Why the devname display is different at TX1 R28.2?
The display devname is “imx219 6-0010”.
[ 3.210452] [IMX219]: probing v4l2 sensor.
[ 3.216579] imx219 6-0010: imx219_ctrls_init++
[ 3.222822] imx219 6-0010: Failed to init Gain ctrl
the dtsi file devname is “imx219 30-0010”.
drivernode0 {
devname = "imx219 30-0010";
Why is different?
hello sensor_test,
may I know which camera board you’re using?
thanks
I use my own design imx219 camera board.
hello sensor_test,
please adisassembler your dtb file into txt file, and check this in the sysnode declaration.
for example,
dtc -I dtb -O dts -o temp.txt tegra210.dtb
hello JerryChang,
there are error is below.
nvidia@tegra-ubuntu:~$ dtc -I dtb -O dts -o temp.txt tegra210.dtb
FATAL ERROR: Couldn't open "tegra210.dtb": No such file or directory
You need to create tegra210.dtb, or name the full path to it if it isn’t in your current directory. Edit tegra210.dtb name for your specific case.
