Dear experts, dear NVIDIA,
Today when updating/upgrading OTA, I’ve faced errors with update initramfs-tools to version 0.130ubuntu3.10:
sudo apt update
Get:1 file:/var/cuda-repo-10-2-local-10.2.89 InRelease
Ign:1 file:/var/cuda-repo-10-2-local-10.2.89 InRelease
Get:2 file:/var/visionworks-repo InRelease
Ign:2 file:/var/visionworks-repo InRelease
Get:3 file:/var/visionworks-sfm-repo InRelease
Ign:3 file:/var/visionworks-sfm-repo InRelease
Get:4 file:/var/visionworks-tracking-repo InRelease
Ign:4 file:/var/visionworks-tracking-repo InRelease
Get:5 file:/var/cuda-repo-10-2-local-10.2.89 Release [574 B]
Get:6 file:/var/visionworks-repo Release [2 001 B]
Get:7 file:/var/visionworks-sfm-repo Release [2 005 B]
Get:8 file:/var/visionworks-tracking-repo Release [2 010 B]
Hit:9 http://ports.ubuntu.com/ubuntu-ports bionic InRelease
Get:10 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease [88,7 kB]
Hit:12 https://deb.nodesource.com/node_14.x bionic InRelease
Get:13 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease [74,6 kB]
Get:16 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease [88,7 kB]
Hit:18 https://repo.download.nvidia.com/jetson/ffmpeg main InRelease
Hit:19 https://repo.download.nvidia.com/jetson/common r32.4 InRelease
Hit:20 https://repo.download.nvidia.com/jetson/t194 r32.4 InRelease
Get:21 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 Packages [727 kB]
Get:22 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 DEP-11 Metadata [290 kB]
Get:23 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe arm64 Packages [982 kB]
Get:24 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe Translation-en [346 kB]
Get:25 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe arm64 DEP-11 Metadata [280 kB]
Get:26 http://ports.ubuntu.com/ubuntu-ports bionic-backports/universe arm64 DEP-11 Metadata [9 288 B]
Get:27 http://ports.ubuntu.com/ubuntu-ports bionic-security/main arm64 DEP-11 Metadata [42,7 kB]
Get:28 http://ports.ubuntu.com/ubuntu-ports bionic-security/universe arm64 Packages [617 kB]
Get:29 http://ports.ubuntu.com/ubuntu-ports bionic-security/universe Translation-en [233 kB]
Get:30 http://ports.ubuntu.com/ubuntu-ports bionic-security/universe arm64 DEP-11 Metadata [50,9 kB]
Fetched 3 830 kB in 17s (231 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
3 packages can be upgraded. Run 'apt list --upgradable' to see them.
nvidia@Xavier-NX:~$ sudo apt upgrade
Calculating upgrade... Done
The following packages will be upgraded:
initramfs-tools initramfs-tools-bin initramfs-tools-core
3 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 67,7 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 initramfs-tools all 0.130ubuntu3.10 [9 588 B]
Get:2 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 initramfs-tools-core all 0.130ubuntu3.10 [48,3 kB]
Get:3 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 initramfs-tools-bin arm64 0.130ubuntu3.10 [9 884 B]
Fetched 67,7 kB in 0s (155 kB/s)
(Reading database ... 181150 files and directories currently installed.)
Preparing to unpack .../initramfs-tools_0.130ubuntu3.10_all.deb ...
Unpacking initramfs-tools (0.130ubuntu3.10) over (0.130ubuntu3.9) ...
Preparing to unpack .../initramfs-tools-core_0.130ubuntu3.10_all.deb ...
Unpacking initramfs-tools-core (0.130ubuntu3.10) over (0.130ubuntu3.9) ...
Preparing to unpack .../initramfs-tools-bin_0.130ubuntu3.10_arm64.deb ...
Unpacking initramfs-tools-bin (0.130ubuntu3.10) over (0.130ubuntu3.9) ...
Setting up initramfs-tools-bin (0.130ubuntu3.10) ...
Setting up initramfs-tools-core (0.130ubuntu3.10) ...
Setting up initramfs-tools (0.130ubuntu3.10) ...
update-initramfs: deferring update (trigger activated)
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
Processing triggers for initramfs-tools (0.130ubuntu3.10) ...
update-initramfs: Generating /boot/initrd.img-4.9.140-tegra
Warning: couldn't identify filesystem type for fsck hook, ignoring.
I: The initramfs will attempt to resume from /dev/zram5
I: (UUID=xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxxx)
I: Set the RESUME variable to override this.
/sbin/ldconfig.real: Warning: ignoring configuration file that cannot be opened: /etc/ld.so.conf.d/aarch64-linux-gnu_EGL.conf: No such file or directory
/sbin/ldconfig.real: Warning: ignoring configuration file that cannot be opened: /etc/ld.so.conf.d/aarch64-linux-gnu_GL.conf: No such file or directory
Note that I did install v4l2loopback with dkms package, that installed some other more recent linux headers and maybe other packages.
Can someone advise about what could be the cause and possible threats ?
