Hi Jerry,
- We click the power off icon on Ubuntu.
- We can’t get anything by dmesg --follow, below is the serial console log.
And finally, AGX auto reboot.
nvidia@nvidia-desktop:~$
nvidia@nvidia-desktop:~$ [ 1216.377404] systemd-shutdow: 41 output lines suppressed due to ratelimiting
[ 1217.407081] CPU1: shutdown
[ 1217.449728] CPU2: shutdown
[ 1217.514500] CPU3: shutdown
[ 1217.578996] CPU4: shutdown
[ 1217.626171] CPU5: shutdown
榳ARNING: at platform/drivers/mailbox/mail_mach.c:148
WARNING: at platform/drivers/mailbox/mail_mach.c:161
WARNING: at platform/drivers/mailbox/mail_mach.c:177
[0000.054] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.063] I> MB1 (prd-version: 1.5.1.3-t194-41334769-d2a21c57)
[0000.068] I> Boot-mode: Coldboot
[0000.071] I> Chip revision : A02P
[0000.074] I> Bootrom patch version : 15 (correctly patched)
[0000.079] I> ATE fuse revision : 0x200
[0000.083] I> Ram repair fuse : 0x0
[0000.086] I> Ram Code : 0x2
[0000.088] I> rst_source : 0x2
[0000.091] I> rst_level : 0x1
[0000.095] I> Boot-device: eMMC
[0000.109] I> sdmmc DDR50 mode
[0000.114] W> No valid slot number is found in scratch register
[0000.119] W> Return default slot: _a
[0000.122] I> Active Boot chain : 0
[0000.126] I> Boot-device: eMMC
[0000.129] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.135] I> Temperature = 42000
[0000.138] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.143] W> Skipping boost for clk: BPMP_APB
[0000.147] W> Skipping boost for clk: AXI_CBB
[0000.151] W> Skipping boost for clk: AON_CPU_NIC
[0000.155] W> Skipping boost for clk: CAN1
[0000.159] W> Skipping boost for clk: CAN2
[0000.163] I> Boot-device: eMMC
[0000.166] I> Boot-device: eMMC
[0000.175] I> Sdmmc: HS400 mode enabled
[0000.180] I> ECC region[0]: Start:0x0, End:0x0
[0000.184] I> ECC region[1]: Start:0x0, End:0x0
[0000.188] I> ECC region[2]: Start:0x0, End:0x0
[0000.192] I> ECC region[3]: Start:0x0, End:0x0
[0000.196] I> ECC region[4]: Start:0x0, End:0x0
[0000.200] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.206] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.211] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.215] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.219] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.225] E> FAILED: Thermal config
[0000.232] E> FAILED: MEMIO rail config
[0000.251] I> Boot-device: eMMC
[0000.261] I> sdmmc bdev is already initialized
[0000.332] I> MB1 done
?跩ain enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.340] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-389501e9)
[0000.341] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.341] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.342] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.348] W> device prod register failed
[0000.352] I> Boot-device: eMMC
[0000.354] I> Boot_device: SDMMC_BOOT instance: 3
[0000.360] I> sdmmc-3 params source = boot args
[0000.363] I> sdmmc bdev is already initialized
[0000.367] I> sdmmc-3 params source = boot args
[0000.376] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.382] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.383] W> No valid slot number is found in scratch register
[0000.388] W> Return default slot: _a
[0000.392] I> Active Boot chain : 0
[0000.395] I> parsing oem signed section of bpmp-fw header done
[0000.401] I> bpmp-fw binary init read from storage
[0000.406] I> oem authentication of bpmp-fw header done
[0000.412] I> bpmp-fw binary done read from storage
[0000.415] I> bpmp-fw: Authentication init Done
[0000.420] I> parsing oem signed section of cpubl header done
[0000.425] I> cpubl binary init read from storage
[0000.429] I> bpmp-fw: Authentication Finalize Done
[0000.434] I> oem authentication of cpubl header done
[0000.439] I> cpubl binary done read from storage
[0000.443] I> cpubl: Authentication init Done
[0000.448] I> parsing oem signed section of rce header done
[0000.453] I> rce binary init read from storage
[0000.457] I> Relocating BR-BCT
[0000.460] I> cpubl: Authentication Finalize Done
[0000.464] I> oem authentication of rce header done
[0000.469] I> rce binary done read from storage
[0000.473] I> rce: Authentication init Done
[0000.478] I> parsing oem signed section of ape header done
[0000.482] I> ape binary init read from storage
[0000.487] I> rce: Authentication Finalize Done
[0000.491] I> oem authentication of ape header done
[0000.496] I> ape binary done read from storage
[0000.500] I> ape: Authentication init Done
[0000.506] I> parsing oem signed section of tos header done
[0000.509] I> tos binary init read from storage
[0000.513] I> ape: Authentication Finalize Done
[0000.518] I> oem authentication of tos header done
[0000.522] I> tos binary done read from storage
[0000.527] I> tos: Authentication init Done
[0000.532] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.537] I> bpmp-fw-dtb binary init read from storage
[0000.542] I> tos: Authentication Finalize Done
[0000.548] I> oem authentication of bpmp-fw-dtb header done
[0000.554] I> bpmp-fw-dtb binary done read from storage
[0000.556] I> bpmp-fw-dtb: Authentication init Done
[0000.561] I> parsing oem signed section of cpubl-dtb header done
[0000.567] I> cpubl-dtb binary init read from storage
[0000.572] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.609] I> oem authentication of cpubl-dtb header done
[0000.610] I> cpubl-dtb binary done read from storage
[0000.610] I> cpubl-dtb: Authentication init Done
[0000.612] I> parsing oem signed section of eks header done
[0000.613] I> eks binary init read from storage
[0000.613] I> cpubl-dtb: Authentication Finalize Done
[0000.614] I> oem authentication of eks header done
[0000.618] I> eks binary done read from storage
[0000.622] I> eks: Authentication init Done
[0000.626] I> eks: Authentication Finalize Done
[0000.630] I> EKB detected (length: 0x410) @ VA:0x5270a400
誏OTICE: BL31: v1.3(release):de895fd9e
NOTICE: BL31: Built : 12:15:31, Oct 16 2020
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 182: key_mgnt_processing …
hwkey-agent: 157: Init hweky-agent services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is 57f8a77779f848bf2ecf21dabee5645f
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
mrq initialized
[0001.133] I> Welcome to Cboot
殞mon_post initialized
墁0001.134] I> Cboot Version: t194-aad9d75e
[0001.134] I> CPU-BL Params @ 0xf2820000
[0001.134] I> 0) Base:0x00000000 Size:0x00000000
[0001.138] I> 1) Base:0xf1100000 Size:0x00100000
[0001.142] I> 2) Base:0xf2000000 Size:0x00200000
[0001.147] I> 3) Base:0xf1200000 Size:0x00200000
歊lk_set_parent failed for clk can1, parent pll_aon (-22)
clk_set_parent failed for clk can2, parent pll_aon (-22)
clk_set_parent failed for clk dmic5, parent pll_aon (-22)
clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_set_parent failed for clk spi2, parent pll_aon (-22)
clk_set_parent failed for clk pwm4, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
墁0001.151] I> 4) Base:0xf1000000 Size:0x00100000
[0001.256] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.261] I> 6) Base:0xf3800000 Size:0x00400000
[0001.265] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.270] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.274] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.278] I> 10) Base:0xf3000000 Size:0x00800000
[0001.283] I> 11) Base:0x40000000 Size:0x00040000
[0001.287] I> 12) Base:0xf0c00000 Size:0x00100000
歋mc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] 墁0001.292] I> 13) Base:0x40046000 Size:0x00002000
[0001.347] I> 14) Base:0x40048000 Size:0x00002000
[0001.351] I> 15) Base:0xac000000 Size:0x00004000
[0001.356] I> 16) Base:0x4004a000 Size:0x00002000
[0001.360] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.365] I> 18) Base:0x4004c000 Size:0x00002000
[0001.369] I> 19) Base:0xf2200000 Size:0x00600000
[0001.374] I> 20) Base:0x4004e000 Size:0x00002000
[0001.378] I> 21) Base:0xf09d0000 Size:0x0000c000
[0001.382] I> 22) Base:0x00000000 Size:0x00000000
[0001.387] I> 23) Base:0xf09e0000 Size:0x00020000
[0001.391] I> 24) Base:0xf6000000 Size:0x02000000
[0001.396] I> 25) Base:0x40050000 Size:0x00002000
[0001.400] I> 26) Base:0x40040000 Size:0x00006000
[0001.405] I> 27) Base:0xf1800000 Size:0x00400000
[0001.409] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.414] I> 29) Base:0xf1400000 Size:0x00400000
[0001.418] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.423] I> 31) Base:0x00000000 Size:0x00000000
[0001.427] I> 32) Base:0xf8000000 Size:0x08000000
[0001.432] I> 33) Base:0x00000000 Size:0x00000000
[0001.436] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.440] I> 35) Base:0xab000000 Size:0x01000000
[0001.445] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.449] I> 37) Base:0xf2800000 Size:0x00800000
[0001.454] I> 38) Base:0x80000000 Size:0x20000000
[0001.458] I> 39) Base:0xb0000000 Size:0x08000000
[0001.463] I> 40) Base:0x00000000 Size:0x00000000
[0001.467] I> 41) Base:0x00000000 Size:0x00000000
[0001.472] I> 42) Base:0x00000000 Size:0x00000000
[0001.476] I> 43) Base:0x00000000 Size:0x00000000
[0001.481] I> 44) Base:0x00000000 Size:0x00000000
[0001.485] I> 45) Base:0x00000000 Size:0x00000000
[0001.490] GIC-SPI Target CPU: 0
[0001.493] Interrupts Init done
[0001.495] calling constructors
[0001.498] initializing heap
[0001.501] I> Heap: [0xa0691568 … 0xab000000]
[0001.505] initializing threads
[0001.508] initializing timers
[0001.511] creating bootstrap completion thread
[0001.515] top of bootstrap2()
[0001.518] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.523] initializing platform
[0001.526] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.531] W> device prod register failed
[0001.535] I> Bl_dtb @0xaaf00000
[0001.540] W> “plugin-manager” doesn’t exist, creating
[0001.543] W> “ids” doesn’t exist, creating
[0001.547] W> “connection” doesn’t exist, creating
[0001.551] W> “configs” doesn’t exist, creating
[0001.559] I> Find /i2c@3160000’s alias i2c0
[0001.559] I> Reading eeprom i2c=0 address=0x50
[0001.589] I> Device at /i2c@3160000:0x50
[0001.589] I> Reading eeprom i2c=0 address=0x56
[0001.614] I> Device at /i2c@3160000:0x56
[0001.615] I> Find /i2c@3180000’s alias i2c2
[0001.616] I> Reading eeprom i2c=2 address=0x54
[0001.620] E> I2C: slave not found in slaves.
[0001.620] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.621] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.622] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.628] E> eeprom: Failed to read I2C slave device
[0001.633] I> Eeprom read failed 0x3526070d
[0001.637] I> Reading eeprom i2c=2 address=0x57
[0001.647] E> I2C: Timeout while polling for transfer complete. Last value 0x00000002.
[0001.649] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.656] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.662] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.671] E> eeprom: Failed to read I2C slave device
[0001.676] I> Eeprom read failed 0x35260706
[0001.680] I> Reading eeprom i2c=2 address=0x52
[0001.691] E> I2C: Timeout while polling for transfer complete. Last value 0x00000002.
[0001.692] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.700] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.706] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0001.715] E> eeprom: Failed to read I2C slave device
[0001.720] I> Eeprom read failed 0x35260706
[0001.725] I> Find /i2c@c240000’s alias i2c1
[0001.728] I> Reading eeprom i2c=1 address=0x52
[0001.734] E> I2C: slave not found in slaves.
[0001.736] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.744] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.750] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.759] E> eeprom: Retry to read I2C slave device.
[0001.764] E> I2C: slave not found in slaves.
[0001.768] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.776] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.782] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.791] E> eeprom: Failed to read I2C slave device
[0001.796] I> Eeprom read failed 0x3526070d
[0001.800] I> Reading eeprom i2c=1 address=0x50
[0001.804] E> I2C: slave not found in slaves.
[0001.808] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.816] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.822] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.831] E> eeprom: Retry to read I2C slave device.
[0001.836] E> I2C: slave not found in slaves.
[0001.840] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.848] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.853] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.863] E> eeprom: Failed to read I2C slave device
[0001.868] I> Eeprom read failed 0x3526070d
[0001.872] I> create_pm_ids: id: 2888-0004-400-M, len: 15
[0001.877] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.888] I> create_pm_ids: id: XXXX-XXXX-XXX-X, len: 15
[0001.893] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff, len: 93
[0001.904] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0001.912] W> “i2c@3160000” doesn’t exist, creating
[0001.916] W> “module@0x50” doesn’t exist, creating
[0001.921] I> Adding plugin-manager/ids/XXXX-XXXX-XXX=/i2c@3160000:module@0x56
[0001.928] W> “module@0x56” doesn’t exist, creating
[0001.933] I> Adding plugin-manager/cvm
[0001.936] W> “chip-id” doesn’t exist, creating
[0001.940] I> Adding plugin-manager/chip-id/A02P
[0001.944] I> Plugin-manager override starting
[0001.949] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.957] I> node /plugin-manager/fragement-soft-wdt matches
[0001.965] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.969] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0001.975] I> Disable plugin-manager status in FDT
[0001.976] I> Plugin-manager override finished successfully
[0001.981] I> gpio framework initialized
[0001.986] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driver
[0001.993] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
[0002.000] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.007] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.015] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.022] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.028] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.035] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.043] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.050] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.057] I> fixed regulator driver initialized
[0002.065] I> register ‘maxim’ power off handle
[0002.065] I> virtual i2c enabled
[0002.068] I> registered ‘maxim,max20024’ pmic
[0002.072] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0002.079] I> Boot-device: eMMC
[0002.081] I> Boot_device: SDMMC_BOOT instance: 3
[0002.090] I> sdmmc-3 params source = boot args
[0002.090] I> create_pm_ids: id: 2888-0004-400-M, len: 15
[0002.095] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.106] I> create_pm_ids: id: XXXX-XXXX-XXX-X, len: 15
[0002.112] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff, len: 93
[0002.123] I> sdmmc bdev is already initialized
[0002.127] I> sdmmc-3 params source = boot args
[0002.157] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.170] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.177] I> enabling ‘vdd-hdmi-5v0’ regulator
[0002.181] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.182] I> hdmi cable connected
[0002.183] W> set volts not configured for ‘vdd-1v0’
[0002.184] W> set volts not configured for ‘vdd-1v8-hs’
[0002.188] E> invalid display type
[0002.191] E> invalid display type
[0002.192] E> cannot find any other nvdisp nodes
[0002.207] I> edid read success
[0002.219] I> edid read success
[0002.220] I> width = 640, height = 480, frequency = 25174825
[0002.221] I> width = 640, height = 480, frequency = 25174825
[0002.221] I> width = 1920, height = 1080, frequency = 148500000
[0002.225] I> width = 1920, height = 1080, frequency = 138500000
[0002.231] I> width = 1920, height = 1080, frequency = 148351648
[0002.236] I> width = 1280, height = 720, frequency = 74175824
[0002.242] I> width = 720, height = 480, frequency = 26973026
[0002.248] I> width = 720, height = 480, frequency = 26973026
[0002.253] I> width = 640, height = 480, frequency = 25174825
[0002.259] I> width = 720, height = 576, frequency = 26973026
[0002.264] I> width = 720, height = 576, frequency = 26973026
[0002.270] I> width = 1280, height = 720, frequency = 74175824
[0002.275] I> width = 1920, height = 1080, frequency = 148351648
[0002.281] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.291] I> hdmi_enable, starting HDMI initialisation
[0002.296] I> hdmi_enable, HDMI initialisation complete
[0002.306] I> Load in CBoot Boot Options partition and parse it
[0002.312] E> Error -9 when finding node with path /boot-configuration
[0002.313] E> tegrabl_cbo_parse_info: “boot-configuration” not found in CBO file.
[0002.316] I> Hit any key to stop autoboot: 4 3 2 1
[0004.324] initializing target
[0004.324] calling apps_init()
[0004.325] starting app kernel_boot_app
[0004.344] I> found decompressor handler: lz4-legacy
[0004.345] I> decompressing BMP blob …
[0004.348] I> Kernel type = Normal
[0004.349] I> Loading kernel-bootctrl from partition
[0004.349] I> Loading partition kernel-bootctrl at 0xa4ac0000 from device(0x1)
[0004.356] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.356] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.357] I> ########## SD boot ##########
[0004.361] I> No sdcard
[0004.363] I> -0 params source =
[0004.366] E> Blockdev open: exit error
[0004.369] E> SD boot failed, err: 724238353
[0004.373] I> ########## USB boot ##########
[0004.382] W> No valid slot number is found in scratch register
[0004.383] W> Return default slot: _a
[0004.399] I> USB Firmware Version: 60.06 release
[0004.453] I> regulator of usb2-0 already enabled
[0004.457] I> regulator of usb2-1 already enabled
[0004.461] I> regulator of usb2-2 already enabled
[0004.466] I> enabling ‘vdd-5v-sata’ regulator
[0005.532] I> USB 2.0 port 4 new high-speed USB device detected
[0005.534] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa0ea0800, cmd_ring.dma = 0xa0ea0840
[0005.634] I> Start to enumerate device
[0005.636] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa0ea0800, cmd_ring.dma = 0xa0ea0840
[0005.641] I>
[0005.641] I> Enumerated USB Device 05e3:0610
[0005.641] I>
[0005.642] I> Hub:
[0005.642] I> Downstream ports : 4
[0005.643] I> Power switching : Ganged
[0005.643] I> Compound device : No
[0005.643] I> Over-current protection : Global
[0005.647] I> Hub avg delay : 4 ns
[0005.652] I> Set interface = 1 (alt setting)
[0005.657] I> Enable hub ports
[0005.664] I> Device detected on port 1
[0005.667] I> Device detected on port 4
[0006.178] I> Reset port 1
[0006.233] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa0ea0800, cmd_ring.dma = 0xa0ea0840
[0006.334] I> Start to enumerate device
[0006.335] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa0ea0800, cmd_ring.dma = 0xa0ea0840
[0006.339] I> This device is non-MSD, skip enumeration
[0006.341] I> Reset port 4
[0006.397] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa0ea0800, cmd_ring.dma = 0xa0ea0840
[0006.498] I> Start to enumerate device
[0006.499] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa0ea0800, cmd_ring.dma = 0xa0ea0840
[0006.503] I> This device is non-MSD, skip enumeration
[0006.503] E> failed to start xhci controller
[0006.503] E> Error in init of XUSB host driver, err: 7979000d
[0006.504] E> Failed to initialize device 5-0
[0006.504] E> USB boot failed, err: 2037973005
[0006.509] I> ########## Fixed storage boot ##########
[0006.513] I> Already published: 00010003
[0006.517] I> Look for boot partition
[0006.521] I> Fallback: assuming 0th partition is boot partition
[0006.526] I> Detect filesystem
[0006.554] I> Loading extlinux.conf …
[0006.554] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0006.591] I> L4T boot options
[0006.591] I> [1]: “primary kernel”
[0006.591] I> Enter choice:
[0009.592] I> Continuing with default option: 1
[0009.592] I> Loading kernel sig file from rootfs …
[0009.592] I> rootfs path: /sdmmc_user/boot/Image.sig
[0009.611] I> Loading kernel binary from rootfs …
[0009.611] I> rootfs path: /sdmmc_user/boot/Image
[0009.857] I> Validate kernel …
[0009.857] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0010.185] I> No kernel-dtb binary path
[0010.185] W> No valid slot number is found in scratch register
[0010.186] W> Return default slot: _a
[0010.186] I> A/B: bin_type (38) slot 0
[0010.186] I> Loading kernel-dtb from partition
[0010.187] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0010.196] I> Validate kernel-dtb …
[0010.196] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0010.200] I> Loading ramdisk from rootfs …
[0010.201] I> rootfs path: /sdmmc_user/boot/initrd
[0010.254] I> Kernel hdr @0xa4ac0000
[0010.254] I> Kernel dtb @0x90000000
[0010.255] I> decompressor handler not found
[0010.255] I> Copying kernel image (34209808 bytes) from 0xa4ac0000 to 0x80080000 … [0010.265] I> Done
[0010.266] I> Updated bpmp info to DTB
[0010.267] I> Ramdisk: Base: 0x92000000; Size: 0x54eb56
[0010.267] I> Updated initrd info to DTB
[0010.267] W> WARN: Fail to override “console=none” in commandline
[0010.268] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0010.274] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0010.282] W> No valid slot number is found in scratch register
[0010.287] W> Return default slot: _a
[0010.291] I> Active slot suffix:
[0010.294] I> add_boot_slot_suffix: slot_suffix =
[0010.298] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa069d000 lut_mem=0x2008@0xa0697000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0010.334] I> Updated bootarg info to DTB
[0010.338] W> MAC addr invalid!
[0010.340] E> Failed to get WIFI MAC address
[0010.344] W> MAC addr invalid!
[0010.347] E> Failed to get Bluetooth MAC address
[0010.352] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:3d:af:47
[0010.358] W> “plugin-manager” doesn’t exist, creating
[0010.363] I> Adding /chosen/plugin-manager/cvm
[0010.367] W> “chip-id” doesn’t exist, creating
[0010.371] I> Adding /chosen/plugin-manager/chip-id
[0010.376] W> “configs” doesn’t exist, creating
[0010.380] I> Adding /chosen/plugin-manager/configs
[0010.385] W> “ids” doesn’t exist, creating
[0010.389] I> Adding /chosen/plugin-manager/ids
[0010.393] W> “odm-data” doesn’t exist, creating
[0010.398] I> Adding /chosen/plugin-manager/odm-data
[0010.404] W> “memory” doesn’t exist, creating
[0010.407] I> [0] START: 0x80000000, END: 0xac000000
[0010.411] I> [1] START: 0xac004000, END: 0xf09d0000
[0010.416] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0010.421] I> dram_block larger than 80000000
[0010.425] I> [3] START: 0x100000000, END: 0x880000000
[0010.430] I> added [base:0x80000000, size:0x2c000000] to /memory
[0010.435] I> added [base:0xac200000, size:0x44600000] to /memory
[0010.441] I> added [base:0x100000000, size:0x780000000] to /memory
[0010.448] I> Updated memory info to DTB
[0010.451] E> add_disp_param: failed to get display params for du=1
[0010.457] W> “reset” doesn’t exist, creating
[0010.462] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0010.466] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0010.471] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0010.475] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0010.480] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0010.485] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0010.490] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0010.494] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0010.500] W> “misc-data” doesn’t exist, creating
[0010.503] I> Boot-device: eMMC
[0010.506] I> Add boot-sdmmc to plugin-manager/misc-data
[0010.511] I> Add storage-sdmmc to plugin-manager/misc-data
[0010.517] W> Unknown storage device
[0010.520] I> Add serial number:1421421059695 as DT property
[0010.526] I> Plugin-manager override starting
[0010.530] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0010.537] I> node /plugin-manager/fragement-soft-wdt matches
[0010.543] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0010.548] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0010.554] I> Disable plugin-manager status in FDT
[0010.557] I> Plugin-manager override finished successfully
[0010.563] I> tegrabl_load_kernel_and_dtb: Done
[0010.585] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (steven@ai-cradle) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #6 SMP PREEMPT Mon Dec 6 09:06:48 CST 2021
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44600000
[ 0.000000] OF: fdt: - 100000000 , 780000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a069d000
[ 0.000000] Found lut_mem: 00002008@a0697000
[ 1.887847] tegra-xudc-new 3550000.xudc: extcon_get_extcon_dev_by_cable failed -19
榳ARNING: pll_d3 has no dyn ramp
墁 4.582676] cgroup: cgroup2: unknown option “nsdelegate”
[ 5.991156] random: crng init done
[ 5.991284] random: 7 urandom warning(s) missed due to ratelimiting
Ubuntu 18.04.5 LTS nvidia-desktop ttyTCU0
nvidia-desktop login:
