Check serial console log instead of using the monitor status to check.
there have some problem,[ 17.370745] piix4_smbus 0000:00:07.3: SMBus Host Controller not enabled!
[ 18.088566] sd 32:0:0:0: [sda] Assuming drive cache: write through
不確定用中文解釋會不會清楚一點. 或是你可以直接說中文看能不能多提供一些資訊
你能抓一下你Orin上的log嗎? 你上面貼的東西看起來不太像是 Jetson上抓下來的
我不知道这些是否是你需要的
[ 6.080056] nvme nvme0: 6/0/0 default/read/poll queues
[ 6.083652] usb 2-1: Manufacturer: Generic
[ 6.097109] GPT:Primary header thinks Alt. header is not at the end of the d.
[ 6.100485] GPT:250069679 != 500118191
[ 6.104451] GPT:Alternate GPT header not at the end of the disk.
[ 6.110284] GPT:250069679 != 500118191
[ 6.114211] GPT: Use GNU Parted to correct GPT errors.
[ 6.119307] nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 6.119508] hub 2-1:1.0: USB hub found
[ 6.131940] hub 2-1:1.0: 4 ports detected
[ 6.162107] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 6.314244] usb 1-3: New USB device found, idVendor=0bda, idProduct=c822, bc0
[ 6.314488] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.314702] usb 1-3: Product: Bluetooth Radio
[ 6.314826] usb 1-3: Manufacturer: Realtek
[ 6.314946] usb 1-3: SerialNumber: 00e04c000001
[ 7.155483] tegra194-pcie 141e0000.pcie: Phy link never came up
[ 7.155744] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[ 7.155934] pci_bus 0007:00: root bus resource [bus 00-ff]
[ 7.156090] pci_bus 0007:00: root bus resource [io 0x200000-0x2fffff] (bus )
[ 7.156370] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322ffffff)
[ 7.156678] pci_bus 0007:00: root bus resource [mem 0x2e40000000-0x3227fffff]
[ 7.156947] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[ 7.157261] pci 0007:00:00.0: PME# supported from D0 D3hot
[ 7.166959] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[ 7.167116] pci 0007:00:00.0: Max Payload Size set to 256/ 256 (was 256), 2
[ 7.167651] pcieport 0007:00:00.0: Adding to iommu group 10
[ 7.168045] pcieport 0007:00:00.0: PME: Signaling with IRQ 59
[ 7.168655] pcieport 0007:00:00.0: AER: enabled with IRQ 59
[ 7.169051] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[ 7.169300] pci 0007:00:00.0: Removing from iommu group 10
[ 7.169450] pci_bus 0007:00: busn_res: [bus 00-ff] is released
[ 7.172770] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 7.176734] vdd-3v3-sd: supplied by vdd-3v3
[ 7.183427] tegra194-isp5 14800000.isp: initialized
[ 7.188738] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 7.191743] (NULL device *): fops function table already registered
[ 7.200446] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 7.204994] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 7.205001] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 7.210575] irq: IRQ291: trimming hierarchy from :interrupt-controller@f40001
[ 7.230394] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 283
[ 7.331659] tegra194-pcie 140a0000.pcie: host bridge /pcie@140a0000 ranges:
[ 7.331885] tegra194-pcie 140a0000.pcie: IO 0x002a100000..0x002a1fffff0
[ 7.332135] tegra194-pcie 140a0000.pcie: MEM 0x3528000000..0x352fffffff0
[ 7.332368] tegra194-pcie 140a0000.pcie: MEM 0x3240000000..0x3527ffffff0
[ 7.438266] tegra194-pcie 140a0000.pcie: Link up
[ 7.440963] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[ 7.441168] pci_bus 0008:00: root bus resource [bus 00-ff]
[ 7.441319] pci_bus 0008:00: root bus resource [io 0x300000-0x3fffff] (bus )
[ 7.441595] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352ffffff)
[ 7.441870] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527fffff]
[ 7.442134] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[ 7.442447] pci 0008:00:00.0: PME# supported from D0 D3hot
[ 7.447654] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[ 7.447950] pci 0008:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 7.448283] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 7.448572] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 7.449779] pci 0008:01:00.0: supports D1 D2
[ 7.449894] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 7.455291] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280ffff]
[ 7.455478] pci 0008:00:00.0: BAR 13: assigned [io 0x300000-0x300fff]
[ 7.455644] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff]
[ 7.461134] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff]
[ 7.469005] pci 0008:01:00.0: BAR 0: assigned [io 0x300000-0x3000ff]
[ 7.475505] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[ 7.480727] pci 0008:00:00.0: bridge window [io 0x300000-0x300fff]
[ 7.487115] pci 0008:00:00.0: bridge window [mem 0x3528000000-0x35280fffff]
[ 7.494475] pci 0008:00:00.0: Max Payload Size set to 128/ 256 (was 256), 2
[ 7.503016] pci 0008:01:00.0: Max Payload Size set to 128/ 128 (was 128), 2
[ 7.511728] pcieport 0008:00:00.0: Adding to iommu group 11
[ 7.517388] pcieport 0008:00:00.0: PME: Signaling with IRQ 61
[ 7.523375] pcieport 0008:00:00.0: AER: enabled with IRQ 61
[ 7.529818] irq: IRQ293: trimming hierarchy from :pmc@c360000
[ 7.534359] irq: IRQ294: trimming hierarchy from :interrupt-controller@f40001
[ 7.541785] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 7.549314] tegra-se-nvhost 15810000.se: Adding to iommu group 39
[ 7.555041] tegra-se-nvhost 15810000.se: initialized
[ 7.561121] tegra-se-nvhost 15810000.se: tegra_se_probe: com��WARNING: clockk
��plete
[ 7.565901] tegra-se-nvhost 15820000.se: Adding to iommu group 40
[ 7.572223] tegra-se-nvhost 15820000.se: initialized
[ 7.578514] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 7.582962] tegra-se-nvhost 15840000.se: Adding to iommu group 41
[ 7.589440] tegra-se-nvhost 15840000.se: initialized
[ 7.595707] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 7.600997] tegra_actmon d230000.actmon: in actmon_register()…
[ 7.606451] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 7.612009] tegra_actmon d230000.actmon: initialization Completed for the del
[ 7.619863] hvc_sysfs: hypervisor is not present
[ 7.663925] ALSA device list:
[ 7.664012] No soundcards found.
[ 7.665001] Freeing unused kernel memory: 3968K
[ 7.665166] Run /init as init process
[ 7.681803] Root device found: initrd
[ 7.682411] Mount initrd as rootfs and enter recovery mode
Finding OTA work dir on external storage devices
Checking whether device /dev/mmcblk?p1 exist
Device /dev/mmcblk?p1 does not exist
Checking whether device /dev/sd?1 exist
Device /dev/sd?1 does not exist
Checking whether device /dev/nvme?n1p1 exist
Looking for OTA work directory on the device(s): /dev/nvme0n1p1
[ 7.746091] EXT4-fs (nvme0n1p1): warning: mounting fs with errors, running ed
[ 7.747266] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. )
OTA work directory /mnt/ota_work is not found on /dev/nvme0n1p1
Finding OTA work dir on internal storage device
mount: /mnt: special device /dev/mmcblk0p1 does not exist.
Failed to mount /dev/mmcblk0p1 to /mnt
OTA work directory is not found on internal and external storage devices
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
bash-5.0# [ 8.290789] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhcit
新建 文本文档.txt (127.9 KB)
这里是所有的日志了应该,就是我上电后的所有内容,麻烦您了
L4TLauncher: Attempting Recovery Boot
你的板子已經卡在recovery boot了. 基本上上面這個log不需要確認
請你先照下面這個步驟把機器從recovery boot 改成normal boot之後再重新抓log
log2.txt (60.8 KB)
你好,我已经修改为normal boot了
先說明一下. 你抓log的時候terminal的大小可能要調整一下
我這邊看到你的log長這樣. 你可以看到每一行超過一定長度之後log就被你卡掉了.
不過從部分的log我可以看到問題應該是你的nvme上面的rootfs好像有點問題.
[ 10.164186] EXT4-fs error (device nvme0n1p1): ext4_ext_check_inode:496: inod)
你好,今天早上我重新安装了jetpack 6.2,还是无法启动,这是日志
log3.txt (37.6 KB)
[ 19.182058] Please complete system configuration setup on the serial port provided by Jetson’s USB device mode connection. e.g. /dev/ttyACMx where x can 0, 1, 2 etc.
這份log3.txt看來是啟動完了. 只是系統在等你把OEM-config做完而已.
刚才是我在sdkmanager中没有预先设置好config,现在我重新装了下,并预先设置了用户名和密码,然后系统现在一直是在
[ 20.866404] Please wait for auto system configuration setup to complete…
卡了好长时间了,是需要接着做什么操作吗?我不是很明白
log4.txt (37.6 KB)
從你的log看來. 你應該是在用自己的custom board.
如果是的話建議你不要用sdkmanager燒. 直接去Linux_for_Tegra下面
- 跑tools底下的l4t_create_default_users.sh. 讓OEM-config直接做完
- 手動重新燒錄看一下還會不會卡在這裡.
完整的custom board步驟還包含device tree的修改. 有可能上面做完你依然開不進去. 但就是先試試
log5.txt (4.6 KB)
我手动更新后成这样了
現在的狀況比剛才更糟. 現在是連剛才能開進去的地方都開不進去.
請問你改了多少東西? 還有怎麼燒的?
剛才教你跑的東西只有發生在rootfs. 但你現在是卡在UEFI.
你好,我昨晚第一次装jetson linux35.4.1的时候出现这种问题,但是我后边又装了35.3.1就能进去系统了。但是显示还是有问题。这是log,是硬件的问题吗
log6.txt (67.8 KB)
可以麻煩先讓同樣的錯誤不要又犯嗎… 你log沒有完整…
log7.txt (88.4 KB)
好的,麻烦你了。
這看起來是你們自己做的custom board. 請問你確定在這issue發生之前你們的螢幕是能正常跑?
是的,之前是可以跑的
