Recently I updated Ubuntu from 20.04 to 22.04 and now I have issues with Nvidia drivers.
The Vulkan is not working at all, can’t run any Steam game and vkcube doesn’t work.
This is the output when I try to run vkcube:
Can't open bumblebee display.
Selected GPU 0: llvmpipe (LLVM 13.0.1, 256 bits), type: 4
Could not find both graphics and present queues
Btw I’m using Legion 5 with Ryzen 7, AMD integrated GPU and Nvidia GTX 1650 Ti.
Currently I’m in discrete mode, but with switchable graphics it’s the same.
nvidia-bug-report.log.gz (271.4 KB)
Do you have bumble installed? If so, please uninstall it.
Now I removed it.
When I run the vkcube this is what I get now:
Please post the output of
ls /etc/vulkan/icd.d
and
vulkaninfo --summary
The first command shows nothing.
This is the output of the second one:
ERROR: [Loader Message] Code 0 : libnv_vulkan_wrapper.so.1: cannot open shared object file: No such file or directory
WARNING: lavapipe is not a conformant vulkan implementation, testing use only.
VULKANINFO
Vulkan Instance Version: 1.3.204
Instance Extensions: count = 19
VK_EXT_acquire_drm_display : extension revision 1
VK_EXT_acquire_xlib_display : extension revision 1
VK_EXT_debug_report : extension revision 10
VK_EXT_debug_utils : extension revision 2
VK_EXT_direct_mode_display : extension revision 1
VK_EXT_display_surface_counter : extension revision 1
VK_KHR_device_group_creation : extension revision 1
VK_KHR_display : extension revision 23
VK_KHR_external_fence_capabilities : extension revision 1
VK_KHR_external_memory_capabilities : extension revision 1
VK_KHR_external_semaphore_capabilities : extension revision 1
VK_KHR_get_display_properties2 : extension revision 1
VK_KHR_get_physical_device_properties2 : extension revision 2
VK_KHR_get_surface_capabilities2 : extension revision 1
VK_KHR_surface : extension revision 25
VK_KHR_surface_protected_capabilities : extension revision 1
VK_KHR_wayland_surface : extension revision 6
VK_KHR_xcb_surface : extension revision 6
VK_KHR_xlib_surface : extension revision 6
Instance Layers: count = 8
VK_LAYER_MESA_device_select Linux device selection layer 1.2.73 version 1
VK_LAYER_MESA_overlay Mesa Overlay layer 1.2.199 version 1
VK_LAYER_NV_optimus NVIDIA Optimus layer 1.3.205 version 1
VK_LAYER_PRIMUS_PrimusVK Primus-vk - https://github.com/felixdoerre/primus_vk 1.2.0 version 1
VK_LAYER_VALVE_steam_fossilize_32 Steam Pipeline Caching Layer 1.3.207 version 1
VK_LAYER_VALVE_steam_fossilize_64 Steam Pipeline Caching Layer 1.3.207 version 1
VK_LAYER_VALVE_steam_overlay_32 Steam Overlay Layer 1.3.207 version 1
VK_LAYER_VALVE_steam_overlay_64 Steam Overlay Layer 1.3.207 version 1
Devices:
GPU0:
apiVersion = 4202700 (1.2.204)
driverVersion = 1 (0x0001)
vendorID = 0x10005
deviceID = 0x0000
deviceType = PHYSICAL_DEVICE_TYPE_CPU
deviceName = llvmpipe (LLVM 13.0.1, 256 bits)
driverID = DRIVER_ID_MESA_LLVMPIPE
driverName = llvmpipe
driverInfo = Mesa 22.0.1 (LLVM 13.0.1)
conformanceVersion = 0.0.0.0
deviceUUID = 00000000-0000-0000-0000-000000000000
driverUUID = 00000000-0000-0000-0000-000000000000
Please uninstall primus_vk
thanks a lot, now it works fine :)
