Can I use Jetson Nano 2 GB developer Kit in Jetson Xavier NX carrier board? Will it work? I am asking cause I saw in some documents that the Xavier NX dev board supports Nano modules as well.
Even the same form-factor, and PIN compatible, but the board still have gap, some I/O peripherial might not work well, and not a suggest/support combination.
If that’a Nano 4GB module, then can work.
