I try to run a mobile robot simulation in isaac sim 2022.2.1, but when I send the /cmd_vel command using the keyboard, the simulation runs very slowly, and the fps is only 0.8. How do I configure isaac sim to solve my problem? Thanks!
Thanks for your reply! The Isaac sim can run at 90 FPS with “RTX - Realtime” mode. Thanks a lot! and these is a related post about “RTX - Realtime” and “RTX-Interactive Path Tracing” Inconsistent Simulation Speeds in Movie Capture Extension
that’s a good read as well! you didnt mention rendering, so i didn’t want to assume too much and only wanted to focus on the simulation aspect. glad you are having better perf using Realtime 👍
