I used CX7 to connect the QM9700 switch, but it was running for a long time and an error occurred (Link down counter was not zero, I had sent a command to clear it before testing)
a
What makes it happen and why? Is there any command that will allow me to find the exact cause of the reported error
The module is 800G OSFP. The information I query is as follows:
Operational Info
State : Active
Physical state : LinkUp
Speed : IB-NDR
Width : 4x
FEC : Standard_RS-FEC - (544,514)
Loopback Mode : No Loopback
Auto Negotiation : ON
Supported Info
Enabled Link Speed : 0x00000080 (NDR)
Supported Cable Speed : 0x00000080 (NDR)
Troubleshooting Info
Status Opcode : 0
Group Opcode : N/A
Recommendation : No issue was observed
Tool Information
Firmware Version : 31.2012.1068
amBER Version : 2.8
MFT Version : mft 4.27.0-83
Module Info
Identifier : OSFP
Compliance : IB NDR,400G-SR4
Cable Technology : 850 nm VCSEL
Cable Type : Optical Module (separated)
OUI : Other
Vendor Name : xxxx
Vendor Part Number : 2X400GMPO
Vendor Serial Number : 201111111
Rev : A1
Wavelength [nm] : 854
Transfer Distance [m] : 0.0
Attenuation (5g,7g,12g,25g) [dB] : N/A
FW Version : 1.23.0
Digital Diagnostic Monitoring : Yes
Power Class : 15.0 W max
CDR RX : ON,ON,ON,ON
CDR TX : ON,ON,ON,ON
LOS Alarm : N/A
Temperature [C] : 65 [-10…80]
Voltage [mV] : 3281.2 [2970…3630]
Bias Current [mA] : 9.452,9.466,9.466,9.452 [0…15]
Rx Power Current [dBm] : 1.300,0.955,0.973,0.945 [-10.41…5]
Tx Power Current [dBm] : -0.150,0.330,0.515,0.418 [-8.416…5]
SNR Media Lanes [dB] : 0,0,0,0
SNR Host Lanes [dB] : 0,0,0,0
IB Cable Width : 1x,2x,4x,8x
Memory Map Revision : 64
Linear Direct Drive : 0
Cable Breakout : Unspecified
SMF Length : N/A
MAX Power : 60
Cable Rx AMP : 1
Cable Rx Emphasis (Pre) : 0
Cable Rx Post Emphasis : 0
Cable Tx Equalization : 0
Wavelength Tolerance : 14.0nm
Module State : Ready state
DataPath state [per lane] : DPActivated,DPActivated,DPActivated,DPActivated
Rx Output Valid [per lane] : 0,0,0,0
Nominal bit rate : N/A
Rx Power Type : Average power
Manufacturing Date : 25_12_23
Active Set Host Compliance Code : IB NDR
Active Set Media Compliance Code : 400G-SR4
Error Code Response : ConfigUndefined
Module FW Fault : 0
DataPath FW Fault : 0
Tx Fault [per lane] : 0,0,0,0
Tx LOS [per lane] : 0,0,0,0
Tx CDR LOL [per lane] : 0,0,0,0
Rx LOS [per lane] : 0,0,0,0
Rx CDR LOL [per lane] : 0,0,0,0
Tx Adaptive EQ Fault [per lane] : 0,0,0,0
2024-05-28 15:07:11,422 -
Operational Info
State : Active
Speed : IB-NDR
Width : 4x
Supported Info
Status Opcode : 0
Group Opcode : N/A
Tool Information
amBER Version : 2.8
Physical Counters and BER Info
Time Since Last Clear [Min] : 4302.8
Symbol Errors : 0
Symbol BER : 15E-255
Effective Physical Errors : 0
Effective Physical BER : 15E-255
Raw Physical Errors Per Lane : 48905455907,7934132259,2920644571,787673008
Raw Physical BER : 5E-7
Link Down Counter : 2
Link Error Recovery Counter : 0
2024-05-28 15:07:11,785 -
Operational Info
State : Active
Speed : IB-NDR
Width : 4x
Supported Info
Status Opcode : 0
Group Opcode : N/A
Tool Information
amBER Version : 2.8
Histogram of FEC Errors
Header : Range Occurrences
Bin 0 : [0] 20111015590768
Bin 1 : [1] 58829955432
Bin 2 : [2] 827585568
Bin 3 : [3] 19803041
Bin 4 : [4] 808748
Bin 5 : [5] 45105
Bin 6 : [6] 3254
Bin 7 : [7] 298
Bin 8 : [8] 30
Bin 9 : [9] 1
Bin 10 : [10] 2
Bin 11 : [11] 0
Bin 12 : [12] 0
Bin 13 : [13] 0
Bin 14 : [14] 0
Bin 15 : [15] 0
Operational Info
State : Active
Speed : IB-NDR
Width : 4x
Supported Info
Status Opcode : 0
Group Opcode : N/A
Tool Information
amBER Version : 2.8
