Using SEKONIX SF3326/3324 camera with Jetson AGX Orin
Hi team,
I am planning to use SEKONIX SF3326-100 or SEKONIX SF3324-100 GMSL cameras with Jetson AGX Orin.
Do people have any faced any compatibility / performance issues with them as I see a lot of them getting sold on ebay.
Also, what aftermarket deserializer board is recommended for these?
You need to confirm if vendor provide the driver or not.
If not you need to implement the driver by yourself.
Hey Shane,
Thanks for the reply.
Follow up on that: if I use a deserializer board compatible with Jetson AGX Orin with the above camera, will I still need a driver?
Apologies if the question sounds stupied, I am new to this realm.
Current the SF3326/3324 camera don’t have driver in default release.
Is there any guide on how can I write the driver to use it with Jetson AGX Orin?
Also, what deserializer board will you recommend for using these cams?
Here’s the programing guide.
