Hi Nvidia Team,
May I have pinmux file password to get “Filter” button unlock ??
Regards
Hi yi-chia.lan,
Unfortunately, we cannot provide the password for the pinmux spreadsheet.
To prevent misconfiguration, the sheet contains complex underlying macros for the logics and hidden columns that are critical to its function.
Hi Nvidia Team,
without “filter” button, it will spend “a lot of time” to finish all pinmux setting.
for example we use filter button for “AS” column to check there is no missing.
or we can use filter button for “B” column to group-up specific function (ex: I2C/I2S) and set “AS” column function quickly.
without “filter” button , it spend more then double time to setup pinmux.
please optimize this file.
Regards
Hi @yi-chia.lan,
I am checking this issue with internal team.
We could enable the filter for each columns as following.
Please check if it could meet your requirement or you have further suggestions.
Hi KevinFFF,
Yes , this is what we need.
much appreciate if nvidia can help to release this kind of pinmux file
Regards
Thanks for confirming.
We’ll integrate it into Thor’s next v1.8 pinmux spreadsheet.
