Hi, i bought a orin nano developer kit. The firmware it has is not compatible to run jetpack 6.0 Hence i’m following the steps to update qspi as described here :
However it seems there is no script named nvidia-l4t-jetson-orin-nano-qspi-updater
How to update the qspi ?
Thanks for any help
Can you first issue sudo apt update and then the install command?
