb: xHCI Host Controller
[ 7.779413] xhci-tegra 70090000.xusb: new USB bus registered, assigned bus number 1
[ 7.792894] xhci-tegra 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00010810
[ 7.804203] xhci-tegra 70090000.xusb: irq 319, io mem 0x70090000
[ 7.811530] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 7.820798] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.830112] usb usb1: Product: xHCI Host Controller
[ 7.836070] usb usb1: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 7.843002] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 7.854498] usb usb1: SerialNumber: 70090000.xusb
[ 7.854860] hub 1-0:1.0: USB hub found
[ 7.854885] hub 1-0:1.0: 5 ports detected
[ 7.861677] android_work: did not send uevent (0 0 (null))
[ 7.871483] xhci-tegra 70090000.xusb: xHCI Host Controller
[ 7.871490] xhci-tegra 70090000.xusb: new USB bus registered, assigned bus number 2
[ 7.871604] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 7.871607] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.871610] usb usb2: Product: xHCI Host Controller
[ 7.871612] usb usb2: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 7.871614] usb usb2: SerialNumber: 70090000.xusb
[ 7.871904] hub 2-0:1.0: USB hub found
[ 7.871923] hub 2-0:1.0: 4 ports detected
[ 7.917017] android_work: did not send uevent (0 0 (null))
[ 7.968134] android_work: sent uevent USB_STATE=CONNECTED
[ 7.975600] android_work: sent uevent USB_STATE=DISCONNECTED
[ 8.023598] android_work: did not send uevent (0 0 (null))
[ 8.097129] android_work: sent uevent USB_STATE=CONNECTED
[ 8.103417] configfs-gadget gadget: high-speed config #1: c
[ 8.103440] tegra-xudc-new 700d0000.xudc: ep 5 (type: 3, dir: in) enabled
[ 8.103457] tegra-xudc-new 700d0000.xudc: ep 3 (type: 2, dir: in) enabled
[ 8.103473] tegra-xudc-new 700d0000.xudc: ep 2 (type: 2, dir: out) enabled
[ 8.103595] tegra-xudc-new 700d0000.xudc: ep 9 (type: 3, dir: in) enabled
[ 8.103612] tegra-xudc-new 700d0000.xudc: ep 7 (type: 2, dir: in) enabled
[ 8.103627] tegra-xudc-new 700d0000.xudc: ep 4 (type: 2, dir: out) enabled
[ 8.103665] tegra-xudc-new 700d0000.xudc: ep 15 (type: 3, dir: in) enabled
[ 8.104612] tegra-xudc-new 700d0000.xudc: ep 11 (type: 2, dir: in) enabled
[ 8.104628] tegra-xudc-new 700d0000.xudc: ep 6 (type: 2, dir: out) enabled
[ 8.126427] tegra-xudc-new 700d0000.xudc: setup request failed: -95
[ 8.179488] usb 1-3: new high-speed USB device number 2 using xhci-tegra
[ 8.188074] usb 2-1: new SuperSpeed USB device number 2 using xhci-tegra
[ 8.203000] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 8.210181] l4tbr0: port 1(usb0) entered forwarding state
[ 8.210202] l4tbr0: port 1(usb0) entered forwarding state
[ 8.210253] android_work: sent uevent USB_STATE=CONFIGURED
[ 8.212024] usb 2-1: New USB device found, idVendor=0955, idProduct=09ff
[ 8.212027] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 8.212029] usb 2-1: Product: USB 10/100/1000 LAN
[ 8.212031] usb 2-1: Manufacturer: Nvidia
[ 8.212033] usb 2-1: SerialNumber: 000001000000
[ 8.212113] tegra-xudc-new 700d0000.xudc: ep 13 (type: 2, dir: in) enabled
[ 8.212129] tegra-xudc-new 700d0000.xudc: ep 8 (type: 2, dir: out) enabled
[ 8.213075] IPv6: ADDRCONF(NETDEV_CHANGE): usb1: link becomes ready
[ 8.213167] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 6
[ 8.213401] usb 1-3: feature bit otg_vbus_off set
[ 8.213406] usb 1-3: New USB device found, idVendor=05e3, idProduct=0610
[ 8.213409] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.213411] usb 1-3: Product: USB2.1 Hub
[ 8.213413] usb 1-3: Manufacturer: GenesysLogic
[ 8.214336] hub 1-3:1.0: USB hub found
[ 8.214612] hub 1-3:1.0: 4 ports detected
[ 8.218430] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 6
[ 8.328094] usb 2-2: new SuperSpeed USB device number 3 using xhci-tegra
[ 8.346513] usb 2-2: feature bit otg_vbus_off set
[ 8.346518] usb 2-2: New USB device found, idVendor=05e3, idProduct=0620
[ 8.346521] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.346523] usb 2-2: Product: USB3.1 Hub
[ 8.346525] usb 2-2: Manufacturer: GenesysLogic
[ 8.348644] hub 2-2:1.0: USB hub found
[ 8.348977] hub 2-2:1.0: 4 ports detected
[ 8.441470] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 8.451078] tegra-pcie 1003000.pcie-controller: link 1 down, ignoring
[ 8.458589] tegra-pcie 1003000.pcie-controller: PCIE: no end points detected
[ 8.461358] IPVS: Creating netns size=1424 id=1
[ 8.472056] usb 2-1: reset SuperSpeed USB device number 2 using xhci-tegra
[ 8.473278] tegra-pcie 1003000.pcie-controller: PCIE: Disable power rails
[ 8.512966] r8152 2-1:1.0 eth0: v2.09.00 (2017/08/21)
[ 8.512970] r8152 2-1:1.0 eth0: This product is covered by one or more of the following patents:
[ 8.512970] US6,570,884, US6,115,776, and US6,327,625.
[ 8.512970]
[ 8.527472] usb 1-3.1: new high-speed USB device number 3 using xhci-tegra
[ 8.534191] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.534287]
[ 8.534287] Dongle Host Driver, version 1.201.82 (r)
[ 8.534287] Compiled in drivers/net/wireless/bcmdhd on Mar 1 2018 at 20:43:08
[ 8.534288] wl_android_wifi_on in
[ 8.534290] wifi_platform_set_power = 1
[ 8.547101] usb 1-3.1: New USB device found, idVendor=8564, idProduct=4100
[ 8.547105] usb 1-3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.547108] usb 1-3.1: Product: USB2.0 Hub
[ 8.547110] usb 1-3.1: Manufacturer: Transcend Info
[ 8.548240] hub 1-3.1:1.0: USB hub found
[ 8.548539] hub 1-3.1:1.0: 4 ports detected
[ 8.797122] tegradc tegradc.1: blank - normal
[ 8.809189] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 8.831464] usb 1-3.1.1: new high-speed USB device number 4 using xhci-tegra
[ 8.895343] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 72
[ 8.904425] F1 signature read @0x18000000=0x17214354
[ 8.913495] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 8.920629] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 8.993790] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 9.031803] usb 1-3.1.1: New USB device found, idVendor=07ca, idProduct=1a01
[ 9.041279] usb 1-3.1.1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 9.043126] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 9.044000] wifi_platform_get_mac_addr
[ 9.045597] Firmware up: op_mode=0x0005, MAC=00:04:4b:8e:a7:f9
[ 9.050722] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 9.054931] Firmware version = wl0: Dec 12 2017 15:09:35 version 7.35.221.34 (r679642) FWID 01-8f1f4763
[ 9.057058] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 9.057225] tegra_sysfs_on
[ 9.093640] usb 1-3.1.1: Product: AVerMedia PW310 Webcam
[ 9.098997] usb 1-3.1.1: Manufacturer: Generic
[ 9.103528] usb 1-3.1.1: SerialNumber: 200901010001
[ 9.113642] uvcvideo: Found UVC 1.00 device AVerMedia PW310 Webcam (07ca:1a01)
[ 9.133029] input: AVerMedia PW310 Webcam as /devices/70090000.xusb/usb1/1-3/1-3.1/1-3.1.1/1-3.1.1:1.0/input/input3
[ 9.143503] tegradc tegradc.1: unblank
[ 9.383322] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if : P2P interface registered
[ 9.414345] WLC_E_IF: NO_IF set, event Ignored
[ 9.420755] usb 2-2-port1: Cannot enable. Maybe the USB cable is bad?
[ 10.108384] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 17
[ 10.115717] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 18
[ 10.408238] tegradc tegradc.1: unblank
[ 11.605501] tegradc tegradc.1: blank - powerdown
