What command can I use to query the module name and type?
And what do the two names on this picture stand for? Which name is the corresponding module name?
Hi 77097962,
Are you using the devkit or custom board?
The upper one seems the carrier board you are using.
The bottom one seems the module you are using.
We would check the hardware details with the following command.
$ cat /etc/nv_boot_control.conf
Please share the result of above command on your board.
Yes, you are using Orin NX 16GB module (SKU: 0000) on an Orin Nano devkit(p3768) as your carrier board so that you would see orin nano devkit string.
