• Hardware Platform ( GPU) A30X • DeepStream Version 6.1 • TensorRT Version 8.2.5.1 • NVIDIA GPU Driver Version (valid for GPU only) 510.39.01 • Issue Type questions
I want to use nvdsudpsrc and nvdsudpsink for UDP communication.
I started the DeepStream docker container (nvcr.io/nvidia/deepstream: 6.1-devel) and ran nvdsudpsrc,by following command
gst-launch -1.0 -e nvdsudpsrc uri = udp :// 239.xx.xx.xx: xxxx local-iface-ip = 192.168.xx.xx multicast-iface = ibpXXX!
application/x-rtp, media = video, encoding-name = H 264!
queue!
rtph 264 depend!
h 264 parse!
qtmux! filesink location =./ xxx.mp4
But,it does not work and I get following error messages:
WARNING: erronous pipeline: no element “nvdsudpsrc”
Also, I executed following command
gst-inspect -1.0 nvdsudpsrc
Then I get following error message:
“No such element or plugin ‘nvdsudpsrc’”
How do I use “nvdsudpsrc” ?
The docker container has Rivermax installed.
I executed following command, before I run nvdsudpsrd.
I executed following command and got following message:
$gst-inspect-1.0 libnvdsgst_udp.so
Plugin Details:
Name libnvdsgst_udp.so
Description Plugin for blacklisted file
Filename /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so
Version 0.0.0
License BLACKLIST
Source module BLACKLIST
Binary package BLACKLIST
Origin URL BLACKLIST
0 features:
Also, I executed following command and got following messase:
“libdpcp.so.1 = > not found” is displayed.
Does this affect anything? If so, how can I solve it?
I installed “MLNX_OFED_LINUX-5.6-2.0.9.0-ubuntu20.04-x86_64.iso” on the host machine.
But,I did not installed OFED on a Docker container(nvcr.io/nvidia/deepstream: 6.1 -devel).
Do I need to install OFED on Docker containers?
