Hello folks,
I’d like to see VK_EXT_headless_surface when executing vulkaninfo in Google Colab headless instance with T4 GPU.
Here’s what I did so far:
- Update drivers
!apt install -qy wget vulkan-tools xvfb libnvidia-gl-535
!apt remove -qy mesa-vulkan-drivers
- Install headlesss nvidia-525 drivers
!apt install nvidia-headless-525
Here’s the output of !nvidia-xconfig --query-gpu-info:
Number of GPUs: 1
GPU #0:
UUID : GPU-2e550925-ce29-5566-4a1a-d0803a404083
PCI BusID : PCI:0:4:0
Number of Display Devices: 0
And the output of !vulkaninfo --summary:
'DISPLAY' environment variable not set... skipping surface info
error: XDG_RUNTIME_DIR not set in the environment.
VULKANINFO
Vulkan Instance Version: 1.3.204
Instance Extensions: count = 19
VK_EXT_acquire_drm_display : extension revision 1
VK_EXT_acquire_xlib_display : extension revision 1
VK_EXT_debug_report : extension revision 10
VK_EXT_debug_utils : extension revision 2
VK_EXT_direct_mode_display : extension revision 1
VK_EXT_display_surface_counter : extension revision 1
VK_KHR_device_group_creation : extension revision 1
VK_KHR_display : extension revision 23
VK_KHR_external_fence_capabilities : extension revision 1
VK_KHR_external_memory_capabilities : extension revision 1
VK_KHR_external_semaphore_capabilities : extension revision 1
VK_KHR_get_display_properties2 : extension revision 1
VK_KHR_get_physical_device_properties2 : extension revision 2
VK_KHR_get_surface_capabilities2 : extension revision 1
VK_KHR_surface : extension revision 25
VK_KHR_surface_protected_capabilities : extension revision 1
VK_KHR_wayland_surface : extension revision 6
VK_KHR_xcb_surface : extension revision 6
VK_KHR_xlib_surface : extension revision 6
Instance Layers:
Devices:
GPU0:
apiVersion = 4206834 (1.3.242)
driverVersion = 2245656896 (0x85da0140)
vendorID = 0x10de
deviceID = 0x1eb8
deviceType = PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
deviceName = Tesla T4
driverID = DRIVER_ID_NVIDIA_PROPRIETARY
driverName = NVIDIA
driverInfo = 535.104.05
conformanceVersion = 1.3.5.0
deviceUUID = 2e550925-ce29-5566-4a1a-d0803a404083
driverUUID = 0415fb4e-e904-5af7-8fad-a705dd68f35e
