When FDT is not specified in extlinux.conf, where does the dtb come from?
I see this is on the SD card:
     Device: /dev/mmcblk0p10
      Start: 18432
        End: 19327
    Sectors: 896
       Type: Linux filesystem
  Type-UUID: 0FC63DAF-8483-4772-8E79-3D69D8477DE4
       UUID: 9F7DF322-ACE3-4203-967A-B515F102B06D
It’s not a file system that can be mounted, and it’s not a dtb file that dtc recognizes.
How can I peek inside?
Hi tunretni,
This dtb is from the DTB partition.
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%2520Linux%2520Driver%2520Package%2520Development%2520Guide%2Fpart_config.html
Hello tunretni,
Also, the dtb that’s loaded can be found at /sys/firmware/devicetree/base which can be extracted to a .dts file using the below command:
dtc -I fs -O dts -o $HOME/extracteddtb.dts /sys/firmware/devicetree/base
The “dtc” command is installed through the package “device-tree-compiler”
You can also view the device tree via /proc/device-tree. The dtc tool can generate dts from the filesystem. I often do that to be certain of what really is being used.
