Jetson AGX Xavier operating temperature
What is the lowest operating temperature of xavier module?
In spec description, the low temperature is -25°C, but our test result is - 24°C. The module is failed to work at -25°C. We want to make sure the accurate operating temperature, thanks.
It is -25C as spec listed. What’s the temperature value read from thermal zone when it failed? It might have tolerance at the point.
The following is the log, please help to check is there any information about temperature below -25°C, or other reasons that make xavier failed to startup, thanks.
\0\0\0?
[0000.096] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.104] I> MB1 (prd-version: 1.5.1.6-t194-41334769-1740dd39)
[0000.109] I> Boot-mode: Coldboot
[0000.112] I> Chip revision : A02P
[0000.115] I> Bootrom patch version : 15 (correctly patched)
[0000.121] I> ATE fuse revision : 0x200
[0000.124] I> Ram repair fuse : 0x0
[0000.127] I> Ram Code : 0x2
[0000.130] I> rst_source : 0x0
[0000.132] I> rst_level : 0x0
[0000.136] I> Boot-device: eMMC
[0000.151] I> sdmmc DDR50 mode
[0000.155] W> No valid slot number is found in scratch register
[0000.161] W> Return default slot: _a
[0000.164] I> Active Boot chain : 0
[0000.167] I> Boot-device: eMMC
[0000.171] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.178] I> Temperature = 31500
[0000.181] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.186] W> Skipping boost for clk: BPMP_APB
[0000.190] W> Skipping boost for clk: AXI_CBB
[0000.194] W> Skipping boost for clk: AON_CPU_NIC
[0000.198] W> Skipping boost for clk: CAN1
[0000.202] W> Skipping boost for clk: CAN2
[0000.206] I> Boot-device: eMMC
[0000.209] I> Boot-device: eMMC
[0000.218] I> Sdmmc: HS400 mode enabled
[0000.223] I> ECC region[0]: Start:0x0, End:0x0
[0000.227] I> ECC region[1]: Start:0x0, End:0x0
[0000.231] I> ECC region[2]: Start:0x0, End:0x0
[0000.235] I> ECC region[3]: Start:0x0, End:0x0
[0000.239] I> ECC region[4]: Start:0x0, End:0x0
[0000.243] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.249] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.254] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.258] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.262] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.268] E> FAILED: Thermal config
[0000.275] E> FAILED: MEMIO rail config
[0000.293] I> Boot-device: eMMC
[0000.303] I> sdmmc bdev is already initialized
[0000.377] I> MB1 done
\0?鄊ain enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.385] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-feba5943)
[0000.386] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.386] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.387] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.393] W> device prod register failed
[0000.397] I> Boot-device: eMMC
[0000.399] I> Boot_device: SDMMC_BOOT instance: 3
[0000.405] I> sdmmc-3 params source = boot args
[0000.408] I> sdmmc bdev is already initialized
[0000.412] I> sdmmc-3 params source = boot args
[0000.421] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.427] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.428] W> No valid slot number is found in scratch register
[0000.433] W> Return default slot: _a
[0000.437] I> Active Boot chain : 0
[0000.440] I> parsing oem signed section of bpmp-fw header done
[0000.446] I> bpmp-fw binary init read from storage
[0000.451] I> oem authentication of bpmp-fw header done
[0000.457] I> bpmp-fw binary done read from storage
[0000.460] I> bpmp-fw: Authentication init Done
[0000.465] I> parsing oem signed section of cpubl header done
[0000.470] I> cpubl binary init read from storage
[0000.474] I> bpmp-fw: Authentication Finalize Done
[0000.479] I> oem authentication of cpubl header done
[0000.484] I> cpubl binary done read from storage
[0000.488] I> cpubl: Authentication init Done
[0000.493] I> parsing oem signed section of rce header done
[0000.498] I> rce binary init read from storage
[0000.502] I> Relocating BR-BCT
[0000.505] I> cpubl: Authentication Finalize Done
[0000.510] I> oem authentication of rce header done
[0000.514] I> rce binary done read from storage
[0000.518] I> rce: Authentication init Done
[0000.523] I> parsing oem signed section of ape header done
[0000.527] I> ape binary init read from storage
[0000.532] I> rce: Authentication Finalize Done
[0000.536] I> oem authentication of ape header done
[0000.541] I> ape binary done read from storage
[0000.545] I> ape: Authentication init Done
[0000.550] I> parsing oem signed section of tos header done
[0000.554] I> tos binary init read from storage
[0000.559] I> ape: Authentication Finalize Done
[0000.563] I> oem authentication of tos header done
[0000.567] I> tos binary done read from storage
[0000.572] I> tos: Authentication init Done
[0000.576] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.582] I> bpmp-fw-dtb binary init read from storage
[0000.587] I> tos: Authentication Finalize Done
[0000.593] I> oem authentication of bpmp-fw-dtb header done
[0000.599] I> bpmp-fw-dtb binary done read from storage
[0000.601] I> bpmp-fw-dtb: Authentication init Done
[0000.606] I> parsing oem signed section of cpubl-dtb header done
[0000.612] I> cpubl-dtb binary init read from storage
[0000.617] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.654] I> oem authentication of cpubl-dtb header done
[0000.654] I> cpubl-dtb binary done read from storage
[0000.655] I> cpubl-dtb: Authentication init Done
[0000.657] I> parsing oem signed section of eks header done
[0000.658] I> eks binary init read from storage
[0000.658] I> cpubl-dtb: Authentication Finalize Done
[0000.659] I> oem authentication of eks header done
[0000.662] I> eks binary done read from storage
[0000.667] I> eks: Authentication init Done
[0000.671] I> eks: Authentication Finalize Done
[0000.675] I> EKB detected (length: 0x410) @ VA:0x5270a400
銷OTICE: BL31: v1.3(release):5b49e7f80
NOTICE: BL31: Built : 08:38:54, Feb 19 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 197: key_mgnt_processing …
hwkey-agent: 189: Setting EKB key 0 to slot 14
hwkey-agent: 167: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
[0001.175] I> Welcome to Cboot鈓rq initialized
fmon_post initialized
[0001.176] I> Cboot Version: t194-9efcbc4f
[0001.176] I> CPU-BL Params @ 0xf2820000
[0001.177] I> 0) Base:0x00000000 Size:0x00000000
[0001.180] I> 1) Base:0xf1100000 Size:0x00100000
[0001.185] I> 2) Base:0xf2000000 Size:0x00200000
[0001.189] I> 3) Base:0xf1200000 Size:0x00200000
鈉lk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
醄0001.194] I> 4) Base:0xf1000000 Size:0x00100000
[0001.273] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.277] I> 6) Base:0xf3800000 Size:0x00400000
[0001.282] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.286] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.291] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.295] I> 10) Base:0xf3000000 Size:0x00800000
[0001.300] I> 11) Base:0x40000000 Size:0x00040000
[0001.304] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.309] I> 13) Base:0x40046000 Size:0x00002000
[0001.313] I> 14) Base:0x40048000 Size:0x00002000
鈋mc_debugfs initialized
dvs_debugfs initialized
醄0001.318] I> 15) Base:0xac000000 Size:0x00004000
鈌mon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] 醄0001.327] I> 16) Base:0x4004a000 Size:0x00002000
[0001.377] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.382] I> 18) Base:0x4004c000 Size:0x00002000
[0001.386] I> 19) Base:0xf2200000 Size:0x00600000
[0001.391] I> 20) Base:0x4004e000 Size:0x00002000
[0001.395] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.400] I> 22) Base:0x00000000 Size:0x00000000
[0001.404] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.409] I> 24) Base:0xf6000000 Size:0x02000000
[0001.413] I> 25) Base:0x40050000 Size:0x00002000
[0001.417] I> 26) Base:0x40040000 Size:0x00006000
[0001.422] I> 27) Base:0xf1800000 Size:0x00400000
[0001.426] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.431] I> 29) Base:0xf1400000 Size:0x00400000
[0001.435] I> 30) Base:0x00000000 Size:0x00000000
[0001.440] I> 31) Base:0x00000000 Size:0x00000000
[0001.444] I> 32) Base:0xf8000000 Size:0x08000000
[0001.449] I> 33) Base:0x00000000 Size:0x00000000
[0001.453] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.458] I> 35) Base:0xab000000 Size:0x01000000
[0001.462] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.467] I> 37) Base:0xf2800000 Size:0x00800000
[0001.471] I> 38) Base:0x80000000 Size:0x20000000
[0001.475] I> 39) Base:0xb0000000 Size:0x08000000
[0001.480] I> 40) Base:0x00000000 Size:0x00000000
[0001.484] I> 41) Base:0x00000000 Size:0x00000000
[0001.489] I> 42) Base:0x00000000 Size:0x00000000
[0001.493] I> 43) Base:0x00000000 Size:0x00000000
[0001.498] I> 44) Base:0x00000000 Size:0x00000000
[0001.502] I> 45) Base:0x00000000 Size:0x00000000
[0001.507] GIC-SPI Target CPU: 0
[0001.510] Interrupts Init done
[0001.513] calling constructors
[0001.515] initializing heap
[0001.518] I> Heap: [0xa06945e8 … 0xab000000]
[0001.522] initializing threads
[0001.525] initializing timers
[0001.528] creating bootstrap completion thread
[0001.532] top of bootstrap2()
[0001.535] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.540] initializing platform
[0001.543] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.548] W> device prod register failed
[0001.552] I> Bl_dtb @0xaaf00000
[0001.558] W> “plugin-manager” doesn’t exist, creating
[0001.560] W> “ids” doesn’t exist, creating
[0001.564] W> “connection” doesn’t exist, creating
[0001.568] W> “configs” doesn’t exist, creating
[0001.580] I> Find /i2c@3160000’s alias i2c0
[0001.580] I> Reading eeprom i2c=0 address=0x50
[0001.606] I> Device at /i2c@3160000:0x50
[0001.607] I> Reading eeprom i2c=0 address=0x56
[0001.631] I> Device at /i2c@3160000:0x56
[0001.636] I> Find /i2c@3180000’s alias i2c2
[0001.636] I> Reading eeprom i2c=2 address=0x54
[0001.638] E> I2C: slave not found in slaves.
[0001.638] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.639] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.640] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.646] E> eeprom: Failed to read I2C slave device
[0001.651] I> Eeprom read failed 0x3526070d
[0001.655] I> Reading eeprom i2c=2 address=0x57
[0001.660] E> I2C: slave not found in slaves.
[0001.664] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.671] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.677] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.686] E> eeprom: Failed to read I2C slave device
[0001.691] I> Eeprom read failed 0x3526070d
[0001.695] I> Reading eeprom i2c=2 address=0x52
[0001.700] E> I2C: slave not found in slaves.
[0001.704] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.712] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.717] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0001.727] E> eeprom: Failed to read I2C slave device
[0001.731] I> Eeprom read failed 0x3526070d
[0001.739] I> Find /i2c@c240000’s alias i2c1
[0001.739] I> Reading eeprom i2c=1 address=0x52
[0001.745] E> I2C: slave not found in slaves.
[0001.748] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.756] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.761] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.771] E> eeprom: Retry to read I2C slave device.
[0001.776] E> I2C: slave not found in slaves.
[0001.780] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.787] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.793] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.802] E> eeprom: Failed to read I2C slave device
[0001.807] I> Eeprom read failed 0x3526070d
[0001.811] I> Reading eeprom i2c=1 address=0x50
[0001.816] E> I2C: slave not found in slaves.
[0001.820] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.828] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.833] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.843] E> eeprom: Retry to read I2C slave device.
[0001.847] E> I2C: slave not found in slaves.
[0001.851] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.859] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.865] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.874] E> eeprom: Failed to read I2C slave device
[0001.879] I> Eeprom read failed 0x3526070d
[0001.883] I> create_pm_ids: id: 2888-0004-400-M, len: 15
[0001.888] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.899] I> create_pm_ids: id: XXXX-XXXX-XXX-X, len: 15
[0001.905] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff, len: 93
[0001.916] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0001.923] W> “i2c@3160000” doesn’t exist, creating
[0001.927] W> “module@0x50” doesn’t exist, creating
[0001.932] I> Adding plugin-manager/ids/XXXX-XXXX-XXX=/i2c@3160000:module@0x56
[0001.939] W> “module@0x56” doesn’t exist, creating
[0001.947] I> Adding plugin-manager/cvm
[0001.947] W> “chip-id” doesn’t exist, creating
[0001.951] I> Adding plugin-manager/chip-id/A02P
[0001.956] I> Plugin-manager override starting
[0001.961] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.970] I> node /plugin-manager/fragement-soft-wdt matches
[0001.978] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.984] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0001.991] I> Disable plugin-manager status in FDT
[0001.991] I> Plugin-manager override finished successfully
[0001.993] I> gpio framework initialized
[0001.998] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driver
[0002.005] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
[0002.012] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.019] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.027] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.033] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.039] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.047] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.055] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.061] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.069] I> fixed regulator driver initialized
[0002.080] I> register ‘maxim’ power off handle
[0002.081] I> virtual i2c enabled
[0002.081] I> registered ‘maxim,max20024’ pmic
[0002.083] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0002.090] I> Boot-device: eMMC
[0002.093] I> Boot_device: SDMMC_BOOT instance: 3
[0002.102] I> sdmmc-3 params source = boot args
[0002.102] I> create_pm_ids: id: 2888-0004-400-M, len: 15
[0002.107] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.118] I> create_pm_ids: id: XXXX-XXXX-XXX-X, len: 15
[0002.123] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff, len: 93
[0002.134] I> sdmmc bdev is already initialized
[0002.138] I> sdmmc-3 params source = boot args
[0002.169] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.182] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.192] I> enabling ‘vdd-hdmi-5v0’ regulator
[0002.198] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.198] I> hdmi cable connected
[0002.200] W> set volts not configured for ‘vdd-1v0’
[0002.202] W> set volts not configured for ‘vdd-1v8-hs’
[0002.207] E> invalid display type
[0002.211] E> invalid display type
[0002.212] E> cannot find any other nvdisp nodes
[0002.227] I> edid read success
[0002.240] I> edid read success
[0002.240] I> width = 640, height = 480, frequency = 25174825
[0002.241] I> width = 640, height = 480, frequency = 25174825
[0002.241] I> width = 1600, height = 900, frequency = 108000000
[0002.242] I> width = 720, height = 480, frequency = 27000000
[0002.246] I> width = 1920, height = 1080, frequency = 148351648
[0002.251] I> width = 1280, height = 720, frequency = 74175824
[0002.257] I> width = 720, height = 480, frequency = 26973026
[0002.262] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.272] I> hdmi_enable, starting HDMI initialisation
[0002.278] I> hdmi_enable, HDMI initialisation complete
[0002.288] I> Load in CBoot Boot Options partition and parse it
[0002.294] E> Error -9 when finding node with path /boot-configuration
[0002.295] E> tegrabl_cbo_parse_info: “boot-configuration” not found in CBO file.
[0002.298] I> Using default boot order
[0002.301] I> boot-dev-order :-
[0002.304] I> 1.sd
[0002.306] I> 2.usb
[0002.308] I> 3.nvme
[0002.310] I> 4.emmc
[0002.312] I> 5.net
[0002.313] I> Hit any key to stop autoboot: 4 3 2 1
[0004.321] initializing target
[0004.321] calling apps_init()
[0004.322] starting app kernel_boot_app
[0004.341] I> found decompressor handler: lz4-legacy
[0004.342] I> decompressing BMP blob …
[0004.354] I> Kernel type = Normal
[0004.354] I> Loading kernel-bootctrl from partition
[0004.354] I> Loading partition kernel-bootctrl at 0xa4ad0000 from device(0x1)
[0004.361] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.361] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.362] I> ########## SD (0) boot ##########
[0004.363] I> No sdcard
[0004.364] I> -0 params source =
[0004.367] E> Blockdev open: exit error
[0004.371] E> SD boot failed, err: 724238353
[0004.375] I> ########## USB (0) boot ##########
[0004.384] W> No valid slot number is found in scratch register
[0004.385] W> Return default slot: _a
[0004.400] I> USB Firmware Version: 60.06 release
[0004.456] I> regulator of usb2-0 already enabled
[0004.463] I> regulator of usb2-1 already enabled
[0004.470] I> regulator of usb2-2 already enabled
[0004.479] I> enabling ‘vdd-5v-sata’ regulator
[0005.547] I> USB 2.0 port 2 new high-speed USB device detected
[0005.547] W> Change usb2 root port id to 4
[0005.548] W> Change usb2 root port id to 2
[0005.549] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa9ad0000, cmd_ring.dma = 0xa9ad0040
[0005.650] I> Start to enumerate device
[0005.651] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa9ad0000, cmd_ring.dma = 0xa9ad0040
[0005.655] I> This device is non-MSD, skip enumeration
[0005.655] E> Failed to enumerate USB device
[0005.655] E> failed to start xhci controller
[0005.656] E> Error in init of XUSB host driver, err: 7979000d
[0005.656] W> Failed to initialize device 5-0
[0005.660] E> USB boot failed, err: 2037973005
[0005.665] I> ########## Fixed storage boot ##########
[0005.676] I> Already published: 00010003
[0005.676] I> Look for boot partition
[0005.677] I> Fallback: assuming 0th partition is boot partition
[0005.682] I> Detect filesystem
[0005.710] I> Loading extlinux.conf …
[0005.710] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0005.747] I> L4T boot options
[0005.747] I> [1]: “primary kernel”
[0005.747] I> Enter choice:
[0008.748] I> Continuing with default option: 1
[0008.748] I> Loading kernel sig file from rootfs …
[0008.748] I> rootfs path: /sdmmc_user/boot/Image.sig
[0008.773] I> Loading kernel binary from rootfs …
[0008.773] I> rootfs path: /sdmmc_user/boot/Image
[0009.017] I> Validate kernel …
[0009.017] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0009.330] E> digest on binary did not match!!
[0009.330] C> OEM authentication of kernel payload failed!
[0009.331] W> Failed to validate kernel binary (err=1077936152, fail=0)
[0009.331] W> Security fuse not burned, ignore validation failure
[0009.338] I> No kernel-dtb binary path
[0009.339] W> No valid slot number is found in scratch register
[0009.339] W> Return default slot: _a
[0009.339] I> A/B: bin_type (38) slot 0
[0009.343] I> Loading kernel-dtb from partition
[0009.347] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0009.362] I> Validate kernel-dtb …
[0009.362] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0009.366] I> Encryption fuse is not ON
[0009.368] I> Loading ramdisk from rootfs …
[0009.372] I> Loading initrd sig file from rootfs …
[0009.377] I> rootfs path: /sdmmc_user/boot/initrd.sig
[0009.400] I> Loading initrd binary from rootfs …
[0009.400] I> rootfs path: /sdmmc_user/boot/initrd
[0009.464] I> overload load_size to 7236840 (from 7236848)
[0009.467] I> Validate initrd …
[0009.467] I> T19x: Authenticate initrd (bin_type: 49), max size 0x4000000
[0009.534] I> Encryption fuse is not ON
[0009.547] I> Kernel hdr @0xa4ad0000
[0009.547] I> Kernel dtb @0x90000000
[0009.548] I> decompressor handler not found
[0009.548] I> Copying kernel image (34332680 bytes) from 0xa4ad0000 to 0x80080000 … [0009.558] I> Done
[0009.559] I> Updated bpmp info to DTB
[0009.561] I> Ramdisk: Base: 0x92000000; Size: 0x6e6ce8
[0009.561] I> Updated initrd info to DTB
[0009.562] W> WARN: Fail to override “console=none” in commandline
[0009.562] I> Active rootfs suffix:
[0009.564] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0009.571] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0009.578] W> No valid slot number is found in scratch register
[0009.584] W> Return default slot: _a
[0009.587] I> Active slot suffix:
[0009.590] I> add_boot_slot_suffix: slot_suffix =
[0009.595] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0xa06a0000 lut_mem=0x2008@0xa069b000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0009.626] I> Updated bootarg info to DTB
[0009.630] W> MAC addr invalid!
[0009.633] E> Failed to get WIFI MAC address
[0009.637] W> MAC addr invalid!
[0009.640] E> Failed to get Bluetooth MAC address
[0009.644] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:4d:60:24
[0009.651] W> “plugin-manager” doesn’t exist, creating
[0009.655] I> Adding /chosen/plugin-manager/cvm
[0009.659] W> “chip-id” doesn’t exist, creating
[0009.664] I> Adding /chosen/plugin-manager/chip-id
[0009.669] W> “configs” doesn’t exist, creating
[0009.673] I> Adding /chosen/plugin-manager/configs
[0009.677] W> “ids” doesn’t exist, creating
[0009.681] I> Adding /chosen/plugin-manager/ids
[0009.686] W> “odm-data” doesn’t exist, creating
[0009.690] I> Adding /chosen/plugin-manager/odm-data
[0009.698] W> “memory” doesn’t exist, creating
[0009.699] I> [0] START: 0x80000000, END: 0xac000000
[0009.704] I> [1] START: 0xac004000, END: 0xf0ad0000
[0009.708] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0009.713] I> dram_block larger than 80000000
[0009.717] I> [3] START: 0x100000000, END: 0x880000000
[0009.722] I> added [base:0x80000000, size:0x2c000000] to /memory
[0009.728] I> added [base:0xac200000, size:0x44800000] to /memory
[0009.734] I> added [base:0x100000000, size:0x780000000] to /memory
[0009.740] I> Updated memory info to DTB
[0009.744] E> add_disp_param: failed to get display params for du=1
[0009.750] W> “reset” doesn’t exist, creating
[0009.754] I> Adding ecid(0000000164091207140000000e0301c0) to DT
[0009.760] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0009.764] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0009.769] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0009.774] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0009.778] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0009.783] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0009.788] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0009.793] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0009.799] W> “misc-data” doesn’t exist, creating
[0009.802] I> Boot-device: eMMC
[0009.805] I> Add boot-sdmmc to plugin-manager/misc-data
[0009.810] I> Add storage-sdmmc to plugin-manager/misc-data
[0009.815] W> Unknown storage device
[0009.819] I> Add serial number:1423121017082 as DT property
[0009.825] I> Plugin-manager override starting
[0009.829] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0009.836] I> node /plugin-manager/fragement-soft-wdt matches
[0009.843] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0009.848] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0009.855] I> Disable plugin-manager status in FDT
[0009.856] I> Plugin-manager override finished successfully
[0009.862] I> tegrabl_load_kernel_and_dtb: Done
[0009.884] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (byd@ubuntu) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Sat Jan 8 00:56:04 PST 2022
[ 0.000000] ITSC_AVC_AIKernel_v00.00.05_20211208
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 780000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a06a0000
[ 0.000000] Found lut_mem: 00002008@a069b000
釽ARNING: pll_d3 has no dyn ramp
醄 7.226047] Micrel BCM89881 Gigabit PHY dwc_phy-1:03: $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ bcm89881_probe $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
[ 7.247322] tegra-xudc-new 3550000.xudc: extcon_get_extcon_dev_by_cable failed -19
[ 7.692732] max96712 2-0029: $$$ max96172_write_read_reg0x00f1: 0xc8
[ 7.832679] max96712 2-0029: $$$ max96172_read_reg0x001a: 0x12
[ 7.849125] max96712 2-0029: $$$ max96172_read_reg0x000a: 0x0
[ 7.865604] max96712 2-0029: $$$ max96172_read_reg0x000b: 0x0
[ 7.882044] max96712 2-0029: $$$ max96172_read_reg0x000c: 0xc8
[ 8.280184] max9295a 2-0040: max9295_write_reg:i2c write failed, 0x0 = 82
[ 8.280662] max9295a 2-0040: max9295_read_reg addr: 0x0000 val: oxffffff80
[ 8.340141] max9295a 2-0040: max9295_write_reg:i2c write failed, 0x0 = 84
[ 8.340613] max9295a 2-0040: max9295_read_reg addr: 0x0000 val: oxffffff80
[ 8.400189] max9295a 2-0040: max9295_write_reg:i2c write failed, 0x0 = 86
[ 8.400661] max9295a 2-0040: max9295_read_reg addr: 0x0000 val: oxffffff80
[ 8.460366] max9295a 2-0040: max9295_read_reg addr: 0x0000 val: ox88
[ 10.300267] ERROR: could not get clock /spi@c260000:osc(2)
[ 10.300870] ERROR: could not get clock /spi@c260000:osc(2)
[ 11.055352] rt5659 7-001a: Device with ID register ffffff80 is not rt5659
[ 11.156077] tegra-asoc: sound: ASoC: CODEC DAI rt5659-aif1 not registered
[ 11.156318] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 17.269722] bpmp_wait_ack() returned -110 (ch 22 mrq 3 data <0x25 0x01 0x00 0x06>)
[ 17.352842] CPU1: SError detected, daif=1c0, spsr=0x408000c5, mpidr=80000001, esr=be000000
[ 17.352853] CPU6: SError detected, daif=1c0, spsr=0x408000c5, mpidr=80000300, esr=be000000
[ 17.352860] CPU7: SError detected, daif=1c0, spsr=0x408000c5, mpidr=80000301, esr=be000000
[ 17.352870] CPU4: SError detected, daif=1c0, spsr=0x408000c5, mpidr=80000200, esr=be000000
[ 17.352877] CPU5: SError detected, daif=1c0, spsr=0x408000c5, mpidr=80000201, esr=be000000
[ 17.352887] CPU2: SError detected, daif=1c0, spsr=0x40c000c5, mpidr=80000100, esr=be000000
[ 17.352902] CPU3: SError detected, daif=1c0, spsr=0x408000c5, mpidr=80000101, esr=be000000
[ 17.517430] CPU:0, Error:CBB-NOC@0x2300000,irq=488
[ 17.517433] **************************************
[ 17.517436] * For more Internal Decode Help
[ 17.517438] * http://nv/cbberr
[ 17.517441] * NVIDIA userID is required to access
[ 17.517443] **************************************
[ 17.517445] CPU:0, Error:CBB-NOC
[ 17.517449] Error Logger : 0
[ 17.517459] ErrLog0 : 0x80000000
[ 17.517463] Transaction Type : RD - Read, Incrementing
[ 17.517465] Error Code : SLV
[ 17.517468] Error Source : Target
[ 17.517471] Error Description : Target error detected by CBB slave
[ 17.517481] AXI2APB_0 bridge error: SFIFONE - Status FIFO Not Empty interrupt
[ 17.517491] AXI2APB_0 bridge error: TIM - Timer(Timeout) interrupt
[ 17.517491] Packet header Lock : 0
[ 17.517494] Packet header Len1 : 0
[ 17.517497] NOC protocol version : version >= 2.7
[ 17.517500] ErrLog1 : 0x40000
[ 17.517503] ErrLog2 : 0x0
[ 17.517506] RouteId : 0x40000
[ 17.517509] InitFlow : aon_p2ps/I/aon
[ 17.517512] Targflow : gpu_p2pm/T/gpu_p2pm
[ 17.517515] TargSubRange : 0
[ 17.517518] SeqId : 0
[ 17.517521] ErrLog3 : 0x8
[ 17.517524] ErrLog4 : 0x80
[ 17.517558] debug using routeid alone as below address is a joker entry and not-reliable.
[ 17.517558] Address : 0x8017000008 (unknown device)
[ 17.517561] ErrLog5 : 0x0
[ 17.517564] Non-Modify : 0x0
[ 17.517567] AXI ID : 0x0
[ 17.517570] Master ID : 齵京?
[ 17.517573] Security Group(GRPSEC): 0x0
[ 17.517576] Cache : 0x0 – Non-cacheable/Non-Bufferable)
[ 17.517581] Protection : 0x0 – Unprivileged, Secure, Data Access
[ 17.517583] FALCONSEC : 0x0
[ 17.517587] Virtual Queuing Channel(VQC): 0x0
[ 17.517591] **************************************
[ 17.517658] CPU0: SError detected, daif=1c0, spsr=0x40400045, mpidr=80000000, esr=be000000
[ 21.599739] **************************************
[ 21.601618] * For more Internal Decode Help
[ 21.603382] * http://nv/cbberr
[ 21.605112] * NVIDIA userID is required to access
[ 21.606893] **************************************
[ 21.608647] CPU:6, Error:BPMP-NOC
[ 21.610369] Error Logger : 1
[ 21.612086] ErrLog0 : 0x80030600
[ 21.613772] Transaction Type : RD - Read, Incrementing
[ 21.615473] Error Code : TMO
[ 21.617148] Error Source : Target NIU
[ 21.618861] Error Description : Target time-out error
[ 21.620603] Packet header Lock : 0
[ 21.622347] Packet header Len1 : 3
[ 21.624099] NOC protocol version : version >= 2.7
[ 21.625893] ErrLog1 : 0xbba00
[ 21.627612] ErrLog2 : 0x0
[ 21.629331] RouteId : 0xbba00
[ 21.631024] InitFlow : cpu_p_i/I/0
[ 21.632750] Targflow : cbb_t/T/0
[ 21.634443] TargSubRange : 13
[ 21.636108] SeqId : 0
[ 21.637761] ErrLog3 : 0x700020c
[ 21.639427] ErrLog4 : 0x0
[ 21.641109] Address : 0x1700020c (unknown device)
[ 21.642834] ErrLog5 : 0xcfa30
[ 21.644500] Master ID : BPMP
[ 21.646164] Security Group(GRPSEC): 0x7d
[ 21.647839] Cache : 0x0 – Non-cacheable/Non-Bufferable)
[ 21.649571] Protection : 0x3 – Privileged, Non-Secure, Data Access
[ 21.651314] FALCONSEC : 0x0
[ 21.652984] Virtual Queuing Channel(VQC): 0x0
[ 21.654719] **************************************
[ 21.656438] **************************************
[ 21.658153] * For more Internal Decode Help
[ 21.659880] * http://nv/cbberr
[ 21.661561] * NVIDIA userID is required to access
[ 21.663299] **************************************
[ 21.665063] CPU:6, Error:CBB-NOC
[ 21.668264] Error Logger : 0
[ 21.671420] ErrLog0 : 0x80000000
[ 21.674912] Transaction Type : RD - Read, Incrementing
[ 21.679817] Error Code : SLV
[ 21.683489] Error Source : Target
[ 21.686905] Error Description : Target error detected by CBB slave
[ 21.693727] AXI2APB_0 bridge error: SFIFONE - Status FIFO Not Empty interrupt[ 21.700900] AXI2APB_0 bridge error: TIM - Timer(Timeout) interrupt
[ 21.707123] Packet header Lock : 0
[ 21.710965] Packet header Len1 : 0
[ 21.714462] NOC protocol version : version >= 2.7
[ 21.719452] ErrLog1 : 0x40000
[ 21.722607] ErrLog2 : 0x0
[ 21.725495] RouteId : 0x40000
[ 21.729162] InitFlow : aon_p2ps/I/aon
[ 21.732932] Targflow : gpu_p2pm/T/gpu_p2pm
[ 21.737130] TargSubRange : 0
[ 21.740542] SeqId : 0
[ 21.743513] ErrLog3 : 0x20
[ 21.746664] ErrLog4 : 0x80
[ 21.749639] debug using routeid alone as below address is a joker entry and not-reliable.[ 21.758044] Address : 0x8017000020 (unknown device)
[ 21.763201] ErrLog5 : 0x0
[ 21.765829] Non-Modify : 0x0
[ 21.769414] AXI ID : 0x0
[ 21.772042] Master ID : 齵京?
[ 21.775627] Security Group(GRPSEC): 0x0
[ 21.779825] Cache : 0x0 – Non-cacheable/Non-Bufferable)
[ 21.785602] Protection : 0x0 – Unprivileged, Secure, Data Access
[ 21.791988] FALCONSEC : 0x0
[ 21.795051] Virtual Queuing Channel(VQC): 0x0
[ 21.799600] **************************************
[ 21.804622] **************************************
[ 21.809401] RAS Error in SCF:IOB, ERRSELR_EL1=1025:
[ 21.813782] Status = 0xfc009604
[ 21.817277] IERR = CBB Interface Error: 0x96
[ 21.821480] SERR = Assertion Failure: 0x4
[ 21.825849] Overflow (there may be more errors) - Uncorrectable
[ 21.831629] Uncorrectable (this is fatal)
[ 21.835919] MISC0 = 0x40
[ 21.838538] MISC1 = 0x1664a444521
[ 21.841956] ADDR = 0x800000001404000c
[ 21.845806] **************************************
[ 21.850807] **************************************
[ 21.855516] RAS Error in L2, ERRSELR_EL1=512:
[ 21.860150] Status = 0xfc006612
[ 21.863564] IERR = SCF to L2 Slave Error Read: 0x66
[ 21.868206] SERR = Error response from slave: 0x12
[ 21.873104] Overflow (there may be more errors) - Uncorrectable
[ 21.878966] Uncorrectable (this is fatal)
[ 21.883344] MISC0 = 0x80000000400000
[ 21.886838] MISC1 = 0x20240000005
[ 21.890166] ADDR = 0x800000001404000c
[ 21.893759] **************************************
[ 21.899051] **************************************
[ 21.903901] RAS Error in L2, ERRSELR_EL1=560:
[ 21.908362] Status = 0xfc006612
[ 21.911516] IERR = SCF to L2 Slave Error Read: 0x66
[ 21.916588] SERR = Error response from slave: 0x12
[ 21.921399] Overflow (there may be more errors) - Uncorrectable
[ 21.927174] Uncorrectable (this is fatal)
[ 21.930952] MISC0 = 0x80000000400000
[ 21.934875] MISC1 = 0x20240000004
[ 21.938033] ADDR = 0x800000001404000c
[ 21.941884] **************************************
[ 21.947281] Bad mode in Error handler detected on CPU6, code 0xbe000000 – SError
[ 21.954654] Internal error: Oops - bad mode: 0 [#1] PREEMPT SMP
[ 21.960515] Modules linked in:
[ 21.965140] CPU: 6 PID: 0 Comm: swapper/6 Tainted: G W 4.9.201-tegra #1
[ 21.971188] Hardware name: Jetson-AGX (DT)
[ 21.975305] task: ffffffc7dbc47000 task.stack: ffffffc7dbc6c000
[ 21.981169] PC is at tegra_read_chipid+0x58/0xa8
[ 21.985633] LR is at tegra_read_chipid+0x28/0xa8
[ 21.990527] pc : [] lr : [] pstate: 408000c5
[ 21.998051] sp : ffffffc7dbc6fe50
[ 22.001462] x29: ffffffc7dbc6fe50 x28: 0000000000000001
[ 22.008862] x27: ffffff8009e66000 x26: ffffff8009831ac0
[ 22.014134] x25: 0000000000000000 x24: 0000000405ba76e0
[ 22.019682] x23: ffffff8009fd8658 x22: ffffffc7ffd58ac8
[ 22.025370] x21: ffffff8009fd8670 x20: ffffff800a19c148
[ 22.031063] x19: ffffff800a19c148 x18: 0000000001b78a3f
[ 22.037009] x17: 0000000000000000 x16: 000000000000000e
[ 22.042444] x15: 0000000000000000 x14: 00000000003ef602
[ 22.048096] x13: 0000000000000f99 x12: 071c71c71c71c71c
[ 22.053691] x11: 000000000000000b x10: 0101010101010101
[ 22.059357] x9 : fffffffffffffffb x8 : 7f7f7f7f7f7f7f7f
[ 22.065400] x7 : fefefeff646c606d x6 : 00170401e9e1acf4
[ 22.070645] x5 : 742c616901041700 x4 : 8080808000000000
[ 22.076255] x3 : b34b234b0963a000 x2 : 000000000000000b
[ 22.081583] x1 : ffffffc7dbc47000 x0 : 0000000000021917
[ 22.086667]
[ 22.088450] Process swapper/6 (pid: 0, stack limit = 0xffffffc7dbc6c000)
[ 22.093251] Call trace:
[ 22.095363] [] tegra_read_chipid+0x58/0xa8
[ 22.100697] [] tegra_get_platform+0x14/0x80
[ 22.106295] [] t19x_cpu_enter_state+0x1c/0x118
[ 22.111634] [] cpuidle_enter_state+0x84/0x380
[ 22.117491] [] cpuidle_enter+0x34/0x48
[ 22.122313] [] call_cpuidle+0x44/0x70
[ 22.127380] [] cpu_startup_entry+0x1b0/0x200
[ 22.132981] [] secondary_start_kernel+0x190/0x1f8
[ 22.138582] [<0000000080f6e1a4>] 0x80f6e1a4
[ 22.142615] —[ end trace f561c186fb0590f7 ]—
[ 22.163183] Kernel panic - not syncing: Attempted to kill the idle task!
[ 22.165185] SMP: stopping secondary CPUs
[ 23.256940] SMP: failed to stop secondary CPUs 0-7
[ 23.258894] Kernel Offset: disabled
[ 23.260823] Memory Limit: none
[ 23.262739] trusty-log panic notifier - trusty version Built: 08:40:57 Feb 19 2021 [ 23.279083] Rebooting in 5 seconds…
[ 26.194160] **************************************
[ 26.196271] * For more Internal Decode Help
[ 26.198297] * http://nv/cbberr
[ 26.200302] * NVIDIA userID is required to access
[ 26.202330] **************************************
[ 26.204391] CPU:7, Error:BPMP-NOC
[ 26.206409] Error Logger : 1
[ 26.208410] ErrLog0 : 0x80030608
[ 26.210405] Transaction Type : WR - Write, Incrementing
[ 26.212470] Error Code : TMO
[ 26.214474] Error Source : Target NIU
[ 26.216500] Error Description : Target time-out error
[ 26.218532] Packet header Lock : 0
[ 26.220514] Packet header Len1 : 3
[ 26.222445] NOC protocol version : version >= 2.7
[ 26.224387] ErrLog1 : 0xbaa01
[ 26.226292] ErrLog2 : 0x0
[ 26.228176] RouteId : 0xbaa01
[ 26.230049] InitFlow : cpu_p_i/I/0
[ 26.231947] Targflow : cbb_t/T/0
[ 26.233807] TargSubRange : 5
[ 26.235635] SeqId : 0
[ 26.237450] ErrLog3 : 0x190000
[ 26.239242] ErrLog4 : 0x0
[ 26.241035] Address : 0xc190000 (unknown device)
[ 26.242857] ErrLog5 : 0xcfa30
[ 26.244656] Master ID : BPMP
[ 26.246463] Security Group(GRPSEC): 0x7d
[ 26.248268] Cache : 0x0 – Non-cacheable/Non-Bufferable)
[ 26.250123] Protection : 0x3 – Privileged, Non-Secure, Data Access
[ 26.252057] FALCONSEC : 0x0
[ 26.253921] Virtual Queuing Channel(VQC): 0x0
[ 26.255796] **************************************
[ 26.257709] **************************************
[ 26.259563] * For more Internal Decode Help
[ 26.261438] * http://nv/cbberr
[ 26.263292] * NVIDIA userID is required to access
[ 26.265157] **************************************
[ 26.267015] CPU:7, Error:CBB-NOC
[ 26.268815] Error Logger : 0
[ 26.270616] ErrLog0 : 0x80000000
[ 26.272406] Transaction Type : RD - Read, Incrementing
[ 26.274548] Error Code : SLV
[ 26.277703] Error Source : Target
[ 26.281636] Error Description : Target error detected by CBB slave
[ 26.288203] AXI2APB_0 bridge error: SFIFONE - Status FIFO Not Empty interrupt[ 26.295117] AXI2APB_0 bridge error: SFIFOF - Status FIFO Full interrupt
[ 26.302376] AXI2APB_0 bridge error: TIM - Timer(Timeout) interrupt[ 26.308418] Packet header Lock : 0
[ 26.311830] Packet header Len1 : 0
[ 26.315503] NOC protocol version : version >= 2.7
[ 26.320491] ErrLog1 : 0x40000
[ 26.324163] ErrLog2 : 0x0
[ 26.326875] RouteId : 0x40000
[ 26.330111] InitFlow : aon_p2ps/I/aon
[ 26.333967] Targflow : gpu_p2pm/T/gpu_p2pm
[ 26.338511] TargSubRange : 0
[ 26.341666] SeqId : 0
[ 26.344379] ErrLog3 : 0x30
[ 26.347529] ErrLog4 : 0x80
[ 26.350679] debug using routeid alone as below address is a joker entry and not-reliable.[ 26.359256] Address : 0x8017000030 (unknown device)
[ 26.364413] ErrLog5 : 0x0
[ 26.367041] Non-Modify : 0x0
[ 26.370536] AXI ID : 0x0
[ 26.373166] Master ID : 齵京?
[ 26.376838] Security Group(GRPSEC): 0x0
[ 26.381036] Cache : 0x0 – Non-cacheable/Non-Bufferable)
[ 26.386555] Protection : 0x0 – Unprivileged, Secure, Data Access
[ 26.392944] FALCONSEC : 0x0
[ 26.396263] Virtual Queuing Channel(VQC): 0x0
[ 26.400812] **************************************
[ 26.405798] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Errors
[ 26.413702] **************************************
[ 26.418750] RAS Error in SCF:IOB, ERRSELR_EL1=1025:
[ 26.423738] Status = 0xfc009604
[ 26.426803] IERR = CBB Interface Error: 0x96
[ 26.431268] SERR = Assertion Failure: 0x4
[ 26.435723] Overflow (there may be more errors) - Uncorrectable
[ 26.441327] Uncorrectable (this is fatal)
[ 26.445791] MISC0 = 0x40
[ 26.448066] MISC1 = 0x264e444423
[ 26.451481] ADDR = 0x800000001404000c
[ 26.455681] **************************************
[ 26.460578] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectable Errors
[ 26.469739] **************************************
[ 26.474836] RAS Error in L2, ERRSELR_EL1=560:
[ 26.479298] Status = 0xfc006612
[ 26.482536] IERR = SCF to L2 Slave Error Read: 0x66
[ 26.487349] SERR = Error response from slave: 0x12
[ 26.492250] Overflow (there may be more errors) - Uncorrectable
[ 26.498026] Uncorrectable (this is fatal)
[ 26.501884] MISC0 = 0x100000000400000
[ 26.506074] MISC1 = 0x40240000000
[ 26.509232] ADDR = 0x800000001404000c
[ 26.513340] **************************************
[ 26.518248] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
[ 26.526344] Bad mode in Error handler detected on CPU7, code 0xbe000000 – SError
[ 26.533638] Internal error: Oops - bad mode: 0 [#2] PREEMPT SMP
[ 26.539242] Modules linked in:
[ 26.544297] CPU: 7 PID: 0 Comm: swapper/7 Tainted: G D W 4.9.201-tegra #1
[ 26.550089] Hardware name: Jetson-AGX (DT)
[ 26.554030] task: ffffffc7dbc70000 task.stack: ffffffc7dbc78000
[ 26.560241] PC is at tegra_read_chipid+0x58/0xa8
[ 26.564966] LR is at tegra_read_chipid+0x28/0xa8
[ 26.569343] pc : [] lr : [] pstate: 408000c5
[ 26.577037] sp : ffffffc7dbc7be50
[ 26.580275] x29: ffffffc7dbc7be50 x28: 0000000000000001
[ 26.587605] x27: ffffff8009e66000 x26: ffffff8009831ac0
[ 26.593146] x25: 0000000000000000 x24: 0000000405ba7560
[ 26.599177] x23: ffffff8009fd8658 x22: ffffffc7ffd70ac8
[ 26.604612] x21: ffffff8009fd8670 x20: ffffff800a19c148
[ 26.610306] x19: ffffff800a19c148 x18: 00000000ffffffe4
[ 26.616247] x17: 0000000000000000 x16: 000000000000000e
[ 26.621691] x15: 0000000000000000 x14: 0000000000000001
[ 26.627623] x13: 0000000000000f99 x12: 071c71c71c71c71c
[ 26.633240] x11: 000000000000000b x10: 0101010101010101
[ 26.638857] x9 : fffffffffffffffb x8 : 7f7f7f7f7f7f7f7f
[ 26.644581] x7 : fefefeff646c606d x6 : 00170401e9e1acf4
[ 26.650099] x5 : 742c616901041700 x4 : 8080808000000000
[ 26.655443] x3 : b34b234b0963a000 x2 : 000000000000000b
[ 26.660791] x1 : ffffffc7dbc70000 x0 : 0000000000021917
[ 26.665873]
[ 26.667871] Process swapper/7 (pid: 0, stack limit = 0xffffffc7dbc78000)
[ 26.672238] Call trace:
[ 26.674604] [] tegra_read_chipid+0x58/0xa8
[ 26.679942] [] tegra_get_platform+0x14/0x80
[ 26.685281] [] t19x_cpu_enter_state+0x1c/0x118
[ 26.690620] [] cpuidle_enter_state+0x84/0x380
[ 26.696223] [] cpuidle_enter+0x34/0x48
[ 26.701553] [] call_cpuidle+0x44/0x70
[ 26.706107] [] cpu_startup_entry+0x1b0/0x200
[ 26.711967] [] secondary_start_kernel+0x190/0x1f8
[ 26.717828] [<0000000080f6e1a4>] 0x80f6e1a4
[ 26.721594] —[ end trace f561c186fb0590f8 ]—
[ 28.281644] SMP: stopping secondary CPUs
[ 29.375253] SMP: failed to stop secondary CPUs 0-7
醄 30.773256] **************************************
[ 30.775494] * For more Internal Decode Help
[ 30.777611] * http://nv/cbberr
[ 30.779689] * NVIDIA userID is required to access
[ 30.781760] **************************************
[ 30.783831] CPU:4, Error:CBB-NOC
[ 30.785882] Error Logger : 0
[ 30.787915] ErrLog0 : 0x80000000
[ 30.789936] Transaction Type : RD - Read, Incrementing
[ 30.791994] Error Code : SLV
[ 30.794005] Error Source : Target
[ 30.796014] Error Description : Target error detected by CBB slave
[ 30.798114] AXI2APB_0 bridge error: SFIFONE - Status FIFO Not Empty interrupt[ 30.798304] AXI2APB_0 bridge error: SFIFOF - Status FIFO Full interrupt
[ 30.800492] AXI2APB_0 bridge error: TIM - Timer(Timeout) interrupt[ 30.800660] Packet header Lock : 0
[ 30.802800] Packet header Len1 : 0
[ 30.804965] NOC protocol version : version >= 2.7
[ 30.807112] ErrLog1 : 0x40000
[ 30.809192] ErrLog2 : 0x0
[ 30.811261] RouteId : 0x40000
[ 30.813302] InitFlow : aon_p2ps/I/aon
[ 30.815339] Targflow : gpu_p2pm/T/gpu_p2pm
[ 30.817368] TargSubRange : 0
[ 30.819358] SeqId : 0
[ 30.821342] ErrLog3 : 0x40
[ 30.823320] ErrLog4 : 0x80
[ 30.825252] debug using routeid alone as below address is a joker entry and not-reliable.[ 30.825497] Address : 0x8017000040 (unknown device)
[ 30.827552] ErrLog5 : 0x0
[ 30.829587] Non-Modify : 0x0
[ 30.831649] AXI ID : 0x0
[ 30.833678] Master ID : 齵京?
[ 30.835701] Security Group(GRPSEC): 0x0
[ 30.837771] Cache : 0x0 – Non-cacheable/Non-Bufferable)
[ 30.839863] Protection : 0x0 – Unprivileged, Secure, Data Access
[ 30.842019] FALCONSEC : 0x0
[ 30.844096] Virtual Queuing Channel(VQC): 0x0
[ 30.848085] **************************************
[ 30.853074] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Errors
[ 30.861238] **************************************
[ 30.865765] RAS Error in SCF:IOB, ERRSELR_EL1=1025:
[ 30.871011] Status = 0xfc009604
[ 30.874076] IERR = CBB Interface Error: 0x96
[ 30.878539] SERR = Assertion Failure: 0x4
[ 30.882995] Overflow (there may be more errors) - Uncorrectable
[ 30.888860] Uncorrectable (this is fatal)
[ 30.893065] MISC0 = 0x40
[ 30.895595] MISC1 = 0x226424445e1
[ 30.899012] ADDR = 0x800000001404000c
[ 30.902951] **************************************
[ 30.907594] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectable Errors
[ 30.916998] **************************************
[ 30.922109] RAS Error in L2, ERRSELR_EL1=544:
[ 30.926573] Status = 0xfc006612
[ 30.929809] IERR = SCF to L2 Slave Error Read: 0x66
[ 30.934367] SERR = Error response from slave: 0x12
[ 30.939520] Overflow (there may be more errors) - Uncorrectable
[ 30.945297] Uncorrectable (this is fatal)
[ 30.949416] MISC0 = 0x80000000400000
[ 30.953085] MISC1 = 0x20240000008
[ 30.956500] ADDR = 0x800000001404000c
[ 30.960352] **************************************
[ 30.965363] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
[ 30.973447] Bad mode in Error handler detected on CPU4, code 0xbe000000 – SError
[ 30.980739] Internal error: Oops - bad mode: 0 [#3] PREEMPT SMP
[ 30.986340] Modules linked in:
[ 30.991493] CPU: 4 PID: 0 Comm: swapper/4 Tainted: G D W 4.9.201-tegra #1
[ 30.997183] Hardware name: Jetson-AGX (DT)
[ 31.001386] task: ffffffc7dbc45400 task.stack: ffffffc7dbc5c000
[ 31.007343] PC is at tegra_read_chipid+0x58/0xa8
[ 31.012065] LR is at tegra_read_chipid+0x28/0xa8
[ 31.016698] pc : [] lr : [] pstate: 408000c5
[ 31.024314] sp : ffffffc7dbc5fe50
[ 31.027290] x29: ffffffc7dbc5fe50 x28: 0000000000000001
[ 31.034982] x27: ffffff8009e66000 x26: ffffff8009831ac0
[ 31.040769] x25: 0000000000000000 x24: 0000000405ba7ac0
[ 31.046296] x23: ffffff8009fd8658 x22: ffffffc7ffd28ac8
[ 31.052238] x21: ffffff8009fd8670 x20: ffffff800a19c148
[ 31.057672] x19: ffffff800a19c148 x18: 0000000001c00723
[ 31.063357] x17: 0000000000000000 x16: 000000000000000e
[ 31.069326] x15: 0000000000000000 x14: 0000000000511259
[ 31.074751] x13: 0000000000000f98 x12: 071c71c71c71c71c
[ 31.080617] x11: 000000000000000b x10: 0101010101010101
[ 31.086244] x9 : fffffffffffffffb x8 : 7f7f7f7f7f7f7f7f
[ 31.091957] x7 : fefefeff646c606d x6 : 00170401e9e1acf4
[ 31.097479] x5 : 742c616901041700 x4 : 8080808000000000
[ 31.102572] x3 : b34b234b0963a000 x2 : 000000000000000b
[ 31.108175] x1 : ffffffc7dbc45400 x0 : 0000000000021917
[ 31.113507]
[ 31.115589] Process swapper/4 (pid: 0, stack limit = 0xffffffc7dbc5c000)
[ 31.119252] Call trace:
[ 31.121624] [] tegra_read_chipid+0x58/0xa8
[ 31.127216] [] tegra_get_platform+0x14/0x80
[ 31.132296] [] t19x_cpu_enter_state+0x1c/0x118
[ 31.137894] [] cpuidle_enter_state+0x84/0x380
[ 31.143494] [] cpuidle_enter+0x34/0x48
[ 31.148827] [] call_cpuidle+0x44/0x70
[ 31.153639] [] cpu_startup_entry+0x1b0/0x200
[ 31.158984] [] secondary_start_kernel+0x190/0x1f8
[ 31.165099] [<0000000080f6e1a4>] 0x80f6e1a4
[ 31.168612] —[ end trace f561c186fb0590f9 ]—
[ 35.220355] **************************************
[ 35.222508] * For more Internal Decode Help
[ 35.224623] * http://nv/cbberr
[ 35.226714] * NVIDIA userID is required to access
[ 35.228836] **************************************
[ 35.230938] CPU:5, Error:CBB-NOC
[ 35.232976] Error Logger : 0
[ 35.235011] ErrLog0 : 0x80000000
[ 35.237030] Transaction Type : RD - Read, Incrementing
[ 35.239119] Error Code : SLV
[ 35.241152] Error Source : Target
[ 35.243169] Error Description : Target error detected by CBB slave
[ 35.245263] AXI2APB_0 bridge error: SFIFONE - Status FIFO Not Empty interrupt[ 35.245455] AXI2APB_0 bridge error: SFIFOF - Status FIFO Full interrupt
[ 35.247605] AXI2APB_0 bridge error: TIM - Timer(Timeout) interrupt[ 35.247779] Packet header Lock : 0
[ 35.249909] Packet header Len1 : 0
[ 35.252092] NOC protocol version : version >= 2.7
[ 35.254305] ErrLog1 : 0x40000
[ 35.256461] ErrLog2 : 0x0
[ 35.258556] RouteId : 0x40000
[ 35.260633] InitFlow : aon_p2ps/I/aon
[ 35.262700] Targflow : gpu_p2pm/T/gpu_p2pm
[ 35.264777] TargSubRange : 0
[ 35.266790] SeqId : 0
[ 35.268779] ErrLog3 : 0x50
[ 35.270728] ErrLog4 : 0x80
[ 35.272664] debug using routeid alone as below address is a joker entry and not-reliable.[ 35.272913] Address : 0x8017000050 (unknown device)
[ 35.274954] ErrLog5 : 0x0
[ 35.276993] Non-Modify : 0x0
[ 35.279038] AXI ID : 0x0
[ 35.281051] Master ID : 齵京?
[ 35.283065] Security Group(GRPSEC): 0x0
[ 35.285092] Cache : 0x0 – Non-cacheable/Non-Bufferable)
[ 35.287194] Protection : 0x0 – Unprivileged, Secure, Data Access
[ 35.289328] FALCONSEC : 0x0
[ 35.291374] Virtual Queuing Channel(VQC): 0x0
[ 35.294669] **************************************
[ 35.299913] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Errors
[ 35.308075] **************************************
[ 35.312605] RAS Error in SCF:IOB, ERRSELR_EL1=1025:
[ 35.317850] Status = 0xfc009604
[ 35.321174] IERR = CBB Interface Error: 0x96
[ 35.325381] SERR = Assertion Failure: 0x4
[ 35.329579] Overflow (there may be more errors) - Uncorrectable
[ 35.335441] Uncorrectable (this is fatal)
[ 35.339907] MISC0 = 0x40
[ 35.342438] MISC1 = 0x2642444423
[ 35.345853] ADDR = 0x800000001404000c
[ 35.349793] **************************************
[ 35.354692] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectable Errors
[ 35.364096] **************************************
[ 35.368950] RAS Error in L2, ERRSELR_EL1=544:
[ 35.373412] Status = 0xfc006612
[ 35.376650] IERR = SCF to L2 Slave Error Read: 0x66
[ 35.381209] SERR = Error response from slave: 0x12
[ 35.386361] Overflow (there may be more errors) - Uncorrectable
[ 35.391880] Uncorrectable (this is fatal)
[ 35.395998] MISC0 = 0x100000000400000
[ 35.400189] MISC1 = 0x40240000000
[ 35.403603] ADDR = 0x800000001404000c
[ 35.407456] **************************************
[ 35.412121] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
[ 35.420461] Bad mode in Error handler detected on CPU5, code 0xbe000000 – SError
[ 35.427753] Internal error: Oops - bad mode: 0 [#4] PREEMPT SMP
[ 35.433612] Modules linked in:
[ 35.438252] CPU: 5 PID: 0 Comm: swapper/5 Tainted: G D W 4.9.201-tegra #1
[ 35.444201] Hardware name: Jetson-AGX (DT)
[ 35.448403] task: ffffffc7dbc46200 task.stack: ffffffc7dbc68000
[ 35.454354] PC is at tegra_read_chipid+0x58/0xa8
[ 35.459078] LR is at tegra_read_chipid+0x28/0xa8
[ 35.463457] pc : [] lr : [] pstate: 408000c5
[ 35.471151] sp : ffffffc7dbc6be50
[ 35.474133] x29: ffffffc7dbc6be50 x28: 0000000000000001
[ 35.481822] x27: ffffff8009e66000 x26: ffffff8009831ac0
[ 35.487349] x25: 0000000000000000 x24: 0000000405ba7f80
[ 35.493388] x23: ffffff8009fd8658 x22: ffffffc7ffd40ac8
[ 35.499088] x21: ffffff8009fd8670 x20: ffffff800a19c148
[ 35.504679] x19: ffffff800a19c148 x18: 0000000001b77a3f
[ 35.510215] x17: 0000000000000000 x16: 00000000007072bb
[ 35.516160] x15: 00000000006e09e3 x14: 00000000003eea02
[ 35.521850] x13: 0000000000000f97 x12: 071c71c71c71c71c
[ 35.527209] x11: 000000000000000b x10: 0101010101010101
[ 35.532828] x9 : fffffffffffffffb x8 : 7f7f7f7f7f7f7f7f
[ 35.538543] x7 : fefefeff646c606d x6 : 00170401e9e1acf4
[ 35.544323] x5 : 742c616901041700 x4 : 8080808000000000
[ 35.549406] x3 : b34b234b0963a000 x2 : 000000000000000b
[ 35.555012] x1 : ffffffc7dbc46200 x0 : 0000000000021917
[ 35.560338]
[ 35.562421] Process swapper/5 (pid: 0, stack limit = 0xffffffc7dbc68000)
[ 35.566349] Call trace:
[ 35.568716] [] tegra_read_chipid+0x58/0xa8
[ 35.574056] [] tegra_get_platform+0x14/0x80
[ 35.579392] [] t19x_cpu_enter_state+0x1c/0x118
[ 35.584992] [] cpuidle_enter_state+0x84/0x380
[ 35.590593] [] cpuidle_enter+0x34/0x48
[ 35.595408] [] call_cpuidle+0x44/0x70
[ 35.600479] [] cpu_startup_entry+0x1b0/0x200
[ 35.606080] [] secondary_start_kernel+0x190/0x1f8
[ 35.611687] [<0000000080f6e1a4>] 0x80f6e1a4
[ 35.615449] —[ end trace f561c186fb0590fa ]—
[ 39.667344] **************************************
[ 39.669561] * For more Internal Decode Help
[ 39.671686] * http://nv/cbberr
[ 39.673808] * NVIDIA userID is required to access
[ 39.675955] **************************************
[ 39.678070] CPU:2, Error:CBB-NOC
[ 39.680122] Error Logger : 0
[ 39.682164] ErrLog0 : 0x80000000
[ 39.684189] Transaction Type : RD - Read, Incrementing
[ 39.686264] Error Code : SLV
[ 39.688290] Error Source : Target
[ 39.690304] Error Description : Target error detected by CBB slave
[ 39.692375] AXI2APB_0 bridge error: SFIFONE - Status FIFO Not Empty interrupt[ 39.692572] AXI2APB_0 bridge error: SFIFOF - Status FIFO Full interrupt
[ 39.694736] AXI2APB_0 bridge error: TIM - Timer(Timeout) interrupt[ 39.694908] Packet header Lock : 0
[ 39.697046] Packet header Len1 : 0
[ 39.699235] NOC protocol version : version >= 2.7
[ 39.701446] ErrLog1 : 0x40000
[ 39.703599] ErrLog2 : 0x0
[ 39.705696] RouteId : 0x40000
[ 39.707781] InitFlow : aon_p2ps/I/aon
[ 39.709833] Targflow : gpu_p2pm/T/gpu_p2pm
[ 39.711900] TargSubRange : 0
[ 39.713923] SeqId : 0
[ 39.715911] ErrLog3 : 0x60
[ 39.717868] ErrLog4 : 0x80
[ 39.719840] debug using routeid alone as below address is a joker entry and not-reliable.[ 39.720073] Address : 0x8017000060 (unknown device)
[ 39.722131] ErrLog5 : 0x0
[ 39.724161] Non-Modify : 0x0
[ 39.726203] AXI ID : 0x0
[ 39.728250] Master ID : 齵京?
[ 39.730295] Security Group(GRPSEC): 0x0
[ 39.732329] Cache : 0x0 – Non-cacheable/Non-Bufferable)
[ 39.734439] Protection : 0x0 – Unprivileged, Secure, Data Access
[ 39.736555] FALCONSEC : 0x0
[ 39.738613] Virtual Queuing Channel(VQC): 0x0
[ 39.741983] **************************************
[ 39.746712] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Errors
[ 39.755134] **************************************
[ 39.759662] RAS Error in SCF:IOB, ERRSELR_EL1=1025:
[ 39.764906] Status = 0xfc009604
[ 39.767973] IERR = CBB Interface Error: 0x96
[ 39.772695] SERR = Assertion Failure: 0x4
[ 39.776893] Overflow (there may be more errors) - Uncorrectable
[ 39.782756] Uncorrectable (this is fatal)
[ 39.786963] MISC0 = 0x40
[ 39.789496] MISC1 = 0x1a6464445e1
[ 39.792652] ADDR = 0x800000001404000c
[ 39.796592] **************************************
[ 39.801750] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectable Errors
[ 39.810878] **************************************
[ 39.816006] RAS Error in L2, ERRSELR_EL1=528:
[ 39.820468] Status = 0xfc006612
[ 39.823707] IERR = SCF to L2 Slave Error Read: 0x66
[ 39.828519] SERR = Error response from slave: 0x12
[ 39.833160] Overflow (there may be more errors) - Uncorrectable
[ 39.839192] Uncorrectable (this is fatal)
[ 39.843055] MISC0 = 0x80000000400000
[ 39.846982] MISC1 = 0x20240000006
[ 39.850396] ADDR = 0x800000001404000c
[ 39.853990] **************************************
[ 39.859021] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
[ 39.867086] Bad mode in Error handler detected on CPU2, code 0xbe000000 – SError
[ 39.874376] Internal error: Oops - bad mode: 0 [#5] PREEMPT SMP
[ 39.880495] Modules linked in:
[ 39.885149] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G D W 4.9.201-tegra #1
[ 39.890823] Hardware name: Jetson-AGX (DT)
[ 39.895025] task: ffffffc7dbc43800 task.stack: ffffffc7dbc54000
[ 39.900980] PC is at tegra_read_chipid+0x58/0xa8
[ 39.905960] LR is at tegra_read_chipid+0x28/0xa8
[ 39.910596] pc : [] lr : [] pstate: 40c000c5
[ 39.917949] sp : ffffffc7dbc57e50
[ 39.921444] x29: ffffffc7dbc57e50 x28: 0000000000000001
[ 39.928888] x27: ffffff8009e66000 x26: ffffff8009831ac0
[ 39.934683] x25: 0000000000000000 x24: 0000000405bacdc0
[ 39.940452] x23: ffffff8009fd8658 x22: ffffffc7ffcf8ac8
[ 39.945901] x21: ffffff8009fd8670 x20: ffffff800a19c148
[ 39.951576] x19: ffffff800a19c148 x18: 00000000000003ea
[ 39.957269] x17: 0000000000000000 x16: 00000000008d1833
[ 39.962963] x15: 0000000000871cd2 x14: 000000000019b5ba
[ 39.968658] x13: 0000000000000f83 x12: 071c71c71c71c71c
[ 39.974529] x11: 000000000000000b x10: 0101010101010101
[ 39.980142] x9 : fffffffffffffffb x8 : 7f7f7f7f7f7f7f7f
[ 39.985860] x7 : fefefeff646c606d x6 : 00170401e9e1acf4
[ 39.991382] x5 : 742c616901041700 x4 : 8080808000000000
[ 39.996735] x3 : b34b234b0963a000 x2 : 000000000000000b
[ 40.002069] x1 : ffffffc7dbc43800 x0 : 0000000000021917
[ 40.007414]
[ 40.009529] Process swapper/2 (pid: 0, stack limit = 0xffffffc7dbc54000)
[ 40.013407] Call trace:
[ 40.015773] [] tegra_read_chipid+0x58/0xa8
[ 40.021111] [] tegra_get_platform+0x14/0x80
[ 40.026194] [] t19x_cpu_enter_state+0x1c/0x118
[ 40.031791] [] cpuidle_enter_state+0x84/0x380
[ 40.037651] [] cpuidle_enter+0x34/0x48
[ 40.042468] [] call_cpuidle+0x44/0x70
[ 40.047535] [] cpu_startup_entry+0x1b0/0x200
[ 40.052880] [] secondary_start_kernel+0x190/0x1f8
[ 40.058997] [<0000000080f6e1a4>] 0x80f6e1a4
[ 40.062507] —[ end trace f561c186fb0590fb ]—
[ 44.113975] **************************************
[ 44.116127] * For more Internal Decode Help
[ 44.118243] * http://nv/cbberr
[ 44.120348] * NVIDIA userID is required to access
[ 44.122494] **************************************
[ 44.124606] CPU:3, Error:CBB-NOC
[ 44.126632] Error Logger : 0
[ 44.128653] ErrLog0 : 0x80000000
[ 44.130667] Transaction Type : RD - Read, Incrementing
[ 44.132746] Error Code : SLV
[ 44.134772] Error Source : Target
[ 44.136789] Error Description : Target error detected by CBB slave
[ 44.138878] AXI2APB_0 bridge error: SFIFONE - Status FIFO Not Empty interrupt[ 44.139071] AXI2APB_0 bridge error: SFIFOF - Status FIFO Full interrupt
[ 44.141224] AXI2APB_0 bridge error: TIM - Timer(Timeout) interrupt[ 44.141394] Packet header Lock : 0
[ 44.143529] Packet header Len1 : 0
[ 44.145713] NOC protocol version : version >= 2.7
[ 44.147917] ErrLog1 : 0x40000
[ 44.150081] ErrLog2 : 0x0
[ 44.152177] RouteId : 0x40000
[ 44.154274] InitFlow : aon_p2ps/I/aon
[ 44.156369] Targflow : gpu_p2pm/T/gpu_p2pm
[ 44.158414] TargSubRange : 0
[ 44.160427] SeqId : 0
[ 44.162412] ErrLog3 : 0x70
[ 44.164355] ErrLog4 : 0x80
[ 44.166328] debug using routeid alone as below address is a joker entry and not-reliable.[ 44.166556] Address : 0x8017000070 (unknown device)
[ 44.168607] ErrLog5 : 0x0
[ 44.170639] Non-Modify : 0x0
[ 44.172669] AXI ID : 0x0
[ 44.174712] Master ID : 齵京?
[ 44.176765] Security Group(GRPSEC): 0x0
[ 44.178796] Cache : 0x0 – Non-cacheable/Non-Bufferable)
[ 44.180918] Protection : 0x0 – Unprivileged, Secure, Data Access
[ 44.183045] FALCONSEC : 0x0
[ 44.185117] Virtual Queuing Channel(VQC): 0x0
[ 44.188545] **************************************
[ 44.193534] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Errors
[ 44.201437] **************************************
[ 44.206481] RAS Error in SCF:IOB, ERRSELR_EL1=1025:
[ 44.211215] Status = 0xfc009604
[ 44.214538] IERR = CBB Interface Error: 0x96
[ 44.219259] SERR = Assertion Failure: 0x4
[ 44.223457] Overflow (there may be more errors) - Uncorrectable
[ 44.229061] Uncorrectable (this is fatal)
[ 44.233270] MISC0 = 0x40
[ 44.235801] MISC1 = 0x2646444463
[ 44.239473] ADDR = 0x800000001404000c
[ 44.243414] **************************************
[ 44.248310] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectable Errors
[ 44.257697] **************************************
[ 44.262569] RAS Error in L2, ERRSELR_EL1=528:
[ 44.267033] Status = 0xfc006612
[ 44.270272] IERR = SCF to L2 Slave Error Read: 0x66
[ 44.275086] SERR = Error response from slave: 0x12
[ 44.279980] Overflow (there may be more errors) - Uncorrectable
[ 44.285755] Uncorrectable (this is fatal)
[ 44.289877] MISC0 = 0x100000000400000
[ 44.293550] MISC1 = 0x40240000000
[ 44.296966] ADDR = 0x800000001404000c
[ 44.300816] **************************************
[ 44.306016] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
[ 44.314078] Bad mode in Error handler detected on CPU3, code 0xbe000000 – SError
[ 44.321374] Internal error: Oops - bad mode: 0 [#6] PREEMPT SMP
[ 44.327234] Modules linked in:
[ 44.332144] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D W 4.9.201-tegra #1
[ 44.337825] Hardware name: Jetson-AGX (DT)
[ 44.341762] task: ffffffc7dbc44600 task.stack: ffffffc7dbc58000
[ 44.347975] PC is at tegra_read_chipid+0x58/0xa8
[ 44.352697] LR is at tegra_read_chipid+0x28/0xa8
[ 44.357335] pc : [] lr : [] pstate: 408000c5
[ 44.364769] sp : ffffffc7dbc5be50
[ 44.368011] x29: ffffffc7dbc5be50 x28: 0000000000000001
[ 44.375199] x27: ffffff8009e66000 x26: ffffff8009831ac0
[ 44.381232] x25: 0000000000000000 x24: 0000000405ba7880
[ 44.386760] x23: ffffff8009fd8658 x22: ffffffc7ffd10ac8
[ 44.392445] x21: ffffff8009fd8670 x20: ffffff800a19c148
[ 44.398300] x19: ffffff800a19c148 x18: 00000000ffffffeb
[ 44.404081] x17: 0000000000000000 x16: 000000000000000e
[ 44.409515] x15: 0000000000000000 x14: 0000000000000001
[ 44.415205] x13: 0000000000000f99 x12: 071c71c71c71c71c
[ 44.420813] x11: 000000000000000b x10: 0101010101010101
[ 44.426692] x9 : fffffffffffffffb x8 : 7f7f7f7f7f7f7f7f
[ 44.432147] x7 : fefefeff646c606d x6 : 00170401e9e1acf4
[ 44.437669] x5 : 742c616901041700 x4 : 8080808000000000
[ 44.443272] x3 : b34b234b0963a000 x2 : 000000000000000b
[ 44.448364] x1 : ffffffc7dbc44600 x0 : 0000000000021917
[ 44.453693]
[ 44.455780] Process swapper/3 (pid: 0, stack limit = 0xffffffc7dbc58000)
[ 44.459969] Call trace:
[ 44.462340] [] tegra_read_chipid+0x58/0xa8
[ 44.467675] [] tegra_get_platform+0x14/0x80
[ 44.472755] [] t19x_cpu_enter_state+0x1c/0x118
[ 44.478613] [] cpuidle_enter_state+0x84/0x380
[ 44.484215] [] cpuidle_enter+0x34/0x48
[ 44.489030] [] call_cpuidle+0x44/0x70
[ 44.493842] [] cpu_startup_entry+0x1b0/0x200
[ 44.499444] [] secondary_start_kernel+0x190/0x1f8
[ 44.505560] [<0000000080f6e1a4>] 0x80f6e1a4
[ 44.509328] —[ end trace f561c186fb0590fc ]—
[ 48.560970] **************************************
[ 48.563046] * For more Internal Decode Help
[ 48.565065] * http://nv/cbberr
[ 48.567070] * NVIDIA userID is required to access
[ 48.569100] **************************************
[ 48.571105] CPU:0, Error:CBB-NOC
[ 48.573028] Error Logger : 1
[ 48.574956] ErrLog0 : 0x80030600
[ 48.576883] Transaction Type : RD - Read, Incrementing
[ 48.578848] Error Code : TMO
[ 48.580771] Error Source : Target NIU
[ 48.582707] Error Description : Target time-out error
[ 48.584660] Packet header Lock : 0
[ 48.586571] Packet header Len1 : 3
[ 48.588454] NOC protocol version : version >= 2.7
[ 48.590380] ErrLog1 : 0x240156
[ 48.592275] ErrLog2 : 0x0
[ 48.594104] RouteId : 0x240156
[ 48.595938] InitFlow : bpmp_p2ps/I/bpmp_p2ps
[ 48.597782] Targflow : gpu_p2pm/T/gpu_p2pm
[ 48.599604] TargSubRange : 0
[ 48.601376] SeqId : 0
[ 48.603116] ErrLog3 : 0x20c
[ 48.604836] ErrLog4 : 0x0
[ 48.606535] Address : 0x1700020c (unknown device)
[ 48.608314] ErrLog5 : 0x5599f470
[ 48.610023] Non-Modify : 0x1
[ 48.611706] AXI ID : 0xab
[ 48.613363] Master ID : BPMP
[ 48.615027] Security Group(GRPSEC): 0x7d
[ 48.616701] Cache : 0x0 – Non-cacheable/Non-Bufferable)
[ 48.618408] Protection : 0x3 – Privileged, Non-Secure, Data Access
[ 48.620161] FALCONSEC : 0x0
[ 48.621851] Virtual Queuing Channel(VQC): 0x0
[ 48.623591] **************************************
[ 48.625365] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Errors
[ 48.627279] **************************************
[ 48.629110] RAS Error in SCF:IOB, ERRSELR_EL1=1025:
[ 48.630944] Status = 0xfc009604
[ 48.634238] IERR = CBB Interface Error: 0x96
[ 48.638524] SERR = Assertion Failure: 0x4
[ 48.642548] Overflow (there may be more errors) - Uncorrectable
[ 48.647979] Uncorrectable (this is fatal)
[ 48.652269] MISC0 = 0x40
[ 48.654887] MISC1 = 0x264a4444e1
[ 48.658302] ADDR = 0x800000001404000c
[ 48.661983] **************************************
[ 48.666797] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectable Errors
[ 48.676422] **************************************
[ 48.681314] RAS Error in L2, ERRSELR_EL1=512:
[ 48.685774] Status = 0xfc006612
[ 48.689011] IERR = SCF to L2 Slave Error Read: 0x66
[ 48.693825] SERR = Error response from slave: 0x12
[ 48.698725] Overflow (there may be more errors) - Uncorrectable
[ 48.704243] Uncorrectable (this is fatal)
[ 48.708617] MISC0 = 0x80000000400000
[ 48.712029] MISC1 = 0x20240000000
[ 48.715703] ADDR = 0x800000001404000c
[ 48.719553] **************************************
[ 48.724512] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
[ 48.732557] Bad mode in Error handler detected on CPU0, code 0xbe000000 – SError
[ 48.739852] Internal error: Oops - bad mode: 0 [#7] PREEMPT SMP
[ 48.745455] Modules linked in:
[ 48.750240] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G D W 4.9.201-tegra #1
[ 48.756298] Hardware name: Jetson-AGX (DT)
[ 48.760503] task: ffffff8009e713c0 task.stack: ffffff8009e60000
[ 48.766195] PC is at __do_softirq+0xb8/0x3b0
[ 48.770657] LR is at __do_softirq+0x74/0x3b0
[ 48.775031] pc : [] lr : [] pstate: 40400045
[ 48.782901] sp : ffffffc7ffcc0f10
[ 48.786137] x29: ffffffc7ffcc0f10 x28: ffffff8009e713c0
[ 48.793370] x27: ffffff8009e66000 x26: ffffffc7ffcc1050
[ 48.798897] x25: ffffff8009826018 x24: ffffffc7dc410800
[ 48.804924] x23: ffffff8009e63d30 x22: 0000000000000000
[ 48.810354] x21: 0000000000000000 x20: 0000000000000282
[ 48.816292] x19: ffffff8009e713c0 x18: 0000000000000020
[ 48.821986] x17: 0000000000000000 x16: 000000000000000e
[ 48.827671] x15: ffffffffffffffff x14: 00001e8480000000
[ 48.833114] x13: 00000000000000da x12: 0000000000000000
[ 48.838815] x11: ffffff8008f899d0 x10: ffffff8009e66000
[ 48.844489] x9 : ffffff8008f899d8 x8 : 00000000000000da
[ 48.850001] x7 : ffffff800a147cd8 x6 : 00000000139c1d2e
[ 48.855760] x5 : 00ffffffffffffff x4 : 0000000000000015
[ 48.860856] x3 : 0000000000000001 x2 : 00000047f6497000
[ 48.866452] x1 : ffffff800a143840 x0 : 0000000000000000
[ 48.871795]
[ 48.873770] Process swapper/0 (pid: 0, stack limit = 0xffffff8009e60000)
[ 48.877924] Call trace:
[ 48.880292] [] __do_softirq+0xb8/0x3b0
[ 48.885370] [] irq_exit+0xd0/0x118
[ 48.889917] [] __handle_domain_irq+0x6c/0xc0
[ 48.895515] [] gic_handle_irq+0x5c/0xb0
[ 48.900590] [] el1_irq+0xe8/0x194
[ 48.905145] [] cpuidle_enter_state+0xb8/0x380
[ 48.910571] [] cpuidle_enter+0x34/0x48
[ 48.915820] [] call_cpuidle+0x44/0x70
[ 48.920632] [] cpu_startup_entry+0x1b0/0x200
[ 48.926492] [] rest_init+0x84/0x90
[ 48.930785] [] start_kernel+0x384/0x398
[ 48.936206] [] __primary_switched+0x80/0x94
[ 48.941894] —[ end trace f561c186fb0590fd ]—
[ 52.979460] **************************************
[ 52.981472] * For more Internal Decode Help
[ 52.983418] * http://nv/cbberr
[ 52.985326] * NVIDIA userID is required to access
[ 52.987264] **************************************
[ 52.989204] CPU:1, Error:CBB-NOC
[ 52.991107] Error Logger : 0
[ 52.993002] ErrLog0 : 0x80030000
[ 52.994873] Transaction Type : RD - Read, Incrementing
[ 52.996797] Error Code : SLV
[ 52.998678] Error Source : Target
[ 53.000560] Error Description : Target error detected by CBB slave
[ 53.002527] AXI2APB_0 bridge error: SFIFONE - Status FIFO Not Empty interrupt[ 53.002715] AXI2APB_0 bridge error: SFIFOF - Status FIFO Full interrupt
[ 53.004751] AXI2APB_0 bridge error: TIM - Timer(Timeout) interrupt[ 53.004929] Packet header Lock : 0
[ 53.006930] Packet header Len1 : 3
[ 53.008933] NOC protocol version : version >= 2.7
[ 53.010935] ErrLog1 : 0x320028
[ 53.012891] ErrLog2 : 0x0
[ 53.014811] RouteId : 0x320028
[ 53.016717] InitFlow : ccroc_p2ps/I/ccroc_p2ps
[ 53.018615] Targflow : axis_satellite_grout/T/axis_satellite_grout
[ 53.020561] TargSubRange : 0
[ 53.022476] SeqId : 0
[ 53.024348] ErrLog3 : 0x1404000c
[ 53.026200] ErrLog4 : 0x0
[ 53.028030] Address : 0x1404000c – /cv-noc@14040000 + 0xc
[ 53.029967] ErrLog5 : 0xa09f851
[ 53.031852] Non-Modify : 0x1
[ 53.033718] AXI ID : 0x14
[ 53.035560] Master ID : CCPLEX
[ 53.037404] Security Group(GRPSEC): 0x7e
[ 53.039297] Cache : 0x1 – Device
[ 53.041164] Protection : 0x2 – Unprivileged, Non-Secure, Data Access
[ 53.043134] FALCONSEC : 0x0
[ 53.045038] Virtual Queuing Channel(VQC): 0x0
[ 53.048735] **************************************
[ 53.053978] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Errors
[ 53.062234] **************************************
[ 53.066845] RAS Error in SCF:IOB, ERRSELR_EL1=1025:
[ 53.071658] Status = 0xfc009604
[ 53.075328] IERR = CBB Interface Error: 0x96
[ 53.079615] SERR = Assertion Failure: 0x4
[ 53.083556] Overflow (there may be more errors) - Uncorrectable
[ 53.089500] Uncorrectable (this is fatal)
[ 53.093708] MISC0 = 0x40
[ 53.096069] MISC1 = 0x264a4445e3
[ 53.099742] ADDR = 0x800000001404000c
[ 53.103506] **************************************
[ 53.108237] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectable Errors
[ 53.117862] **************************************
[ 53.122753] RAS Error in L2, ERRSELR_EL1=512:
[ 53.127216] Status = 0xfc006612
[ 53.130195] IERR = SCF to L2 Slave Error Read: 0x66
[ 53.135008] SERR = Error response from slave: 0x12
[ 53.139907] Overflow (there may be more errors) - Uncorrectable
[ 53.145939] Uncorrectable (this is fatal)
[ 53.150057] MISC0 = 0x100000000400000
[ 53.153994] MISC1 = 0x40240000000
[ 53.157404] ADDR = 0x800000001404000c
[ 53.160999] **************************************
[ 53.166217] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
[ 53.173995] Bad mode in Error handler detected on CPU1, code 0xbe000000 – SError
You can run “sudo tegrastats” and decrease your working temperature gradually. It shall tell us whether it is dead in -25 or something lower.
