Hi.
I am trying to get the camera working, but nothing is working as it should.
The Nano is running Jetpack 4.6.4 with packages all up to date.
So i want to use the full resolution of the IMX219 sensor to get max FOV and best image quality, which is AFAIK 3264x2464@21fps. At least that’s what nvgstcapture tells me.
But when i try to capture images at this resolution using simple_camera.py
from this repository the CPU is at 100%, FPS are about 0.3 and the whole operating system is laggy. So not usable.
And when i use nvgstcapture -m 1 --image-res=5
, nvgstcapture crashes with the following message:
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
ARGUS_ERROR: Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute: 895 Frame Rate specified is greater than supported
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 3264 H = 2464
seconds to Run = 0
Frame Rate = 21.000000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
ARGUS_ERROR: Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute: 1131 InvalidState.
GST_ARGUS: Cleaning up
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD... Exiting...
CONSUMER: ERROR OCCURRED
ERROR on bus: by /GstPipeline:capture_native_pipeline/GstBin:cap_bin/GstNvArgusCameraSrc:nvarguscamerasrc0: CANCELLED
Which is even less usable.
I can’t imagine this is expected behavior, so i rebuilt OpenCV with CUDA support, but that didn’t help.
l4t-jetson-multimedia/-api/-utils are installed, coming from a full install using SDKManager.
Any help is much appreciated, thanks in advance.
Edit: OK, i was able to solve the latter problem by specifically setting the framerate to 21 via an argument, but i wonder why this is necessary in the first place, because the output says it is running at 21frames.
But the issue having extreme frame drops using CSICamera still persists.
