I have installed all the required SDKs, including cmake, cuda, Visual studio 2019, directX, Vulkan, FFMPEG LGPL, Agility, and the compilation commands are as follows:
Cmake - G “Visual Studio 16 2019” - A “x64” - DCMAKE_ BUILD_ TYPE=Release - DFFMPEG_ DIR=D:/ffmpeg-n4.4 latest win64 lgpl shared-4.4 DSKIP_ GL_ DEPENDENCY=TRUE - DSKIP_ GL_ DEPENDENCY=TRUE - DAGILITY_ SDK_ BIN=D: d3d build native bin x64- DAGILITY_ SDK_ VER=610- DCMAKE_ INSTALL_ PREFIX=
This step of compilation was successful, generating the NvCodec.sln file, but the step of generating the executable file failed
Cmake – build-- Target install – config Release
Continuously reporting errors error MSB8066 custom generation of has exited with code 1, Does anyone know what the reason is
Print as follows:
1>Checking Build System
Building Custom Rule D:/Video_Codec_SDK_12.1.14/Video_Codec_SDK_12.1.14/Samples/AppDecode/AppDec/CMakeLists.txt
AppDec.cpp
D:\Program Files\Nvidia\CUDA\v12.2\include\cuda.h(20651,1): warning C4819: 该文件包含不能在当前代码页(936)中表示的字符。请将该文件保存为 Unicode 格式以防止数据丢失 [D:\Video_Codec_SDK_12.1.14\Video_Codec_SDK_12.1.14\Samples\Build\AppDecode\AppDec\AppDec.vcxproj]
D:\Program Files\Nvidia\CUDA\v12.2\include\cuda.h(21325,1): warning C4819: 该文件包含不能在当前代码页(936)中表示的字符。请将该文件保存为 Unicode 格式以防止数据丢失 [D:\Video_Codec_SDK_12.1.14\Video_Codec_SDK_12.1.14\Samples\Build\AppDecode\AppDec\AppDec.vcxproj]
D:\ffmpeg-n4.4-latest-win64-lgpl-shared-4.4\include\libavutil\rational.h(1,1): warning C4819: 该文件包含不能在当前代码页(936)中表示的字符。请将该文件保存为 Unicode 格式以防止数据丢失 [D:\Video_Codec_SDK_12.1.14\Video_Codec_SDK_12.1.14\Samples\Build\AppDecode\AppDec\AppDec.vcxproj]
NvDecoder.cpp
正在生成代码…
AppDec.vcxproj → D:\Video_Codec_SDK_12.1.14\Video_Codec_SDK_12.1.14\Samples\Build\Release\AppDec.exe
Building NVCC (Device) object AppDecode/AppDecD3D/CMakeFiles/AppDecD3D.dir///Utils/Release/AppDecD3D_generated_ColorSpace.cu.obj
CMake Error at AppDecD3D_generated_ColorSpace.cu.obj.Release.cmake:220 (message):
Error generating
D:/Video_Codec_SDK_12.1.14/Video_Codec_SDK_12.1.14/Samples/Build/AppDecode/AppDecD3D/CMakeFiles/AppDecD3D.dir///Utils/Release/AppDecD3D_generated_ColorSpace.cu.obj
D:\Program Files\Microsoft Visual Studio\2019\Community\MSBuild\Microsoft\VC\v160\Microsoft.CppCommon.targets(241,5): error MSB8066: “D:\Video_Codec_SDK_12.1.14\Video_Codec_SDK_12.1.14\Samples\Utils\ColorSpace.cu;D:\Video_Codec_SDK_12.1.14\Video_Codec_SDK_12.1.14\Sampl
es\AppDecode\AppDecD3D\CMakeLists.txt”的自定义生成已退出,代码为 1。 [D:\Video_Codec_SDK_12.1.14\Video_Codec_SDK_12.1.14\Samples\Build\AppDecode\AppDecD3D\AppDecD3D.vcxproj]
Building NVCC (Device) object AppDecode/AppDecImageProvider/CMakeFiles/AppDecImageProvider.dir///Utils/Release/AppDecImageProvider_generated_ColorSpace.cu.obj
CMake Error at AppDecImageProvider_generated_ColorSpace.cu.obj.Release.cmake:220 (message):
Error generating
D:/Video_Codec_SDK_12.1.14/Video_Codec_SDK_12.1.14/Samples/Build/AppDecode/AppDecImageProvider/CMakeFiles/AppDecImageProvider.dir///Utils/Release/AppDecImageProvider_generated_ColorSpace.cu.obj
es\AppDecode\AppDecImageProvider\CMakeLists.txt”的自定义生成已退出,代码为 1。 [D:\Video_Codec_SDK_12.1.14\Video_Codec_SDK_12.1.14\Samples\Build\AppDecode\AppDecImageProvider\AppDecImageProvider.vcxproj]
Building Custom Rule D:/Video_Codec_SDK_12.1.14/Video_Codec_SDK_12.1.14/Samples/AppDecode/AppDecLowLatency/CMakeLists.txt
AppDecLowLatency.cpp
