Has anybody successfully used VBox version of Ubuntu as their “Host” while working (flashing, etc.) with their TX2? I tried to use it as the host to flash the latest JetPack on it and it does not work, when I move to the physical box I have no problems. I am thinking that my problem has to do with the virtualization to physical issues. I am running Vbox on a Win10 fully patched box. Any thoughts on this?
VMs are not supported…typically USB doesn’t work right (it’s rare to not run into a USB issue with a VM). If you want to use a VM, then this may help:
[url]https://devtalk.nvidia.com/default/topic/1002081/jetson-tx2/jetpack-3-0-install-with-a-vm/[/url]
