Hello everyone, Currently I am trying to upgrade the firmware version from 35.0 to 36 using qspi boot loader but facing issue with that. Attaching the snapshots of the error messages for further reference.
Hi ravikumar.r1,
Are you using the devkit or custom board for Orin Nano?
Please share the detailed steps how do you upgrade from r35 to r36.
And what’s the exact version of r35 and r36?
I would also like to check the log in your case.
Hello @KevinFFF,
Currently I am using jetpack 5.1.3 but need to upgrade to jetpack 6.0 but while installing the qspi boot loader it is getting error
te-jetson@tejetson-desktop:~$ sudo nvbootctrl dump-slots-info
[sudo] password for te-jetson:
Current version: 0.0.1
Capsule update status: 0
Current bootloader slot: A
Active bootloader slot: A
num_slots: 2
slot: 0, status: normal
slot: 1, status: normal
te-jetson@tejetson-desktop:~$ sudo apt-get install nvidia-l4t-jetson-orin-nano-qspi-updater
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/8,939 kB of archives.
After this operation, 11.0 MB of additional disk space will be used.
debconf: delaying package configuration, since apt-utils is not installed
(Reading database … 160415 files and directories currently installed.)
Preparing to unpack …/nvidia-l4t-jetson-orin-nano-qspi-updater_36.3.0-20240424200557_arm64.deb …
3767–0005–1–jetson-orin-nano-devkit-
Info. Installing mtdblock.
Info. Active boot storage: mmcblk1
Info. Legacy mode: false
TNSPEC 3767-300-0005-M.1-1-0-jetson-orin-nano-devkit-
COMPATIBLE_SPEC 3767–0005–1–jetson-orin-nano-devkit-
TEGRA_LEGACY_UPDATE false
TEGRA_BOOT_STORAGE mmcblk1
TEGRA_EMMC_ONLY false
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
Info: Write TegraPlatformCompatSpec with 3767–0005–1–jetson-orin-nano-devkit-.
ERROR. BSP version 1 is not supported.
dpkg: error processing archive /var/cache/apt/archives/nvidia-l4t-jetson-orin-nano-qspi-updater_36.3.0-20240424200557_arm64.deb (–unpack):
new nvidia-l4t-jetson-orin-nano-qspi-updater package pre-installation script subprocess returned error exit status 1
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Hello @KevinFFF, Is there any solution for this?
Are you working on the devkit or custom carrier board for Orin Nano?
Have you tried to perform image-based OTA to update from JP5.1.3 to JP6.1?
Or have you tried just using the flash command directly?
Hello @KevinFFF, I am using developer kit, and I managed to upgrade it to jetpack 6.1 using SDK manager
