Hello. I would like to ask a few questions before implementing HSB in our product.
First, we use TI’s MMICs. These are radar-specific ICs, and recently, application notes like the one shown in the photo below can be found on TI’s website. We intend to apply these MMICs to HSB, but each radar device is equipped with four MMICs. Each MMIC operates at 450 Mbps per lane and is configured with 4 lanes.
We intend to configure approximately 12 of these radar devices, and the configuration is as follows:
Radar Device (MMIC4) * 12 = MMIC48
Considering the data bandwidth, since each lane is 0.45Gbps, the total bandwidth is 86.4Gbps. If we consider the overhead of the HSB and assume it is 15%, the bandwidth becomes 99.36Gbps.
When configuring the block diagram as shown above, four MMICs are converted to LVDS using CrossLink-NX, and SFP+ outputs are sent via CertusPro-NX (which has Holoscan IP) to a switching hub, which is then connected to Thor.
While I would need to receive a response from Lattice to confirm whether this configuration is actually feasible, I am curious whether NVIDIA’s Thor can handle these 48 MMICs, regardless of the FPGA implementation status at present.
In the existing GMSL2 SERDES environment, data pipelines had to be configured by assigning CSI ports, setting Vi-ids, and allocating PHY controllers for each MMIC. I have attempted to configure 12 MMICs on a single Thor using this configuration, but I am wondering if data processing close to 100Gbps is possible software-wise when configuring 48 MMICs on a single Thor using HSB.
Additionally, I would like to know if individual software settings for the 48 MMICs are required on HSB, and if this is even possible. (I am unsure if it is possible to assign IPs to each FPGA board and IDs to the internal MMICs.)
Consequently, there are 12 HSB boards. Each HSB board is equipped with 4 MMICs, and these HSBs utilize SFP+ to occupy a data bandwidth of 8.6 Gbps.
Approximately 12 of these HSBs are connected to a switching hub and then connected to Thor via a QSFP28 port.
I would like to know if Thor can process all the data from each HSB and 48 MMICs, if this can be implemented in software and if there are any references worth consulting, or if technical support is available.
