Hello, I am attempting to display the input from an USB Elgato 4K video capture card using gstreamer. My current issue is the command below outputs a black screen.
Do you use IGX developer kit or AGX Xavier developer kit? Would like to confirm which platform you are using. And please share the release version.
The camera preview creates a new window, but it is fully black and I cannot see the input video feed. Similarly the video file is empty after I run the command.
The sensor driver looks not ready. Please check if it needs additional driver for the device. And you may try USB cameras. To check if the issue is specific to the device.
