Hello everyone. I’m new to the jetson community and I want to know that if it is possible to power on and use tx2 developer kit in MAXN power mode using a 5300 mAh 30C 4S (14.8v) 78.4 Wh Lipo battery.
I appreciate any comments
Hi, the voltage is in the range, it looks fine.
thank you for your reply. one more question is that what’s the max power consumption in MAXN mode? is it probable that the tx2 uses more than 25 Watt in a really full loaded situation?
It depends on the use case. MAXN is just a power profile, the power can be more than 25W.
