What is the use of secondary-reinfer-interval?
• Hardware Platform (Jetson / GPU) - GPU
• DeepStream Version - 6.0
• TensorRT Version - 8.0.1
• Issue Type( questions, new requirements, bugs) - questions
Document says about ‘secondary-reinfer-interval’ - Re-inference interval for objects, in frames
Does that mean the secondary model does inference on the same object(detected by pgie) only after every ‘secondary-reinfer-interval’? How does it keep track of the object id without a tracker? Can you please explain how it works.
Please refer to this similar topic: GstNvInfer does not have property secondary-reinfer-interval - #2
I checked the post. Can you clarify on this comment - GstNvInfer does not have property secondary-reinfer-interval - #9 by mchi
This works irrespective of tracker?
It is used to adapt the behavior of SGIE and is independent of tracker.
