What is the maximum duration I can record using smart recording
I want to record a video of duration atleast 10 or 20 minutes. is it possible with smart recording or not?
• DeepStream Version
• TensorRT Version
**• Hardware Platform --------> L4
**• DeepStream Version ---------> 7.0
• TensorRT Version -----------> 8.5
**• NVIDIA GPU Driver Version -----> 550.67
There are two duration. one is cache duration. there is no limit on the maximum duration of data I can cache. please refer to this faq. the other is duration after the start of recording, the limitation is 300 seconds. if the set value is bigger than 300, the set value will be changed to smart-rec-default-duration.
