执行 Isaac Sim 文档 ROS2 教程 "发布摄像机数据 "中的 "将摄像机内在元件发布到 CameraInfo "主题部分时,出现错误 “from omni.isaac.ros2_bridge import read_camera_info”。
In reference to “https://docs.omniverse.nvidia.com/isaacsim/latest/ros2_tutorials/tutorial_ros2_camera_publishing.html” , when using the following code
def publish_camera_info(camera: Camera, freq):
# The following code will link the camera's render product and publish the data to the specified topic name.
render_product = camera._render_product_path
step_size = int(60/freq)
topic_name = camera.name+"_camera_info"
queue_size = 1
node_namespace = ""
frame_id = camera.prim_path.split("/")[-1] # This matches what the TF tree is publishing.
writer = rep.writers.get("ROS2PublishCameraInfo")
camera_info = read_camera_info(render_product_path=render_product)
writer.initialize(
frameId=frame_id,
nodeNamespace=node_namespace,
queueSize=queue_size,
topicName=topic_name,
width=camera_info["width"],
height=camera_info["height"],
projectionType=camera_info["projectionType"],
k=camera_info["k"].reshape([1, 9]),
r=camera_info["r"].reshape([1, 9]),
p=camera_info["p"].reshape([1, 12]),
physicalDistortionModel=camera_info["physicalDistortionModel"],
physicalDistortionCoefficients=camera_info["physicalDistortionCoefficients"],
writer.attach([render_product])
gate_path = omni.syntheticdata.SyntheticData._get_node_path(
"PostProcessDispatch" + "IsaacSimulationGate", render_product
# Set step input of the Isaac Simulation Gate nodes upstream of ROS publishers to control their execution rate
og.Controller.attribute(gate_path + ".inputs:step").set(step_size)
return
The line “from omni.isaac.ros2_bridge import read_camera_info” is running wrongly.I have no problem to execute the other example such as “Publish pointcloud from depth images”, etc. I read the documentation of omni.isaac.ros2_bridge, it seems that there is no “read_camera_info”. camera_info” function.
[7.975s] Simulation App Starting
[9.601s] app ready
[10.820s] Simulation App Startup Complete
[10.829s] [ext: omni.isaac.ros2_bridge-2.26.4] startup
[10.855s] Attempting to load system rclpy
[10.886s] rclpy loaded
2024-09-06 07:10:11 [139,234ms] [Warning] [omni.fabric.plugin] No source has valid data array=0x21d83be0 usdValid=0 cpuValid=0
2024-09-06 07:10:11 [139,236ms] [Warning] [omni.fabric.plugin] No source has valid data array=0x21d91300 usdValid=0 cpuValid=0
2024-09-06 07:10:26 [153,641ms] [Warning] [omni.syntheticdata.plugin] OgnSdPostRenderVarToHost : rendervar copy from texture directly to host buffer is counter-performant. Please use copy from texture to device buffer first.
2024-09-06 07:10:26 [153,672ms] [Warning] [omni.timeline.plugin] Deprecated: direct use of ITimeline callbacks is deprecated. Use ITimeline::getTimeline (Python: omni.timeline.get_timeline_interface) instead.
File "/home/lenovo/IsaacSim-ros_workspaces/humble_ws/publish_camera_project/publish_camera.py", line 268, in <module>
publish_camera_info(camera, approx_freq)
File "/home/lenovo/IsaacSim-ros_workspaces/humble_ws/publish_camera_project/publish_camera.py", line 126, in publish_camera_info
ImportError: cannot import name 'read_camera_info' from 'omni.isaac.ros2_bridge' (/home/lenovo/.local/share/ov/pkg/isaac-sim-4.0.0/exts/omni.isaac.ros2_bridge/omni/isaac/ros2_bridge/__init__.py)
2024-09-06 07:10:26 [153,688ms] [Warning] [carb] [Plugin: omni.sensors.tiled.plugin] Module /home/lenovo/.local/share/ov/pkg/isaac-sim-4.0.0/extscache/omni.sensors.tiled-0.0.3+106.0.0.lx64.r/bin/libomni.sensors.tiled.plugin.so remained loaded after unload request
2024-09-06 07:10:26 [153,693ms] [Warning] [carb] [Plugin: omni.spectree.delegate.plugin] Module /home/lenovo/.local/share/ov/pkg/isaac-sim-4.0.0/kit/exts/omni.usd_resolver/bin/libomni.spectree.delegate.plugin.so remained loaded after unload request
2024-09-06 07:10:26 [153,697ms] [Warning] [omni.graph.core.plugin] Could not find category 'Replicator:Annotators' for removal
2024-09-06 07:10:26 [153,697ms] [Warning] [omni.graph.core.plugin] Could not find category 'Replicator:Core' for removal
2024-09-06 07:10:26 [153,781ms] [Warning] [carb] Client omni.syntheticdata.plugin Failed to acquire interface [omni::graph::core::INode v4.10] while unloading all plugins
Fatal Python error: Segmentation fault
Current thread 0x00007e0e22f45b80 (most recent call first):
<no Python frame>
Extension modules: psutil._psutil_linux, psutil._psutil_posix, omni.mdl.pymdlsdk._pymdlsdk, numpy.core._multiarray_umath, numpy.core._multiarray_tests, numpy.linalg._umath_linalg, numpy.fft._pocketfft_internal, numpy.random._common, numpy.random.bit_generator, numpy.random._bounded_integers, numpy.random._mt19937, numpy.random.mtrand, numpy.random._philox, numpy.random._pcg64, numpy.random._sfc64, numpy.random._generator, torch._C, torch._C._fft, torch._C._linalg, torch._C._nested, torch._C._nn, torch._C._sparse, torch._C._special, scipy._lib._ccallback_c, scipy.sparse._sparsetools, _csparsetools, scipy.sparse._csparsetools, scipy.sparse.linalg._isolve._iterative, scipy.linalg._fblas, scipy.linalg._flapack, scipy.linalg._cythonized_array_utils, scipy.linalg._flinalg, scipy.linalg._solve_toeplitz, scipy.linalg._matfuncs_sqrtm_triu, scipy.linalg.cython_lapack, scipy.linalg.cython_blas, scipy.linalg._matfuncs_expm, scipy.linalg._decomp_update, scipy.sparse.linalg._dsolve._superlu, scipy.sparse.linalg._eigen.arpack._arpack, scipy.sparse.csgraph._tools, scipy.sparse.csgraph._shortest_path, scipy.sparse.csgraph._traversal, scipy.sparse.csgraph._min_spanning_tree, scipy.sparse.csgraph._flow, scipy.sparse.csgraph._matching, scipy.sparse.csgraph._reordering, scipy.spatial._ckdtree, scipy._lib.messagestream, scipy.spatial._qhull, scipy.spatial._voronoi, scipy.spatial._distance_wrap, scipy.spatial._hausdorff, scipy.special._ufuncs_cxx, scipy.special._ufuncs, scipy.special._specfun, scipy.special._comb, scipy.special._ellip_harm_2, scipy.spatial.transform._rotation, PIL._imaging, PIL._imagingft, scipy.ndimage._nd_image, _ni_label, scipy.ndimage._ni_label, osqp._osqp, multidict._multidict, yarl._quoting_c, aiohttp._helpers, aiohttp._http_writer, aiohttp._http_parser, aiohttp._websocket, _cffi_backend, frozenlist._frozenlist, scipy.io.matlab._mio_utils, scipy.io.matlab._streams, scipy.io.matlab._mio5_utils, yaml._yaml (total: 77)
/home/lenovo/.local/share/ov/pkg/isaac-sim-4.0.0/python.sh: 第 41 行: 1763301 段错误 (核心已转储) $python_exe "$@" $args
There was an error running python
