Newbie question: What is the correct syntax (if at all possible with version of VMware ESXi 6.0 U1 and OFED 2.4.0.0) for creating sub/virtual interfaces? From what I can gather in the documentation would it be something like the following:
esxcli system module parameters set -m mlx4_core -p set_4k_mtu=1,msi_x=1,num_vfs=16,probe_vf=16
After rebooting I have not be able to see any additional interfaces prompting this query on the forum. Please advise.
we don’t want to use it as Ethernet card but as IB over IP. That’s the problem that I can’t get it to work as a 40GB IBoIP card in ESX 6 anymore, which worked perfectly with ESX 5.5 and the 1.8.2.4 drivers (which are not supported anymore).
Would you please also link to the driver UM you are referring too?
I have a similar problem: i cant get IP over IB working.
MT 27500 ConnectX-3 (PSID MT_1100120019) on ESX 6 (latest Updates 2 days ago). In the BIOS (SuperMicro) I set in the PCIe Configuration Page “Above 4G Decoding” as “Disabled” since otherwise the card was not recognized in older SuperMicro hardware.
First installed the 3.15.5.5 and also updated the firmware to 5150
Then had a vmnic2 with up to 40000, but link was down.
Then I uninstalled and installed OFED 2.4.0.0
Then had a vmnic2 with up to 1000GB, link down.
I also tried to install both drivers, same issue: link down, card is recognized as Ethernet and not IPoIB.
I already opened a support ticket with VMWare but the technician had no solution.
