VPI Stereo : zero disparity unless confidenceThreshold = 0 (confidenceType/NULL confidenceMap)
I am trying to run vpiSubmitStereoDisparityEstimator. I use OFA+PVA+VIC backends.
I have 2 questions.
1. How to obtain valid disparity images when using VPI_STEREO_CONFIDENCE_ABSOLUTE or RELATIVE
I observed that, except when confidenceThreshold is set to 0 (i.e., disabling disparities with confidence below the threshold), setting confidenceType to VPI_STEREO_CONFIDENCE_ABSOLUTE or RELATIVE results in a disparity image of all zeros. When I use the CUDA backend, a correct disparity image is produced in either case; I confirmed that the behavior differs by backend. The result was the same regardless of whether a confidenceMap was created.
Working code (produces correct disparity image):
vpiInitStereoDisparityEstimatorParams(&submitParams);
submitParams.confidenceType = VPI_STEREO_CONFIDENCE_ABSOLUTE; // or RELATIVE
submitParams.confidenceThreshold = 0;
vpiSubmitStereoDisparityEstimator(stream, backends, stereo, Left, Right, disparity, confidenceMap, &submitParams));
Non-working code (produces black / zero disparity image):
submitParams.confidenceThreshold = 32767; // Default value. Not set to 0.
2. Effect of confidenceThreshold when confidence map flags are NULL
When I create a confidence map, the disparity map changes depending on confidenceThreshold (disparities below the threshold are invalidated). However, when the confidence map flags argument is NULL, I cannot obtain a valid disparity image unless confidenceThreshold = 0; otherwise I get a zero disparity image.
submitParams.confidenceType = VPI_STEREO_CONFIDENCE_INFERENCE;
vpiSubmitStereoDisparityEstimator(stream, backends, stereo, Left, Right, disparity, NULL, &submitParams));
Settings used in all tests
uint64_t backends = VPI_BACKEND_OFA | VPI_BACKEND_PVA | VPI_BACKEND_VIC;
VPIImageFormat InputFormat = VPI_IMAGE_FORMAT_Y8_ER_BL;
VPIImageFormat disparityFormat = VPI_IMAGE_FORMAT_S16;
vpiInitStereoDisparityEstimatorCreationParams(&createParams);
createParams.maxDisparity = 256;
submitParams.numPasses = 1;
submitParams.windowSize = 1;
System details
NVIDIA Jetson AGX Orin
L4T 36.4.7 (JetPack 6.2.1)
Ubuntu 22.04.5 LTS
Kernel Version: 5.15.148-tegra
CUDA 12.6.68
OpenCV 4.8.0
OpenCV CUDA: NO
cuDNN: 9.3.0.75
VPI: 3.2.4
Vulkan: 1.3.204
Sorry for my poor English. Thank you.
I’ll do my best to provide a comprehensive answer to your questions.
1. Obtaining valid disparity images when using VPISTEREOCONFIDENCEABSOLUTE or RELATIVE
You’ve observed that when using the OFA, PVA, or VIC backends, setting confidenceType to VPISTEREOCONFIDENCEABSOLUTE or RELATIVE results in a disparity image of all zeros, unless confidenceThreshold is set to 0. This behavior differs from the CUDA backend, which produces a correct disparity image in either case.
The reason for this behavior is likely due to the way the confidence threshold is applied in the OFA, PVA, and VIC backends. When confidenceType is set to VPISTEREOCONFIDENCEABSOLUTE or RELATIVE, the confidence threshold is used to filter out disparities with low confidence. However, if the confidence threshold is not set to 0, it’s possible that the threshold is too high, causing all disparities to be filtered out, resulting in a zero disparity image.
In contrast, the CUDA backend may have a different implementation of the confidence threshold, which allows it to produce a correct disparity image even when confidenceType is set to VPISTEREOCONFIDENCEABSOLUTE or RELATIVE.
To obtain valid disparity images when using VPISTEREOCONFIDENCEABSOLUTE or RELATIVE, you can try setting confidenceThreshold to a lower value, such as 0.1 or 0.01, to see if this allows more disparities to pass the confidence filter.
You’ve observed that when the confidence map flags argument is NULL, you cannot obtain a valid disparity image unless confidenceThreshold is set to 0. Otherwise, you get a zero disparity image.
This behavior is likely due to the fact that when the confidence map flags argument is NULL, the confidence threshold is not applied, and all disparities are considered valid. However, if confidenceThreshold is not set to 0, it’s possible that the threshold is too high, causing all disparities to be filtered out, resulting in a zero disparity image.
In this case, setting confidenceThreshold to 0 effectively disables the confidence filter, allowing all disparities to pass through.
Comparison of backends
The behavior you’ve observed suggests that there are differences in the implementation of the confidence threshold between the OFA, PVA, VIC, and CUDA backends. The CUDA backend appears to be more lenient in its application of the confidence threshold, allowing more disparities to pass through.
In contrast, the OFA, PVA, and VIC backends appear to be more strict in their application of the confidence threshold, requiring a lower threshold value to produce a valid disparity image.
System details
Your system details suggest that you are running on a NVIDIA Jetson AGX Orin with L4T 36.4.7, JetPack 6.2.1, and Ubuntu 22.04.5 LTS. Your VPI version is 3.2.4, and you are using OpenCV 4.8.0 with CUDA 11.6.8 and cuDNN 9.3.0.75.
Overall, the behavior you’ve observed suggests that there are differences in the implementation of the confidence threshold between the OFA, PVA, VIC, and CUDA backends. To obtain valid disparity images, you may need to adjust the confidenceThreshold value depending on the backend you are using.
Thanks for the reply. However, it’s not an appropriate answer.
I also expected and understand that backends may apply parameters differently. My concern is whether the observed behavior is correct, and whether it can be fixed.
  1. You suggested lowering confidenceThreshold, but even setting it to 1 does not produce a correct disparity image. confidenceThreshold is an int32_t, so smaller fractional values cannot be supplied. Given that the CUDA backend works correctly with the same settings, isn’t this a bug?
  2. I also confirmed that it works correctly when using the CUDA backend. If you claim there are implementation differences, please explain concretely what those differences are. My goal is to use confidenceThreshold properly to suppress mismatches.
Thank you.
  1. Based on the document, confidenceThreshold only support CUDA backend:
It’s recommended to add an error checker to the VPI function so it will show some error-related message:
Ex.
#define CHECK_STATUS(STMT)        \
    do        \
        VPIStatus status = (STMT);                                                          \
        if (status != VPI_SUCCESS)                                                          \
            char buffer[VPI_MAX_STATUS_MESSAGE_LENGTH];                                     \
            vpiGetLastStatusMessage(buffer, sizeof(buffer));                                \
            std::ostringstream ss;                                                          \
            ss << "line " << __LINE__ << " " << vpiStatusGetName(status) << ": " << buffer; \
            throw std::runtime_error(ss.str());                                             \
    } while (0);
CHECK_STATUS(vpiInitStereoDisparityEstimatorCreationParams(&createParams));
  1. Do you have a complete source code that can reproduce the issue?
Hi, AastaLLL
  1. >Based on the document, confidenceThreshold only support CUDA backend. Where can I verify that information? According to the documentation, confidenceThreshold is supported by the CUDA backend and by the OFA+PVA+VIC backends.
    confidenceThreshold
  2. I am attaching the complete source. (The comments are written in Japanese. Sorry about that.)
    main.zip (3.6 KB)
Additionally, I have some newly discovered information to share.
I confirmed that with small image sizes like those used in the sample (470Ă—280), ABSOLUTE or RELATIVE both work correctly. I am currently using 1632Ă—1274 images; at that original size I get the error shown below, but it works correctly if I downsample the images.
line 234 VPI_ERROR_INTERNAL: Valid Right Padding range is [0, 255] inclusive, but input is 288
  1. Effect of confidenceThreshold when confidence map flags are NULL
It still hasn’t been resolved. If you know anything, please let me know.
Hi
Sorry for the missing.
Yes, based on the document, the confidenceThreshold is supported in “CUDA” or “OFA+PVA+VIC” backend.
We can get confidence and disparity with the cuda or ofa-pva-vic backend.
How should we interpret the output?
Both look fine to us. The result won’t be the same since the underlying hardware is different.
Hi
Sorry for the late reply.
I am not asking to obtain both a confidence map and a disparity image; rather, I am questioning whether it works properly when the confidence map is set to NULL and the confidence threshold is set to a value other than 0. I have confirmed that it works correctly with small image pairs, as you indicated, but it does not work properly with larger image sizes, such as 2M or 3M [px]. Could you please try again using larger image sizes under the above conditions?
Thank you.
Sorry for the late update.
As you mentioned that we don’t see issues with a NULL map or a nonzero threshold.
Could you share the images you used with us so we can check your use case directly?
I’m attaching the images I’m using. I’m performing stereo rectification using OpenCV.
Sorry if my understanding is wrong, but are you setting the NULL map and the non-zero setting separately? Both of these need to be set.
  1. Backend: OFA + PVA + VIC
  2. Confidence map: NULL
  3. Confidence threshold: non-zero
Please try under these conditions.
Images.zip (1.6 MB)
Thanks a lot for the clarification.
Confirmed that we also see similar behavior in our environment.
We are checking this issue with our internal team and will get back to you later.
Please check the attached sample that allow custom threshold and using confidence map or not.
We have tested different thresholds and with the confidence map on and off.
All of them worked fine EXCEPT for the image with a threshold very close to the maximum (64000) and the confidence map turned on.
This is the case because the ofa-pva-vic backend tends to not produce as high of confidence values.
Therefore when the confidence threshold is bery high, the confidence map comes out as all false and the stereo disparity results are removed.
In such case, ignoring the explicit confidence map filtering step, the disparity image comes out fine.
main.cpp (15.8 KB)
The purpose of using the confidence map threshold is to eliminate pixels with low confidence that may be false matches.
Therefore, the filtering step cannot be ignored.
Is it correct behavior that the ofa-pva-vic backend does not generate particularly high confidence values in the first place?
Is this the intended behavior?
Please respond.
The confidence map is not working only in the case where the threshold is very close to the maximum.
If not, it can work as expected.
Please try the sample shared above.
Sorry for the delayed confirmation. Thank you for the information.
I’ll try the sample and share the results later.
