Does Jetson Nano 2GB pins module is compatible with Jetson Xavier nx?
Does Jetson Nano 2GB pins module is compatible with Jetson Xavier nx pin module or not?
If I do hardware changes like using developer kit of jetson Xavier and GPU of jetson nano 2gb. Will it be fine or any problem in it?
PLease tell the answers of both the above questions as soon as possible.
  1. They are compatible, please refer to the doc for more info: https://developer.nvidia.com/jetson-xavier-nx-and-jetson-nano-interface-comparison-migration-application-note
  2. Not sure what you mean. How do you implement that?
I am having Jetson Nano 2GB and Jetson Xavier nx.
Can I use the developer Kit of Jetson Xavier nx and module of jetson nano 2GB together?
Thanks for answering
Please refer to the migration application note too.
