Hi, I am trying to run a deep learning library and I am getting errors involving CUDA. My GPU is a NVIDIA RTX A1000 Laptop GPU and the current driver is 31.0.15.1801.
I just want confirmation whether my gpu should be able to run CUDA? If so, what do you think the solution is here?
Detect Objects Using Deep Learning
Tool Path
Input Raster hxip_m_3712102_ne4_10_15.tif
Output Detected Objects C:\Users\carmen.gonsalves\OneDrive - California Department of Technology\Documents\ArcGIS\Projects\Deep_Learning_Bldg_FtPnts\Deep_Learning_Bldg_FtPnts.gdb\sd73a73c9_450f_4f20_b0d6_26de7e0c2e23
Model Definition C:\Users\carmen.gonsalves\OneDrive - California Department of Technology\Documents\ArcGIS\Projects\Deep_Learning_Bldg_FtPnts\usa_building_footprints.dlpk
Arguments padding 128;batch_size 4;threshold 0.9;return_bboxes False;test_time_augmentation False;merge_policy mean;tile_size 512
Non Maximum Suppression NMS
Confidence Score Field Confidence
Class Value Field Class
Max Overlap Ratio 0
Processing Mode PROCESS_AS_MOSAICKED_IMAGE
Output Classified Raster
Use pixel space NO_PIXELSPACE
Objects of Interest
Environments
GPU ID 1
Extent 608138.757198425 4200447.78595189 609799.720809342 4201469.73995138 PROJCS[“NAD_1983_2011_UTM_Zone_10N”,GEOGCS[“GCS_NAD_1983_2011”,DATUM[“D_NAD_1983_2011”,SPHEROID[“GRS_1980”,6378137.0,298.257222101]],PRIMEM[“Greenwich”,0.0],UNIT[“Degree”,0.0174532925199433]],PROJECTION[“Transverse_Mercator”],PARAMETER[“False_Easting”,500000.0],PARAMETER[“False_Northing”,0.0],PARAMETER[“Central_Meridian”,-123.0],PARAMETER[“Scale_Factor”,0.9996],PARAMETER[“Latitude_Of_Origin”,0.0],UNIT[“Meter”,1.0]]
Processor Type GPU
Messages
Start Time: Monday, October 6, 2025 3:43:48 PM
Working with cell size 0.150000 (less than 1.00) meter.
ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Unspecified error [Failed to generate table]
[Missing raster: [%s]]
Unable to initialize python raster function with scalar arguments. [C:\Users\CARMEN~2.GON\AppData\Local\Temp\ArcGISProTemp2820\usa_building_footprints.dlpk\ArcGISInstanceDetector.py]
File “C:\Users\CARMEN~2.GON\AppData\Local\Temp\ArcGISProTemp2820\usa_building_footprints.dlpk\ArcGISInstanceDetector.py”, line 162, in initialize
torch.cuda.set_device(device)
File “C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\fastai\torch_core.py”, line 72, in _new_torch_cuda_set_device
_old_torch_cuda_set_device(device)
File “C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\torch\cuda\_init_.py”, line 350, in set_device
torch._C._cuda_setDevice(device)
RuntimeError: CUDA error: invalid device ordinal
CUDA kernel errors might be asynchronously reported at some other API call, so the stacktrace below might be incorrect.
For debugging consider passing CUDA_LAUNCH_BLOCKING=1.
Compile with `TORCH_USE_CUDA_DSA` to enable device-side assertions.
Failed to execute (DetectObjectsUsingDeepLearning).
Failed at Monday, October 6, 2025 3:44:27 PM (Elapsed Time: 38.23 seconds)
