When using Gst-nvmultiurisrcbin, how to replace the oldest tiles in turn?
GPU 2060
• DeepStream Version
DeepStream 7.0
• TensorRT Version
IN Ds docker
535
questions
When removing a source in Gst-nvmultiurisrcbin, the corresponding tile will turn black and remain. The next time you add a new source, the removed tile will not be used, but a new tile will be opened, so that there will be more and more tiles. How to solve this problem? How to specify the replacement tile?
It is not a problem. The tiler place is decided by the sink pad index of nvstreammux. Gst-nvmultiurisrcbin is open source, you can view the way it decide the pad index for the new added source in s_get_source_id() function in /opt/nvidia/deepstream/deepstream/sources/libs/gstnvdscustomhelper/gst-nvmultiurisrcbincreator.cpp
You can design your own strategy by yourself.
I am a little confused. gstnvdscustomhelper/gst-nvmultiurisrcbincreator.cpp is the implementation component of creator in Gst-nvmultiurisrcbin. I need to modify gstnvdscustomhelper/gst-nvmultiurisrcbincreator.cpp to modify Gst-nvmultiurisrcbin to achieve my goal, right?
Yes. It is open source for your reference and customization.
