After xavier NX is started, the default built-in audio is used. USB external audio needs to be set. How to enable USB audio by default after every boot?
It is setting in Ubuntu. Please check if this helps:
sound - How do you set a default audio output device in Ubuntu? - Ask Ubuntu
