Request for Supported Deserializer Card for Selected MAX96717 Cameras on NVIDIA Jetson AGX Orin platform
We are evaluating GMSL2 camera compatibility with the NVIDIA Jetson AGX Orin platform and and have selected the following cameras:
LI‑VENUS‑OX03F10‑96717‑195H for Surround View System (SVS)
LI‑VB1940‑VCL‑OMS‑GM2B‑137H for (DMS) STURDeCAM57 - 5MP RGB-IR OX05B1S for DMS/OMS
All the above camera modules are using MAX96717 serializer.
Could you please suggest us the appropriate deserializer card that is compatible with the NVIDIA Jetson AGX Orin board for integrating these selected cameras?
Thanks for the support!
Based on the provided context, I will provide a comprehensive answer to your question.
The NVIDIA Jetson AGX Orin platform supports the Gigabit Multimedia Serial Link (GMSL) protocol, which is used for high-speed data transmission between cameras and the platform. Since you are using MAX96717 serializers in your camera modules, you will need a compatible deserializer card to integrate these cameras with the NVIDIA Jetson AGX Orin board.
The context mentions that the reference GMSL module described uses the CSI interface, and no other interface is validated. However, it does not provide specific information about the deserializer card compatibility.
To find a compatible deserializer card, you can consider the following options:
  1. MAX96705 Deserializer: The MAX96705 is a companion deserializer to the MAX96717 serializer. It is designed to work with the MAX96717 and can provide a compatible solution for your camera modules.
  2. NVIDIA-validated Deserializer Cards: NVIDIA may have validated specific deserializer cards for use with the Jetson AGX Orin platform. You can check the NVIDIA website or contact their support team to inquire about validated deserializer cards.
  3. Third-party Deserializer Cards: There may be third-party deserializer cards available that are compatible with the MAX96717 serializer and the NVIDIA Jetson AGX Orin platform. You can search for these cards from reputable manufacturers and verify their compatibility before making a purchase.
When selecting a deserializer card, ensure that it meets the following requirements:
  • Compatibility with the MAX96717 serializer
  • Compatibility with the NVIDIA Jetson AGX Orin platform
  • Support for the CSI interface (if required)
  • Compliance with the GMSL protocol
It is essential to verify the compatibility and specifications of the deserializer card with the camera modules and the NVIDIA Jetson AGX Orin platform to ensure seamless integration and optimal performance.
In summary, while the context does not provide specific information about deserializer card compatibility, you can consider the MAX96705 Deserializer, NVIDIA-validated Deserializer Cards, or third-party Deserializer Cards that meet the required specifications. Verify the compatibility and specifications of the deserializer card before making a purchase to ensure successful integration with your camera modules and the NVIDIA Jetson AGX Orin platform.
I know nothing about the deserializers you are working with, but if that hardware works with drivers normally found in Linux, then likely it works on the Jetson if the kernel version has the ability to use that driver when present. The trick is that often you must add the driver, it isn’t automatic for kernel configuration and build.
hello apoorvam.gowda,
please contact with Jetson camera partners for camera solutions.
you may refer to Partner Camera Solutions.
