HI ,
I’ve got a Windows Server 2016 install on a Huawei server and after installing the driver the system appears to recognize that the M60 is installed.
I want to make sure I’m using the P40 as my Display driver , Is there anything method i can verify ?
On windows server 2016 , how can I verify that RDP able to use the GPU ?
I can see the P40 in GPU-Z & Device manager in local , but I can’t see the P40 driver after RDP .
I can’t run any 3DMark or this type of software to ensure i can use the Display card .
Thank you
