rtx 2060
• DeepStream Version
deepstream 7.0
• TensorRT Version
In deepstream container
535
questions
When I use source-list to configure the rtsp data source, the image mosaic is quite serious due to the default udp protocol. I hope to alleviate this problem by setting it to use the tcp protocol. How should I do it?
This my config:
[source-list]
num-source-bins=1
list=rtsp://192.168.1:554/ch33/main/av_stream
rtsp-protocols=2
#list=sources_rtsp.csv
#csv-file-path=sources_rtsp.csv
use-nvmultiurisrcbin=1
#To display stream name in FPS log, set stream-name-display=1
#sensor-id-list vector is one to one mapped with the uri-list
#identifies each sensor by a unique ID
sensor-id-list=UniqueSensorId1
#Optional sensor-name-list vector is one to one mapped with the uri-list
sensor-name-list=测试摄像头1
max-batch-size=4
http-ip=localhost
http-port=7000
set low latency mode for bitstreams having I and IPPP frames on decoder
low-latency-mode=0
#sgie batch size is number of sources * fair fraction of number of objects detected per frame per source
#the fair fraction of number of object detected is assumed to be 4
sgie-batch-size=10
set the below key to keep the application running at all times
