Based on the provided context, it appears that you have successfully booted the Orin Nano Super DevKit using the SSD containing the Holybro Orin NX DevKit image. However, to verify that this method does not cause any compatibility or performance problems, we need to consider a few factors.
Firstly, the Orin NX and Orin Nano series share the same SoC (t23x), which means that the software compatibility should be similar. However, the Orin NX and Orin Nano have different power modes and thermal designs. The Orin NX series supports a 40W power mode, while the Orin Nano series supports a 25W power mode.
Since you have flashed the Jetson using SDK Manager for the Orin NX DevKit, the image on the SSD is optimized for the Orin NX series. When you boot the Orin Nano Super DevKit using this image, it may not be optimized for the Orin Nano’s power mode and thermal design.
To verify that this method does not cause any compatibility or performance problems, you can perform the following checks:
- Power mode: Verify that the Orin Nano Super DevKit is running in the correct power mode. You can check the power mode using the
nvpmodel command. If the power mode is set to 40W, you may need to adjust it to 25W to match the Orin Nano’s power mode.
- Thermal design: Verify that the Orin Nano Super DevKit’s thermal design is compatible with the image on the SSD. You can check the thermal design using the
tegrastats command. If the thermal design is not compatible, you may need to adjust the thermal settings or use a different thermal design.
- Performance: Verify that the Orin Nano Super DevKit is performing as expected. You can run benchmarking tests to verify that the performance is not affected by using the Orin NX DevKit image.
- Compatibility: Verify that all the peripherals and devices are working correctly. You can check the device tree and kernel logs to ensure that all the devices are recognized and working correctly.
If you have verified that the Orin Nano Super DevKit is working correctly and there are no compatibility or performance issues, it is safe to continue using the Orin Nano Super DevKit with the SSD containing the Holybro Orin NX DevKit image.
However, it is recommended to flash the Orin Nano Super DevKit with the correct image optimized for the Orin Nano series to ensure optimal performance and compatibility. You can use the jetson-orin-nano-devkit-super.conf configuration file to flash the Orin Nano Super DevKit with the correct image.
In summary, while it appears that you have successfully booted the Orin Nano Super DevKit using the SSD containing the Holybro Orin NX DevKit image, it is recommended to verify that there are no compatibility or performance issues and to flash the Orin Nano Super DevKit with the correct image optimized for the Orin Nano series to ensure optimal performance and compatibility.
