Which omniverseMDLtable.csv file works?
There are 3 omniverseMDLtable.csv files on my computer
Dcoument/Omniverse
Connector/Materials
Connector/MDLTable
They are all the same
according to Revit — Omniverse Connect latest documentation
Is Connector/Materials the right path?
Hello @qmxlf! Welcome to the Community! I reached out to the dev team to help get you confirmation on your question. I will post back as soon as I have more information!
Hi @qmxlf
The correct one for Revit is /Omniverse/Revit folder. This is the CSV file that is read in by the Revit Connector.
Please note that you can change and save that CSV while Revit is running and the Connector will pick up that change on the next Export.
Brian
@qmxlf
Agreed with the above - to be super clear, that is the
Documents\Omniverse\Revit
folder
