Hi everyone:
when I run v4l2-ctl command :
v4l2-ctl -d /dev/video0 --set-fmt-video=width=1280,height=720,pixelformat=UYVY --stream-mmap --stream-count=10000 --set-ctrl bypass_mode=0
or gstreamer command:
gst-launch-1.0 nvv4l2camerasrc num-buffers=3000 ! ‘video/x-raw(memory:NVMM),format=(string)UYVY, width=(int)1280, height=(int)720,framerate=(fraction)22/1’ ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=NV12’ ! fpsdisplaysink text-overlay=0 video-sink=fakesink sync=0 -v
I get a high CPU uasge process that named vi-output ,like below :
and at the same time those two commands work fine .
I would like to know what this vi-output used for and the possible reason for this problem.
For CPU usage, please execute sudo tegrastats to get CPU loading of each core. It should not have much CPU usage if you use nvv4l2camerasrc plugin.
thank you for replying
here is tegrastats output , it’s the same as before
It looks expected. You may compare with
gst-launch-1.0 v4l2src num-buffers=3000 ! ‘video/x-raw,format=(string)UYVY, width=(int)1280, height=(int)720,framerate=(fraction)22/1’ ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=NV12’ ! fpsdisplaysink text-overlay=0 video-sink=fakesink sync=0 -v
hi,
I get an error by running the command:
gst-launch-1.0 v4l2src device=/dev/video0 num-buffers=3000 ! ‘video/x-raw,format=(string)UYVY, width=(int)1280,height=(int)720,framerate=(fraction)22/1’ ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=NV12’ ! fpsdisplaysink text-overlay=0 video-sink=fakesink sync=0 -v
but v4l2-ctl command looks fine :
and the CPU usage still high
Please try this:
gst-launch-1.0 v4l2src device=/dev/video0 num-buffers=3000 ! ‘video/x-raw,format=(string)UYVY, width=(int)1280,height=(int)720,framerate=(fraction)22/1’ ! fpsdisplaysink text-overlay=0 video-sink=fakesink sync=0 -v
And check the CPU usage. Another possibility is the sensor driver is not optimized and takes significant CPU usage.
hi
the command still get the same error
but when I run command below , the CPU uasge drop to 0.3%
gst-launch-1.0 nvv4l2camerasrc device=/dev/video0 num-buffers=3000 ! ‘video/x-raw(memory:NVMM),format=(string)UYVY, width=(int)1280, height=(int)720,framerate=(fraction)22/1’ ! fpsdisplaysink text-overlay=0 video-sink=fakesink sync=0 -v
and the v4l2-ctl still get high CPU usage:
Maybe framerate=(fraction)22/1 is wrong. Please execute v4l2-ctl --list-formats-ext and confirm 1280x720 22fps is supported.
HI
I have change it to 22fps , but not working
but I found that a different video device has no such thing;
the same command , when I change video device to /dev/video4 ,the CPU uasge is like 0.3%.
gst-launch-1.0 nvv4l2camerasrc device=/dev/video4 num-buffers=3000 ! ‘video/x-raw(memory:NVMM),format=(string)UYVY, width=(int)1280, height=(int)720,framerate=(fraction)22/1’ ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=NV12’ ! fpsdisplaysink text-overlay=0 vide o-sink=fakesink sync=0 -v
and the difference between those two is they belong to different deserializer (and different csi port),;
could it be hardware or sensor driver problem ?
It is very likely to be an issue in the sensor driver. Do you use the camera board from our partners? Please share more information about the camera input like vendor and model ID.
system
Closed
June 8, 2022, 4:30am
13
